#1275 | |
Drives: FR-S Whiteout
Check this thread out: http://www.ft86club.com/forums/showthread.php?t=69871 Edit: I'm not sure how common it is to require rescaling while running the grimspeed intake, but you might want to double check for any vacuum leaks just to be sure.
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 06-14-2016 at 10:42 PM. |
#1276 |
Drives: GT86
Could someone please explain me why my tune is now reading much leaner?
With OTS Stg1 i had around 11.8-11.7 AFR at WOT Now 12.5-12.2 AFR with Wayno's Stage 1. Nothing has been changed to MAF Scaling or Fueling / OpenLoop etc. What is happening? And the knock in the log is for sure because of running lean. Has it something to do with Front Oxygen Sensor Scaling? I am the only one with those AFR values if i can remember in this whole thread :/ http://datazap.me/u/rezi/14062016wot...3268-3203-4549 |
#1277 | |
Drives: Toyota 86 GTS
- Every car runs slightly different. - They are example maps only. Front O2 is for AU cars. - Stg1 runs leaner than Stg2 and always has. - Stg1 generally knocks more due to having same timing map as Stg2 up to 6k rpm. - Why don't you just replace front O2 with stock and test it instead of whinging? - Multiply 3.44 and above by 1.02 and will be fixed, takes 2 min. |
#1278 |
Drives: 2014 White BRZ
Did another log today and it looks much different than the first one after 200km on the tune.
http://www.datazap.me/u/randomthough...l?log=0&data=1 |
#1279 | |
Drives: GT86
FLKC was also reduced. Also, it seems that my FBKC is going crazy with AC activated, everytime the AC kicks in and i am on the throttle it seems to detect "false knock". Is that normal? IAM dropped down to 0.98, but i think it is because of the AC. I will give it a another week of learning time for the knock-sensor. AFR / IAM drop: http://datazap.me/u/rezi/16063?log=0...rk=3357-819-93 FBKC with AC on: http://datazap.me/u/rezi/16061?log=2...zoom=3140-4880 FYI, Intake Temperature was around 87F-90F |
#1280 |
Running your AC will throw the fuel trims off and can increase the amount of knock correction. Not sure if it "false" or real knock. As long as the computer is doing its job I wouldn't be too concerned with a bit of knock correction while the AC is turned on.
Intent > Content
cowardice is the mother of cruelty. |
#1281 |
Drives: 2013 GBS BRZ Limited
http://datazap.me/u/bfife22/run4?log=0&data=1
3rd gear pull. Stg 2 UEL OTS tune. I have the Perrin Intake (non bigMAf), JDL Catted UEL header, and a Perrin Catback. This run is with the OTS MAF scaling, using Perrin's MAF scaling for the non bigMAF intake made the AFR go really lean. This Stg 2 OTS tune also has less knock than the Stg 1 OTS tune did (which I initially ran because of the catted header) IAM drops down to .98 then .95 starting around 4600 rpm. Any ideas? EDIT: just read the above post. Would like to add that AC was on. Also, outside temp was ~95 degrees F and Intake Air Temp was ~100 degrees
APEXi / JDL / Perrin / Grimmspeed / Tein / Hotchkis / TRD / RAYS / Michelin / Raceseng / JPM Coachworks / SWEIDIT / Carsmo / TOM's / OFT / OEM Audio
#1282 |
http://www.datazap.me/u/bfife22/run6?log=0&data=1
Starting to wonder if most of the knock is due to high ambient temperature. Here is another run on the same portion of road but with the outside temp at a brisk 84 degrees F. Notice some FLKC but IAM stays at 1 the entire run.
#1283 |
Drives: 2014 BRZ Limited
Hi guys!,
Finally went stg2 UEL. with JDL headers. Can you guys let me know what you guys think? http://www.datazap.me/u/gliderx/log-...50?log=0&data= |
#1284 | |
Drives: 2015 86 GTS
This is music to my ears. Since I have had the exact same header sitting in my shed for 6 mths and am thinking about finally installing it, are there any pointers you might like to share ![]() Which "base" map did you finally choose to work from? Thx Oops - just noted your response in the other thread
#1285 | |
Drives: 2015 Firestorm Scion FRS
#1286 | |
Drives: 2015 86 GTS
![]() I did have a look at Wayno's Base Timing B map for 98 RON, but have a sneaking suspicion I will see quite a bit of FLKC at 4500-6000 rpm given the added timing compared to Shiv's OTS. I suspect 1.5-2.5 degrees of FLCK in this range if I implement just changes to this table. I will have a look at it once Shiv releases the updated logger definitions for D00G roms (my car) and post some logs for input in the meantime. |
#1287 | |
Drives: FT86
check the knock correction max A tables as well as total timing is Base Timing B plus Knock Correction Max A. I think you will find wayno has shifted the amount of timing in the knock correction table |
#1288 |
Since i was able to take some hot temperature logs thanks to the triple digit weather the past couple of days I was able to do some adjustments to MAF IAT compensation table. It's still a tick leaner than I'm shooting for in OL but the addition to the compensation table seems to be doing what is expected. The current maf scale was dialed to 65~72*f IAT so that the 68* column in the compensation table is unmolested at 0 compensation and the rest of the table is dialed according to fuel trims being logged in either colder or hotter IATs.
logged in 107*f ambient temps and +0.78% addition of fuel from LTFT: http://datazap.me/u/solidone/z6-kc1e...zoom=5575-5737 Previous setting in approx 90*f ambient and -0.78% fuel from LTFT" http://datazap.me/u/solidone/z61b-ho...13&zoom=52-181 You will also notice that the ignition advance is a few degrees lower as I've also made the IAT ignition advance compensation more aggressive in pulling timing at higher IAT above 100*f. If only there was a ignition advance compensation table for oil temps... Edit: Same revised IAT compensation tables @77*f ambient and +0.78% LTFT: http://datazap.me/u/solidone/kc1e-78...zoom=5939-6375 A little richer than intended at 83*f IATs. looks like I overshot the compensations in OL MAF voltages for temps above 68*f and below 100*f. Will reduce compensation below 100*f IAT adn increase above 100*f. Very close to matching the actual AFR output to my OL Fuel tables. :fistpump: Edit 2: Minor adjustments on this "h" revision of the IAT MAF compensation table. Target AFR's (OL fuel table) are approx 0.25:1 lower than Commanded AFR. 80*F IAT and about 75*f Ambient and 0% LTFT. So far so good. AFR are above 95% accurate in OL above the AFR fluctuations caused by VVT ( 4200rpm-ish) and below 7000RPMs before 20% PI kicks in. Hopefully I can get some logs with IAT's above 110*F soon. I will be aiming to get the AFR to run at or slightly richer above 100*F IAT's. http://datazap.me/u/solidone/z6-kc1h...zoom=2286-2626 66*f IAT same H calibration, looks to be slightly leaner than I remembered. : http://datazap.me/u/solidone/z6-kc1h...zoom=1878-2059 G cal with 90*f IAT: http://datazap.me/u/solidone/kc1g-1s...zoom=4187-4466 vs. H cal with 90*f IAT: http://datazap.me/u/solidone/z6-kc1h...mark=5906-5846 Afr did not budge with the minor changes applied to the MAF IAT comp table.
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 07-03-2016 at 08:30 PM. |
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 01:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 12:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 09:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 04:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 09:27 AM |
