Old 05-06-2016, 12:11 AM   #1
FRS Justin
Drives: 2013 Asphalt FRS
P0300 random cyl misfire
Has anyone had a P0300 DTC and if so what was the cause...
Thanks
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 05-11-2016, 05:37 PM   #2
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
Yes I did...
Thanks
It was because the spark plug grenaded...
Jaden
Jaden is offline   Reply With Quote
The Following User Says Thank You to Jaden For This Useful Post:
FRS Justin (06-10-2016)
Old 05-12-2016, 12:21 AM   #3
FRS Justin
Jaden
Interesting I will pull mine tomorrow...... It has only done it once but who knows.
710whp
The Following User Says Thank You to FRS Justin For This Useful Post:
SoCal80six (06-10-2016)
Old 05-12-2016, 02:32 AM   #4
Jaden
Road-hole
Oh you'd know...
I say it was because the spark plug grenaded but it was the precursor to it grenading, the cylinder wasn't really firing at all once it failed completely.
Jaden
FRS Justin (05-12-2016)
Old 05-12-2016, 04:15 AM   #5
steve99
Drives: FT86
Are your afr ok, not running lean.
no high ltft
check earth connections
is the di injection computer securly grounded its grounded via mounting bolts
Old 06-10-2016, 12:10 AM   #6
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Just threw that code today afr was not reading lean. Cel popped on and off for like 1 min while I was driving then went away on its own. Any ideas what could cause this or what I should look for?
SoCal80six is offline   Reply With Quote
The Following User Says Thank You to SoCal80six For This Useful Post:
Old 06-10-2016, 06:40 AM   #7
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Thanks
There are approximately 4,593 things that can cause a P0300. We need more to work with.
You can pull everything everywhere and do a general inspection for anything broken. Check for vacuum leaks. But don't start throwing parts at a P0300, you won't fix it but you will spend a lot of money replacing good working OEM parts for shit aftermarket parts.
guybo is offline   Reply With Quote
The Following User Says Thank You to guybo For This Useful Post:
Old 06-17-2016, 03:34 PM   #8
MirthScout
Drives: Scion FR-S MT Hot Lava
Mine is at the dealer now for P0301 and P0300; running rough and stalling out at low RPM. The first theory was the coil pack for cylinder 1. Replacing it didn't fix it. The spark plugs were replaced about a month ago. They checked a bunch of other things and couldn't find the cause. They kicked it up to Toyota and after a week got back a new theory; cylinder 1 exhaust valve spring is weak and/or damaged. They are about to start tearing down the engine to find out and maybe fix. So, yeah, it seems it can be really hard to figure out the cause. I'm not sure they've figured out mine yet.
MirthScout is offline   Reply With Quote
Old 06-19-2016, 05:26 PM   #9
jwvand02
Drives: 2013 SWP BRZ Limited
no high ltft
This is the one I had problems with - lost one of the mounting bolts to the underbody monster and didn't think it was a big deal... turns out it is.
jwvand02 is offline   Reply With Quote
Old 12-03-2017, 05:02 PM   #10
Dru670
Drives: 2016 Scion FR-S
Figured out what the problem was?
Dru670 is offline   Reply With Quote
FI car - P0300 code, and now hesitation/bogging at higher rpm FirestormFlex Engine, Exhaust, Transmission 9 08-13-2020 11:57 PM
P0300 and P0304 CEL -- uh oh! empower-auto Issues | Warranty | Recalls / TSB 26 04-16-2018 04:19 PM
Misfire when cold Lawnik Engine, Exhaust, Transmission 5 10-05-2014 09:40 PM
p0300 code... Anyone else?? NickFRS Engine, Exhaust, Transmission 1 09-06-2013 12:33 AM
Misfire Jono AFRICA 49 12-12-2012 07:01 AM
