Old 03-26-2016, 01:34 PM   #1
FirestormFlex
Drives: 2015 Turbo FR-S
FI car - P0300 code, and now hesitation/bogging at higher rpm
My car is a 2015 FR-S. I recently had the SBD turbo kit installed, tuned by Moto-East. I'm on the 3rd tune revision and everything has been going great - car was driving like a dream.
Then today while driving to work, I did a pull in 4th gear. Hit a steady 10.4psi - right on target. Right around redline I shifted into 5th, and I had a CEL flash for few seconds. Everything seemed to be running ok still and I continued to work.
When I arrived, I hooked up my laptop and pulled a code - P0300 - multiple cylinder/random misfire. I cleared the code.
When I left work to drive home, the car started fine and idled fine. Driving around town from light to light was completely normal as well. But once I got on the highway, the car was running like crap - it was fine until 4500rpm or so, but after that would start hesitating/bogging like crazy. It was hard to get the car up to 5000rpm. Once I got off the highway, everything was still running smoothly while idling at stop lights etc.
Any ideas here? Is it possible that it's a coil issue? Did I blow up my car?
FirestormFlex is offline   Reply With Quote
Old 03-26-2016, 06:15 PM   #2
steve99
Talk to the tuner
could be heaps of things
running lean due air leak
bad fuel
check electrical connections
bad spark plugs coil packs ect
http://forums.nasioc.com/forums/show....php?t=2550077
Old 03-26-2016, 09:06 PM   #3
x1UP
One & Done (AOZORA)
x1UP's Avatar
Drives: '15 Series.Blue BRZ (WRB)
Mike at Moto-East should be able to help you out easily. He's one of the best tuners out there for our car!
"I have the need....the need for speed! - Maverick (Top Gun)
x1UP is offline   Reply With Quote
Old 03-27-2016, 10:52 AM   #4
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Did you clamp the Evap line under the intake manifold?
It sounds a whole hell of a lot like it popped off.
If it pops off, you have an open port under the intake leaking boost, downstream of the MAF sensor. Bad things follow.
Lots of people have had the same issue with the same symptoms.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 03-27-2016, 12:13 PM   #5
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Anyone should do this before turbo install. The hose also leading from the evap to the hardline by the injectors also isn't clamped and can pop off.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 03-27-2016, 12:18 PM   #6
FirestormFlex
All lines were clamped at the time of install. We will be going back and double checking everything though .
Old 07-05-2017, 02:09 PM   #7
AfterFXNinja
Drives: Man
Send a message via ICQ to AfterFXNinja Send a message via AIM to AfterFXNinja Send a message via Yahoo to AfterFXNinja
Sorry for bump, but I'm having the same issue with the SBD kit. How did you fix this?
AfterFXNinja is offline   Reply With Quote
Old 12-02-2017, 10:25 PM   #8
Dru670
Drives: 2016 Scion FR-S
updates to this issue please?
Dru670 is offline   Reply With Quote
Old 12-15-2017, 04:48 PM   #9
BRZ RN
BRZ RN's Avatar
Drives: Blue BRZ
my car bogged down bad and have the same problem now. i dont know what to do next
BRZ RN is offline   Reply With Quote
Old 08-13-2020, 10:57 PM   #10
ML
ML's Avatar
Drives: 13 White MT FR-S
sorry for the necro...Had this exact same issue at the track today. Wouldn't go over like 6000 rpm and felt like fuel was cutting out or something. AFR looks fine so doesn't seem like injector/sparkplugs. Also have a bad o2 sensor I believe, which I will replace.
Logs:
https://datazap.me/u/sethmtloutlookc...?log=1&data=16
P0300 and P0304 CEL -- uh oh! empower-auto Issues | Warranty | Recalls / TSB 26 04-16-2018 03:19 PM
Engine bogging / stumble / hesitation / jerking during accelaration ard 2.5k - 3k RPM mo420 Issues | Warranty | Recalls / TSB 24 07-29-2017 07:35 PM
Engine bogging down FRiSson Issues | Warranty | Recalls / TSB 6 08-14-2015 08:07 PM
p0300 code... Anyone else?? NickFRS Engine, Exhaust, Transmission 1 09-05-2013 11:33 PM
Bogging Question??!! Help needed... ScionFrsFan Engine, Exhaust, Transmission 36 02-05-2013 06:44 PM
