Old 06-15-2016, 11:10 AM   #1
Hugo
Drives: Toyota 86
Oil filter torque?
Hey guys,
Just wondering is it really necessary to torque down an oil filter? On the genuine filter it says to torque it down 12~16Nm? I thought hand tight was enough for filters? If so how would you go about getting a wrench to torque it...tried searching to no avail. Also would the drain plug need to be torqued as well? Think i saw in the DIY section its at 28.9.
Hugo is offline   Reply With Quote
Old 06-15-2016, 11:19 AM   #2
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
Hand tight is fine for oil filters.
murdoc is offline   Reply With Quote
The Following User Says Thank You to murdoc For This Useful Post:
brianhj (06-15-2016)
Old 06-15-2016, 11:31 AM   #3
12 to 16 nm would be about hand tight anyway.
Just make sure the drain plug crushes the washer. Don't over do it.
Old 06-15-2016, 11:58 AM   #4
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
are you doing it or the dealership/oil change place?
If its an oil change place/dealer-about 150ft.lbs should do
NOTE THIS IS A JOKE. They always seem to put oil filters/bolts WAAAAY too tight.
The Following 3 Users Say Thank You to continuecrushing For This Useful Post:
MuseChaser (06-15-2016), p1l0t (07-04-2017), Tcoat (06-15-2016)
Old 06-15-2016, 11:59 AM   #5
D_Thissen
D_Thissen's Avatar
Its bad when you need to use an extension on your socket to loosen the drain plug.
The Following 2 Users Say Thank You to D_Thissen For This Useful Post:
continuecrushing (06-15-2016), Tcoat (06-15-2016)
Old 06-15-2016, 12:31 PM   #6
Yep, one hand tight is sufficient ........ unless your hands are greasy and/or you are a weakling ...... then one hand plus two fingers and thumb of the other hand is good.......
Old 06-15-2016, 12:35 PM   #7
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
Snug, then 1/4 turn.
The key to a long marriage, eh?
sdemo is offline   Reply With Quote
The Following 6 Users Say Thank You to sdemo For This Useful Post:
brianhj (06-15-2016), continuecrushing (06-15-2016), Guff (06-15-2016), humfrz (06-15-2016), hypebrz (06-16-2016), soulreapersteve (06-16-2016)
Old 06-15-2016, 12:40 PM   #8
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Touching + 3/4 turn on the filter
Decay107 is offline   Reply With Quote
The Following 2 Users Say Thank You to Decay107 For This Useful Post:
DarkSunrise (06-18-2016), Ultramaroon (06-15-2016)
Old 06-15-2016, 12:42 PM   #9
ZionsWrath
Thanks
ZionsWrath's Avatar
When the impact stops is standard torque spec if you take your car to a shop
Or are you doing this yourself?
Old 06-15-2016, 01:30 PM   #10
murdoc
murdoc's Avatar
The idea of using an impact on an oil drain bolt makes me shudder...
Old 06-15-2016, 01:32 PM   #11
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by Hugo View Post
Hey guys,
Gasket contact --> 3/4 additional turn or so.
As for how to get a torque wrench on, it'd be with a tool like this:
https://www.amazon.com/Lisle-63600-O...dp/B0002SR4Q8/
-alex
Old 06-15-2016, 08:59 PM   #12
pooch
pooch's Avatar
Drives: 2013 Scion FR-S (M/T)
Hand tighten then 3/4 turn with a wrench after..
pooch is offline   Reply With Quote
Old 06-15-2016, 09:13 PM   #13
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
How about using an impact gun to remove spark plugs?
I shit you not I saw it happen and saw the aftermath.
Old 06-15-2016, 09:18 PM   #14
pooch
pooch's Avatar
No need, socket wrench is all you need..
Calculate torque when using a crows foot on torque wrench BirdTRD DIY (Do-It-Yourself) Guides 0 10-11-2015 04:02 PM
Requested torque and Calculated torque nickw14 Software Tuning 3 06-13-2015 04:09 AM
Cusco Oil Filter or Blitz Oil Filter Mr.Impreza CANADA 6 10-11-2014 07:08 AM
OEM Subaru engine air filter + cabin air filter autobrz Mechanical Maintenance and Tools 6 03-09-2014 09:28 PM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
