Old 06-14-2016, 11:05 PM   #1
n2t
Drives: SWP BRZ Limited M/T
Car pulls left and right on high speed, need advice!
I have a 13 BRZ, running stock tires (about 20k miles on all 4) until I hit a nail last Sunday night. The nail was on the side and could not be repaired so I bought 2 new Hankook Ventus V12 Evo to replace both rear ones. Tires, mounting and balancing were all from a local reputable tire shop.
After that my car started pulling left and right on the freeway whenever I drive 65+ mph. Anyone knows what the problem could be?
PS. I can't go back to the tire shop until Saturday morning.
n2t is offline   Reply With Quote
Old 06-14-2016, 11:07 PM   #2
swarb
Alignment, wheel balance, air pressure.
The Following User Says Thank You to swarb For This Useful Post:
SoCal80six (06-15-2016)
Old 06-14-2016, 11:11 PM   #3
n2t
At first, it was pulling left and right like crazy then I checked all tire pressure last night and 3 were at 40 PSI, except for rear right which was about 32 PSI. I pumped air to make all 4 at 40 PSI and it still pulls a little bit.
Old 06-14-2016, 11:14 PM   #4
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Start with air pressure. Chances are one tire is lower than the other.
Next check the lugs nuts are nice and torqued to spec.
If the cars alignment was good before then it's not that.
Thrid, it could be the new tire tread. Either keep driving for a few hundred miles or do a burn out.
Old 06-15-2016, 12:07 AM   #5
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
Right there😃
turtlefeeder is offline   Reply With Quote
Old 06-15-2016, 12:21 AM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Alignment.
That, and you have essentially high performance tires on one axle... you're experiencing tramlining.
-alex
guybo (06-15-2016)
Old 06-15-2016, 12:27 AM   #7
raven1231
I'd either not drive at high speeds or learn to pull to the left
nickmerronesucks (06-15-2016)
Old 06-15-2016, 01:28 AM   #8
How about putting all 4 of the tires pressures at 35 psi and see if that makes a difference.
fumanchu1 (06-15-2016)
Old 06-15-2016, 03:12 AM   #9
n2t
Traffic flow from my home to work is 70mph+, either I have to keep up with it or stuck behind semi trucks doing ~50mph =(
This is what I've just done right now. I will see how it feel, tomorrow morning, on the way to work.
Thank you everyone for your input, eventually I'll take the car back to the tire shop this weekend. I'm just the type of guy who can't sleep at night when there's problem with my car.
Old 06-15-2016, 08:34 AM   #10
jasonojordan
Drives: 2013 satin white brz limited
what width of tire did you go with. This can also play into it as a wider tire will deff react differently to the road surface then the pizza cutter tires the car came with.
There is a section of road by my house that is very uneven and the car pulls to the left and right a ton on it but the rest of the time the car is fine.
jasonojordan is offline   Reply With Quote
Old 06-15-2016, 08:47 AM   #11
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
alignment won't do you any good. The stock tires will tramline and with different rubber on the rear, it's causing front and rear to track slightly different. Make sure that the Hankooks are mounted on the correct side- they are directional.
If they are mounted the right way, grab a jack and put the hankooks on the front and the stockers on the rear, see if that helps. You'll probably get a little more oversteer afterwards though.
guybo is offline   Reply With Quote
Old 06-15-2016, 08:57 AM   #12
WNDSRFR
Drives: FR-S,GTI
I agree with humfrz. 40 psi is way too high. The car is extremely twitchy with high tire pressures. Last time I had my tires changed I had the same problem. Checked the pressure and it was 65 psi!
Always check the pressure after anybody fools with your tires.
The Following User Says Thank You to WNDSRFR For This Useful Post:
Tcoat (06-15-2016)
Old 06-15-2016, 10:23 AM   #13
stevesnj
stevesnj's Avatar
Should be 35 psi all around
My 2016 Build thread
Old 06-15-2016, 10:38 AM   #14
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
40 psi is fine if you are checking tire pressure when hot... if cold pressure should be around low to mid 30s (aka 30-35 depending on a variety of factors).
fumanchu1 is offline   Reply With Quote
High RPM for current speed HachiRo Engine, Exhaust, Transmission 14 04-02-2015 03:59 PM
Vortech vs. Speed By Design-Need advice raven1231 Forced Induction 21 03-25-2015 11:05 PM
ECU pulls timing at high oil temps? brillo Engine, Exhaust, Transmission 24 03-31-2013 10:10 PM
AT holding 2nd gear to high revs during a long left turn EK_Golfer Scion FR-S / Toyota 86 GT86 General Forum 9 03-01-2013 11:35 AM
Video: BRZ / FR-S High Speed Run to 124 MPH (200 km/h) Levi BRZ Photos, Videos, Wallpapers, Gallery Forum 43 05-16-2012 01:37 AM
