Old 06-14-2016, 04:31 PM   #617
DarkSunrise
DarkSunrise's Avatar
Originally Posted by solidONE View Post
That does look better in terms of knock. Even with the higher oil temps.
For myself, and I'm not 100% sure what's "better", I let the computer do its thing dialing back the IAM and building it back up while I'm running on track. I also haven't been running an oil cooler so I'm running a lot hotter and getting much more knock correction than you are. I never bothered to try for a pure "track tune". I'll dial my ignition advance so there's little to no knock correction at temps higher than normal (not quite as high as what i'd see at the track) and call it a day. My IAM will fluctuate from as low as .85 to 1.0 on a track day, and run solid 1.0 with minimal FLKC otherwise. I'm pretty happy with that.
Yeah funny thing - I didn't actually set out to build a track tune, but it's going down that path isn't it? I figure since I have my logs from my hottest track days, why not build a tune that's as safe as I can get it.
For my latest tweaked v2.076 map, I basically took the log you just saw and:
1) Took out 0.5 x FLKC values from base timing B at loads above 1.00 g/rev, ignoring all FLKC under -0.69.
2) Threw in slightly more aggressive IAT timing comp.
3) Added a little coolant-based timing comp.
4) Leaned out the commanded AFR a little. I know this one is counterintuitive, but I was pegging the o2 sensor rich (11.25) on some of my logs from last year.
If this gets me track logs with FLKC and KC at -0.69 or below (and AFR holding ~12 to redline), I'll be pretty happy.
2022 BRZ Build
2013 FR-S Build
Old 06-14-2016, 04:38 PM   #618
DarkSunrise
Originally Posted by DocWalt View Post
I have my logs from last year on track (cooler weather though) with a tweaked 2.073 (reduced timing a little down low in the range that you can see the knock correction, MAF scaled, and that's about it)
I essentially never saw knock correction at high RPM. Just lift throttle (false knock IMO) and sometimes when getting on the gas quickly)
http://datazap.me/u/docwalt/10-24-15...log=0&data=1-5
http://datazap.me/u/docwalt/10-25-15...log=0&data=1-5
Interesting comparing logs with you. Out of curiosity, why not record FLKC as well?
2022 BRZ Build
2013 FR-S Build
Old 06-14-2016, 04:44 PM   #619
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Honestly, I don't remember not recording FLKC... Considering I wasn't doing any scaling I should have been recording FLKC. I'll record some logs at Putnam Park in a week and a half, it's supposed to be over 90 degrees out there.
Old 06-14-2016, 09:57 PM   #620
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
sound like you have a pretty good handle on it. I'm sure you already know of the tradeoffs you're making having your ignition advance tables set as conservatively as you have. Though it would be pretty awesome if you can get all the compensation tables dialed in so that you'd have max power (max ignition advance, perfect afrs, etc.) under all situations across the entire range of temperatures and loads along with minimal knock corrections for a given set up. At least we try to get as close to that level as we can without wasting too much time staring at logs, flashing then reflashing the ECU.
Another thing to consider between the 2 OTS tunes is the cam timing, though you'd probably have to throw it on a dyno to really see what's what.
Intent > Content
Old 06-14-2016, 10:09 PM   #621
DarkSunrise
Ah yes, chasing the dream
Yeah I was wondering about that too. I noticed that the intake cam timing in the v2.076 OTS map is essentially the same as the custom JDL UEL intake cam timing Shiv released. The exhaust cam timing is different, but that could be because the JDL UEL tune was developed using E85. Like you said, probably need a dyno to figure out what's ideal.
2022 BRZ Build
2013 FR-S Build
Old 06-14-2016, 10:39 PM   #622
solidONE
solidONE's Avatar
Keep me updated. I'd like to know if you manage to get your calibrations to work they way you want. Hopefully Shiv doesnt mind this threadjack with all this non-OFH related stuff. OFT FTW? haha
Intent > Content
Old 06-28-2016, 09:18 PM   #623
Myv
Myv's Avatar
Drives: SWP BRZ Limited MT
Just wondering if anyone is using this tune with FT86 SpeedFactory Catted UEL Header?
Myv is offline   Reply With Quote
Old 06-29-2016, 04:50 PM   #624
G-awesome
Drives: 2015 Firestorm Scion FRS
The OFH tune is aggressive for a catted UEL header. I have the JDL one and I've done a bunch of testing on it as well as the stage 2 oft. The stage 2 oft will work but it'll knock a bit around mid to high rpm. You will have to datalog and test to remove timing at the high knock areas. Best to stick with the stage 1 if you don't want to do some additional tweaking to the oft stg 2 tune.
G-awesome is offline   Reply With Quote
Old 06-29-2016, 06:54 PM   #625
Myv
Myv's Avatar
Thanks I'll probably give the OTS Stage 2 a try on 94 gas and do some logging.
Old 07-01-2016, 08:46 AM   #626
K_Gork
Drives: White 2013
I'm running that setup, haven't had any issues
K_Gork is offline   Reply With Quote
Old 07-01-2016, 11:37 AM   #627
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
You could pay $200.00 extra and get the custom tune package from OFT. That way they will do a custom tune for your specific parts on the car
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
Old 08-15-2016, 12:50 AM   #628
Sam.Vera
Detective John Kimble
Sam.Vera's Avatar
Drives: 2016 FR-S
Anyone try the OFH2 tune with catless even-length headers? I have 91 fuel only in my area, but am going to be adding NOS branded octane booster with every tank.
Sam.Vera is offline   Reply With Quote
Old 08-15-2016, 06:48 PM   #629
EffaressNOOB
EffaressNOOB's Avatar
Drives: Halo 2016 Scion FR-S, 6MT
The following is a link of 3 datalogs (1 CL and 2 OL) with Stage 2 UEL E85 with a Perrin Inlet Hose, K&N Drop In, Moded Snorkel, OFH, Invidia N1 Catback:
http://datazap.me/u/taylorshift/log-...0?log=0&data=1
Below is with Stage 2 UEL E85, Perrin 3" BigMAF CAI, Perrin Inlet Hose, OFH, Invidia N1 Catback:
http://datazap.me/u/taylorshift/oft-...l?log=0&data=1
I can't log mafV or IAM with my CALid of F00C, so I had to remove the Perrin 3" CAI.
Can someone tell me if there's any knock on my current setup? (top link)
Enkei TFR (Copper) 17x9+45 | Hankook Ventus V12 Evo2 245/40 | Tein Flex A
OFT Stage 2, E85 | Kraftwerks Skunk2 CAI
Open Flash Unequal Length Header
Invidia N1 CatBack
InstaGram: 49RJ
EffaressNOOB is offline   Reply With Quote
Old 08-22-2016, 05:04 PM   #630
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
So, does the Stage 2 OFH (v1.01) tune play nice with the CATLESS JDL UEL header or not? I haven't seen a clear answer yet, but I'm sure I could have missed something. To be fair though, there are 45 pages to sort through now.
smg1138 is offline   Reply With Quote
Just how noticeable is OFT+OFH and stage 2 tune? BBYZILA Software Tuning 58 03-20-2018 11:56 AM
OFT 2.0 Stage 1 93 Tune MurderRider Software Tuning 57 03-21-2016 12:30 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
FA20club.com Turnaround Times On Modified Tune Files FR-S Matt Software Tuning 103 11-13-2013 01:48 PM
So whate does stage 3 tune do? I already have 2 Frsexxxy Engine, Exhaust, Transmission 17 05-14-2013 06:30 AM
