Old 06-14-2016, 10:55 AM   #2409
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
Originally Posted by DocWalt View Post
I'm well aware, that was my point. I don't know how the heat cycles from DD use behave, are they half cycles because they never actually get HOT?
FWIW I've got two autocrosses and a track day in the next week and a half and 2k miles of highway driving. I'll be putting on new tires before the end of July, I think. 4 months of use out of tires... Depressing
Gotta pay to play😉
Sent from my SAMSUNG-SM-G900A using Tapatalk
jbailey8748 is offline   Reply With Quote
Old 06-14-2016, 11:33 AM   #2410
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Originally Posted by jbailey8748 View Post
Gotta pay to play��
I already paid, I've had a spare set of RE-71Rs sitting in my basement for a month I wasn't going to risk the silly tire shortage problem affecting my ability to drive to work or miss events (going for Philly region class championship)
Old 06-14-2016, 11:49 AM   #2411
e1_griego
e1_griego's Avatar
Drives: Many
^Yup, I bought two sets at the start of the year, just want to get through July with the 1st set if I can (our Tour and Pro are next month).
Also, I picked up that used Ace A/350 header that CSG Mike was selling so I'll be able to give some feedback soon enough.
e1_griego is offline   Reply With Quote
Old 06-14-2016, 12:18 PM   #2412
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Shameless plug, I need to dump a set if anybody wants one.
Edit: Like new and as such, near new pricing.
Vultures.
ineedyourdiddly
Old 06-14-2016, 04:25 PM   #2413
renfield90
The Stig's German cousin
It's fuzzy
Someone wanna grab a measuring tape next time they're under the car?
Old 06-14-2016, 04:27 PM   #2414
e1_griego
e1_griego's Avatar
Drives: Many
The other cat is on the front pipe. The Ace header replaces the overpipe.
Old 06-14-2016, 04:27 PM   #2415
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
What for? That bolts to a factory frontpipe so I'm honestly not sure what you're getting at. I don't have an ACE so I don't have any skin in that game, but I don't see an issue with it.
Old 06-14-2016, 04:44 PM   #2416
renfield90
It depends on rubber chemistry, but in general I consider them full heat cycles.
I've had tires heat cycles themselves to death just sitting in my garage for a few months. Why? Well, in summer our garages get up to around 100F. If you touched the tire it sure wouldn't be "pull your hand away hot" but it's enough.
When a tire heats up, the bits of rubber in the tire form bonds with each other (this is why graining is a symptom of cold tires, the bonds haven't formed yet and rubber freely comes off). The tire generates grip not through simple friction on the road surface, but by the rubber on the surface sticking to the road and stretching/breaking the bonds formed by the rubber. That's why rubber gets laid down on the fast line.
As the tire cools down, those bonds try to release back to their original state, but only get to 95% of it (this is heat cycling). The bonds that do not release become harder to break. Eventually too many of these bonds become permanent, the tire gets hard and it doesn't want to lay down rubber (which is the true way grip is created).
The warmer the tire, the more bonds get formed. Any heating of the tire results in a heat cycle, no matter how subtle. It may not be the equal of an autocross heat cycle but I can guarantee you some of those rubber bits bonded permanently and made the tire harder.
Since you're not laying down a lot of rubber on your daily commute, that's why your tires eventually heat cycle out before they ran out of tread. My BFGs set top index with cords showing last year, but that's because they saw 500 street miles max and were stored indoors with climate control and in bags. You really need to treat the current gen of street tires like race rubber if you care about max performance down to the cords.
The Following 4 Users Say Thank You to renfield90 For This Useful Post:
3essess (09-28-2016), DocWalt (06-14-2016), jbailey8748 (06-28-2016), smg1138 (06-24-2016)
Old 06-14-2016, 04:45 PM   #2417
renfield90
If that's the case it's legal. I must be thinking of a different header or misremembering the pic I saw.
Old 06-24-2016, 03:02 PM   #2418
alucard7755
alucard7755's Avatar
Drives: 2014 Grey BRZ
Originally Posted by 2superblus View Post
Black bushings or Yellow? have you greased them?
I've had some similar popping noises with my whiteline kit. I can't remember what color mine were, but they claimed to be the "greaseless" bushings. Should I have greased them anyway?
alucard7755 is offline   Reply With Quote
Old 06-24-2016, 04:50 PM   #2419
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
Based on my inside source at Whiteline grease them anyhow.
2superblus is offline   Reply With Quote
Old 06-24-2016, 05:21 PM   #2420
BRZHarley
Drives: 69 Firebird, 2015 BRZ
On the topic of the Whiteline bushings and endlinks...
I recently installed a Whiteline 20mm bar with the new greaseless bushing, I decided to try them out and they work great! Greasing them isn't going hurt to anything either...
The clunky noise on the other hand drove me nuts for a week until I determine the cause... The Whiteline bar comes with a nice thick epoxy coating, I found that the coating was preventing a good tightening of the end link to bar connection. The end link to strut was just fine... My resolution was to use an abrasive pad on my air grinder to remove the excess coating around the hole on the bar, took about 5 minutes per side. Once my sons and I cleaned up the bar and retorqued the end end link the clunking was gone and hasn't come back!
Good luck,
Ed
BRZHarley is offline   Reply With Quote
The Following 3 Users Say Thank You to BRZHarley For This Useful Post:
Blue Gt (06-24-2016), DocWalt (06-28-2016), smg1138 (06-24-2016)
Old 06-28-2016, 08:30 AM   #2421
jbailey8748
Good luck,
Ed
I had the same problem and solved it the same way. This does work
The Following 2 Users Say Thank You to jbailey8748 For This Useful Post:
BRZHarley (06-28-2016), DocWalt (06-28-2016)
Old 06-28-2016, 01:52 PM   #2422
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Good luck,
Ed
Good to know. Mine clunks like crazy too...even have some clunky sounds coming from the rear as well. See if I can't fix it up this weekend.
justinco is offline   Reply With Quote
The Following User Says Thank You to justinco For This Useful Post:
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
