Old 06-06-2016, 12:25 PM   #3151
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by Lastexile View Post
I don't AutoX. Sorry, I'm still very new to all of this. I drove a 2002 Chevy Cavalier before my FR-S .
So a 225/40 18x8.0 45 will be a good fit then? I want the off-set to be lined up with the sides if that makes sense. I don't want it to be really close to rubbing the wheel well. What tire would you recommend? I was looking at the Proxy T1 Sport. Would they be better?
Those are good tires. I run MPSS. I have also run RE760 brigestone. BFG sport comp 2, and Michelin A/S + (like A/S3). All are good for street.
I have eibach pro kit springs. (basically TRD) 7/8" lower, a conservative drop. functions well with the stock shocks.
You shouldn't rub at all with those specs.
Old 06-06-2016, 04:53 PM   #3152
Lastexile
Lastexile's Avatar
Drives: 2013 Firestorm FR-S
Awesome dude thanks a lot! I'm not lowered at all but if I do decide to lower, would it be a problem with the specs I gave you?
Lastexile is offline   Reply With Quote
Old 06-06-2016, 05:30 PM   #3153
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Thanks! You'll be good, no problems.
Old 06-11-2016, 06:55 PM   #3154
PickledRage
Drives: 2015 FR-S
Hey everyone,
I have a couple questions I am hoping to get feed back on. For springs should I go with Eibach or Swift? I am only going an inch but with stock wheels and tires for now, does anyone have feedback on spacer size and brand to kick out the stance a little so the stock wheels don't look funny?... Thanks!
PickledRage is offline   Reply With Quote
Old 06-13-2016, 01:40 PM   #3155
Driftin.BRZ
Drives: 2013 Subaru BRZ Sport-Tech
Looking to get new shoes for the BRZ and I'm new to the fitment thing. I'm thinking about 17x9 +20 or 18x10 +25 I don't know what size tires I'm going to need to run these wheel setups or if they fit. I'm currently on stock ride height will eventually get coils and give it a drop, would also want the tires a bit stretched
Driftin.BRZ is offline   Reply With Quote
Old 06-13-2016, 01:46 PM   #3156
Leonardo
Country Boy 4 Life
Leonardo's Avatar
http://www.ft86club.com/forums/showthread.php?p=764402
Your going to have issues with those specs on stock suspension. Read through the wheel directory for more information.
Old 06-13-2016, 03:52 PM   #3157
Driftin.BRZ
Would 18x8.5 +30 fit better?
Old 06-13-2016, 05:08 PM   #3158
Leonardo
Country Boy 4 Life
Leonardo's Avatar
http://www.ft86club.com/forums/showthread.php?t=44291
Old 06-13-2016, 06:17 PM   #3159
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by PickledRage View Post
Hey everyone,
Any of the springs that are a 1" or less drop work well with stock shocks. I have the Prokit springs. I'd also consider the RCE springs.
spacers thread.
http://www.ft86club.com/forums/showthread.php?t=71783
Old 06-18-2016, 10:27 PM   #3160
HuntingtonFRS
Drives: 2013 Scion FR-S in White
Hello everyone. I could really use some advice.
Picking up these wheels:
COSMIS RACING XT-206R BRONZE 18X9 +33MM 5X100
Not sure what tire to get. I want performance over stance. I don't want to stretch the tires and I don't want to poke beyond the fenders. I do have Tein Flex Z coil overs but I'm lowered about as much as the TRD springs take it.
Please guide me oh wise ones!
HuntingtonFRS is offline   Reply With Quote
Old 06-18-2016, 11:43 PM   #3161
swarb
18x9 +33 is roughly equal(outside width) to 18x 9.5 +39(38/40 is 1mm difference), so look up other setups and see how they fit and decide if you are ok with that look.
245/35 is a good tire size. Look up the specific tire and see the recommended rim width and the tread width to see how they should fit.
Camber/height/alignment would affect how they would fit.
I say the are a very good choice overall, not too wide, not too stancy pants, but not sunken in either.
Quick google search got me this pic. Looks good.
Be aware that you will be lowered less and will probably have less camber, so it may poke out at the top of the wheel slightly more.
The Following User Says Thank You to swarb For This Useful Post:
HuntingtonFRS (06-18-2016)
Old 06-19-2016, 12:58 PM   #3162
HuntingtonFRS
Yeah, I spoke to the owner of that car. He ran 225/40/18 which just seems insane to me. That would be crazy stretched would it not?
Old 06-19-2016, 04:01 PM   #3163
swarb
I wouldn't call it a crazy stretch, but still stretched quite a bit at around ~2 inches or so. I ran a 225/40 on a 9.5 rim. Exposes rim/sidewall to get damaged more easily. The rims all had rock chips all around. I probably won't do it again.
Leonardo (06-21-2016)
Old 06-27-2016, 08:54 AM   #3164
ShadowReaper
Indulgent Tormenter
ShadowReaper's Avatar
Drives: 15' LTD Subaru BRZ DGM
you're close to what I'm seeking for..
I am getting Enkei TS9s 18 x 8... I am getting my wheels and tires from tirerack..
For some ideas for tires, I am between:
-Continentals Extremecontact DW
-HANKOOK VENTUS V12 EVO2
-PIRELLI P ZERO NERO GT
All good tires if you ask me
Instagram: Gabe.it.the.ole.college.try
ShadowReaper is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
