Old 06-10-2016, 07:32 PM   #1
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Issue: Cruise Control no bump up or down
Stock FR-S. No mods. Used to work. Out of warranty.
Now, I can set the cruise at a given speed.
Going uphill it will bump up 1mph and then stay there rather than coming back down to what I set it at.
Bumping the + or - doesn't do anything anymore. Used to go up or down 1mph like it's supposed to do in the manual.
If I hold the lever it will move, but I often pass by the 1mph I wanted.
Any ideas how I can get it working again? Lint in the framistat? PB Blaster all over under the dash?
Has this been heard of before?
Ok. Take it to the dealer and hand over lots of cash that's in short supply I suppose.
Old 06-10-2016, 07:51 PM   #2
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Unplug battery for 10min or so. Replug in. Try it at different speeds. See if there's a difference.
Somewhere in another thread it says cruise control wont work if theres something wrong with your car.
Edit: Here ya go
http://www.ft86club.com/forums/showthread.php?t=16726
Old 06-11-2016, 11:15 AM   #3
bcj
Geo Tyrebighter Esq
bcj's Avatar
Cruise works in a basic fashion. No CELs or codes that I'm aware of.
It won't increment up or down.
I've got a post cam fix twin.
Old 06-13-2016, 03:41 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
http://www.ft86club.com/files/BRZwiringi.pdf
Page 109 clearly shows the wiring of the cruise control main switch. Since there's only two wires, I'm guessing there is a specific amount of voltage drop or signals that tell the car of each setting for cruise purposes.
My guess at this point is a malfunctioning cruise control main switch, assuming the ECU is properly flashed with no CEL. CEL will actually result in the cruise light on the dash being constant yellow instead of green.
-alex
Old 06-13-2016, 05:40 PM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Short story.
My buddy is a mechanic. He says he sprays a few squirts of Electrical switch cleaner into the ignition, or any switch that is having problems. 90%of the time, he says it fixes it. I have used it on the ignition of an old civic I had. it worked. I have not needed it on the FR-S yet.
I'd choose the brand you trust. I have some CRC.
https://www.google.com/webhp?sourcei...itch%20cleaner
Engine Check light, Traction Control light, cruise control light all on suddenly wqc3241 Software Tuning 2 01-10-2016 07:37 AM
CEL and Cruise Issue??? mortybryant Scion FR-S / Toyota 86 GT86 General Forum 7 03-23-2015 01:49 PM
Cruise Control nospoons Scion FR-S / Toyota 86 GT86 General Forum 34 06-17-2014 02:28 PM
Cruise control notout86 Scion FR-S / Toyota 86 GT86 General Forum 50 05-13-2013 02:01 AM
cruise control and speedo issue.. tibsy92 Issues | Warranty | Recalls / TSB 1 10-10-2012 12:21 PM
