Drives: Scion FR-S RS 1.0
CEL and Cruise Issue???
Started my RS1 this morning and the CEL was on. I'm just over 5k miles. No noticeable issues. Went ahead and took off. Approximately 10-15 miles later I notice my cruise control won't engage. The light is also orange (typically green). I stop, turn the car off and back on. CEL is off. Continue to drive and cruise control is now working.
Any ideas??? Sent from my iPhone using Tapatalk |
no concrete analysis can be made unless you're able to pull the CEL
Drives: 2014 Monogram
Not sure what the problem is but your car goes into limp mode when the CEL is on, hence not being able to use cruise control you may possibly get a traction control light on as well. I had the same issue. Bought a catless header which resulted in this issue, not sure if you have aftermarket parts but if you do a tune is needed. hope this helps
No aftermarket parts, but thank you for the info. Much appreciated.
Drives: 2005 Toyota Camry
Idea: CEL prevents cruise from being used.
Solution: find out what caused the CEL and prevent it from coming on. -alex |
Could be as simple as a wet or dirty sensor or something as bad as an possible total failure and 1,000 things in between.
If it repeats take it in.
#7 | |
If you have any plans at all (or not) for mods, an OBD dongle and something like Carista is a must have for reading and clearing codes. |
Drives: waiting on a 2021...
Have you gotten sideways, or done any donuts? Mine does the same thing sometimes when I slide it around, or do donuts. Turn the car off, start it back up, good to go. I think it has something to do with the stability control freaking out.
2016 4Runner Tail edition
2020 Camry 2020 RAV4 2013 Chevy 3500 4x4 Duramax 1999 Ford F250 Powerstroke, the tow rig 1969 Mustang, the fast car....(: |
| Jan 11th OTOC Cruise to the 'Cruise In Country Diner' | OTOC | Northwest | 12 | 01-11-2015 12:03 AM |
| Cruise to 'Cruise In Country Diner' 1-26-14 | OTOC | Northwest | 29 | 03-29-2014 12:39 PM |
| Cruise to Cruise In Country Diner Sept 8th | OTOC | Northwest | 6 | 09-06-2013 03:41 PM |
| OTOC cruise to Cruise in Country Diner | OTOC | Northwest | 36 | 01-15-2013 08:18 PM |
| cruise control and speedo issue.. | tibsy92 | Issues | Warranty | Recalls / TSB | 1 | 10-10-2012 12:21 PM |
