Old 06-10-2016, 12:37 PM   #29
Norinradd
Drives: 2013 frs
Originally Posted by mav1178 View Post
Has been, until you decided to spray the MAF sensor.
Again: OBD-II cars (in general), you need to buy a $20 code scanner so you can figure out what is wrong. If it tells you no codes, you need to reset it so that the problem can be duplicated. This way, you can provide the dealer with additional information so they can help you.
It's like high blood pressure. Maybe it's horrible in the clinic when you go for a checkup, but you are fine on an almost daily basis when you test at home. The more info you document, the better off you are when it comes to solving your problem... and step one starts with a reader to diagnose your code.
Old cars would have you turn a knob or screw on the ECU to spit out codes. New cars give you a simple way to read it and clear it instantly.
-alex
Whats wrong with spraying a maf sensor with specifically formulated maf sensor cleaner?
Why is a 20$ obd scanner better than the dealers 1200$ one?
The dealers obd couldnt even read my ecu. BUT two days ago the updated my ecu!????
HOW. Did the updTe ecu yet couldnt run codes? Id say the screwed up the obd prongs
2013 silver frs, injen intake, agency power header, hks exhaust, no kitties, ecutek tune
Norinradd is offline   Reply With Quote
Old 06-10-2016, 12:40 PM   #30
Norinradd
Drives: 2013 frs
You are in "limp mode". Probably from spraying the sensor. The code will need to be cleared.
Why would spraying the maf cause avehicle to go into limp mode? This sounds like you haveno clue what youre talking about.
This is good advice.
Why would a20$ obd workbettr thanthe dealerships obd scanner???????
Old 06-10-2016, 12:42 PM   #31
Norinradd
Drives: 2013 frs
Originally Posted by PandaSPUR View Post
too many issues at once, not enough background info...
Read sig
Old 06-10-2016, 12:52 PM   #32
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
Holy shit it doesn't work better... what it allows you to do is CLEAR your existing codes and therefore be able to REPLICATE the issue and possibly diagnose it at this time.
If you are flashing a code at this time and are in limp mode, you can change all you want but it'll stay in limp until you CLEAR the code.
This saves you the trouble/time/money/headache of having to go to the dealer and pay the fee they charge everytime you need to CLEAR the codes from your ecu.
It's a cheap purchase that in the long run ends up saving quite a bit of time and money if you plan on doing your own maintenance that won't need a trip to the dealer everytime something decides to throw a code.
fumanchu1 is offline   Reply With Quote
The Following User Says Thank You to fumanchu1 For This Useful Post:
humfrz (06-10-2016)
Old 06-10-2016, 12:52 PM   #33
fumanchu1
I hope that made it CLEAR for you
humfrz (06-10-2016)
Old 06-10-2016, 12:56 PM   #34
Norinradd
Drives: 2013 frs
Why couldnt dealer cleAr them? Hecouldnt evenget INTO my ecu. The car was a ghost. Unrecognizable. A 20$ obd wont do shit in this situation. But they got in two days ago to update ecu. So riddle me that.
Old 06-10-2016, 01:04 PM   #35
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
im getting a headache from reading this.. *unsub*
The Following 2 Users Say Thank You to PandaSPUR For This Useful Post:
fumanchu1 (06-10-2016), soulreapersteve (06-11-2016)
Old 06-10-2016, 01:06 PM   #36
fumanchu1
their scanner fcked up!? just cuz it's worth 1.2k doesn't mean it can't be defective or that the tech couldn't have fcked something up like an idiot.
Old 06-10-2016, 01:07 PM   #37
Eventually they are going to start to charge you diagnostic fees at at least $100 a pop.
Old 06-10-2016, 01:11 PM   #38
Norinradd
Drives: 2013 frs
Ya i have a diagnostic booked for tuesday morning
Old 06-10-2016, 01:11 PM   #39
Norinradd
Drives: 2013 frs
Try being the one dealing with it.
Old 06-10-2016, 01:12 PM   #40
Norinradd
Drives: 2013 frs
Or they fucked up flashing the ecu. Bending prongs or something and broke my female obd.
Old 06-10-2016, 01:15 PM   #41
fumanchu1
Could be the 20bucks scanner still isnt abad ideA though
Sent from my SGH-M919V using Tapatalk
Norinradd (06-10-2016)
Old 06-10-2016, 01:17 PM   #42
Norinradd
Drives: 2013 frs
As much as i love this car it will be gone for half of what i paid the day its fixed. Fuck electronics
Upgrade, now ticking. Fartsicle Scion FR-S / Toyota 86 GT86 General Forum 5 07-20-2015 10:30 PM
ticking sound when taking off???? 93frs Scion FR-S / Toyota 86 GT86 General Forum 5 02-09-2015 12:50 AM
Tapping/Ticking in 2nd gear radroach Issues | Warranty | Recalls / TSB 5 03-02-2014 05:00 PM
Ticking sounds from exhaust when off Kefu Issues | Warranty | Recalls / TSB 26 12-20-2013 02:11 PM
ticking noise? iHeartmyFR-S Issues | Warranty | Recalls / TSB 13 04-18-2013 05:42 PM
