#43 |
Drives: Toyota GT86
Very nice work ztan. I don't understand anything about the coding but I love your dedication with this car.
send using the coffeemaker
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners |
#45 |
Drives: FT86
@ztan
would it be possible to use the "Cranking Fuel IPW Compensation (IAT) " table instead looks like the temps could be rescaled its currently not used all 0% compensation shiv used it in the F10G E85 roms in 2.07 tunes as the cranking IPW tables were not defined correctly so could not be changed. |
#46 |
Drives: Toyota 86
Cranking Compensation v.2
*** Cranking code updated - my inferences from my logs to make v.2 code were wrong due to the delay in the Arduino Ethanol sensor controller starting to read a value ***
I tried to apply cranking compensation for E% applied to E0 fuelling and it didn't work - I think there was something in the code which does not allow positive compensation. To use compensations < 1.0, I have scaled cranking fuel to E85 and down-compensated for smaller E%. This one seems to work. I've multiplied E0 cranking tables by the following to get E85 cranking: Code:
ECT -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 100 110 1.54 1.54 1.54 1.54 1.51 1.46 1.36 1.26 1.17 1.10 1.04 1.01 1.00 1.00 1.00 1.00 Code:
000B9870 FlexFuel_Cranking_Comp: ; CODE XREF: Cranking_Compensations 000B9870 ; Cranking_Compensations_0 000B9870 ; DATA XREF: ... 000B9870 4F 22 sts.l pr, @-r15 ; Store System Register Long 000B9872 F4 48 fmov.s @r4, fr4 ; r4=ECT 000B9874 D2 14 mov.l #Pull_2D_A, r2 ; Move Immediate Long Data 000B9876 D4 1A mov.l #Ethanol_Cranking_Comp_Table, r4 ; Move Immediate Long Data 000B9878 42 4B jsr/n @R2 ; Pull_2D_A ; Jump to Subroutine with No delay slot 000B987A C7 17 mova FF_Mult_Max, r0 ; 1.35 000B987C D4 0E mov.l #RAM_FF_Crank_Comp, r4 ; Move Immediate Long Data 000B987E F5 08 fmov.s @r0, fr5 ; Floating-point move single precision 000B9880 D6 0A mov.l #RAM_Flex_Fuelling_Multiplier, r6 ; Move Immediate Long Data 000B9882 F4 68 fmov.s @r6, fr4 ; Floating-point move single precision 000B9884 F4 51 fsub fr5, fr4 ; fr4-FF_Mult_Max 000B9886 F5 9D fldi1 fr5 ; Floating-point load immediate 1.0 000B9888 F5 4E fmac fr0, fr4, fr5 ; 1+(crank_comp*(FF_Mult - FF_Mult_Max)) 000B988A F0 5C fmov fr5, fr0 ; Floating-point move 000B988C F4 0A fmov.s fr0, @r4 ; Floating-point move single precision 000B988E 4F 26 lds.l @r15+, pr ; Load to System Register Long 000B9890 00 6B rts/n ; Return from Subroutine with No delay slot 000B98AC FF F8 D4 14 off_B98AC: .data.l RAM_Flex_Fuelling_Multiplier 000B98AC ; DATA XREF: sub_B97C0 000B98B8 FF F8 D4 20 off_B98B8: .data.l RAM_FF_Crank_Comp ; DATA XREF: sub_B97C0 000B98C8 00 01 13 88 off_B98C8: .data.l Pull_2D_A ; DATA XREF: sub_B97C0 000B98D8 3F AC CC CD FF_Mult_Max: .float 1.35 ; DATA XREF: sub_B97C0 Seems to work. Cranking with Flex sender plugged and unplugged: Code:
MAF_V MAP ECT Port_IPW Direct_IPW Throttle MAF Load Accel Ethanol FF_Mult FF_Cranking 1.07422 99.7076 47.8367 9.46926 0 6.07415 1.63601 0.452178 0 0.0976563 1.00038 0.900488 1.2207 98.2765 48.2156 9.75813 0 5.73641 2.44261 0.451798 0 59.9854 1.24994 0.972127 Last edited by ztan; 12-18-2015 at 05:27 PM. |
| The Following 3 Users Say Thank You to ztan For This Useful Post: |
#47 |
Drives: gt-86 2013
Have no idea about all this teck stuff but thanks for all the great work you have done for this E85 OFT project Ztan.
We all appreciate it . |
#48 |
Drives: Toyota 86
Updated Arduino Flex sender code
There is a delay of around 1500 ms before the Arduino initializes and begins to run the frequency.measure code. There is a small delay in getting an ethanol value out to the ECU whilst the arduino is waiting for a number of frequency.measure periods to pass (at 100Hz, 100 cycles take 1 sec or 1000ms).
To minimise this, I've written an average voltage sender value to EEPROM which is restored as soon as the Arduino boots and then gets updated with a moving average value every time the frequency.measure value gets updated. Code (I've commented off PLX code which I am happy just logging now): Code:
//Flex Fuel sensor code
//Input frequency on pin 8 - pulled up to 5V through 1.8K resistor
//V_out pin 3 - 0-5V output through 1.8K resistor with 10uf capacitor to ground
//PLX iMFD serial packet on Tx pin 0 through 3.3V TTL voltage divider (3.3K/6.8K)
//TRAC double click code
//Input switch on pin 6 - pulled up to 5V through 3.3K resistor
//Output on pin 10 through NPN transistor to take VSC connection to ground
#include <Arduino.h>
#include <FreqMeasure.h>
#include <EEPROM.h>
//FlexFuel sensor
double sum = 0;
int count = 0;
int EE_V_add = 0;
int ethanol_int, V_out_int;
float freq, ethanol, V_out, V_out_avg, E_scalar;
float V_out_default = 147;
float E0 = 55.4; //calibration data for pure gasoline
float E85 = 130.8; //calibration data for E85
//PLX data
//long P0, P1, Pdelta;
//byte PLXpacket[7] {0x80, 0x00, 0x11, 0x00, 0x00, 0x00, 0x40};
//PLX iMFD packet, sent every 100ms:
//0x80 Start byte
//0x00 0x11 Sensor device fuel level
//0x00 Sensor instance
//0x00 0x00 Sensor value (integer, unscaled)
//0x40 Stop byte
//TRAC switch double click
bool TRAC_buttonMonitor = HIGH;
int debounce = 20;
int doubleClick = 200;
int longClick = 3500;
int TRAC_initializeDelay = 4000;
int TRAC_buttonState = 4; //initialize to 0 for normal operation, 4 for on by default after delay
long TRAC_buttonCounter = 0;
void setup()
pinMode (3, OUTPUT);
pinMode (10, OUTPUT);
digitalWrite (10, LOW);
pinMode (6, INPUT);
EEPROM.get(EE_V_add, V_out_avg); //load last V_out_avg
if (isnan(V_out_avg))
V_out_avg = V_out_default;
V_out_int = (int)V_out_avg; //convert to integer for analogWrite
analogWrite(3, V_out_int); //output V_out as PWM voltage on pin 3
FreqMeasure.begin();
// Serial.begin(19200);
// P0 = millis();
E_scalar = (E85 - E0) / 85;
void loop()
//Read FlexFuel sensor frequency
if (FreqMeasure.available())
// average several readings together
sum = sum + FreqMeasure.read();
count = count + 1;
if (count > 100)
freq = FreqMeasure.countToFrequency(sum / count);
sum = 0;
count = 0;
//Convert frequency to E%
ethanol = (freq - E0) / E_scalar; //scale frequency to E% interpolating E0 and E85 values
if (ethanol > 100)
ethanol = 100;
if (ethanol < 0)
ethanol = 0;
ethanol_int = (int)ethanol;
//FlexFuel voltage output
V_out = 255 - (2.55 * ethanol);
V_out_avg = V_out_avg + (0.05 * (V_out - V_out_avg)); //V_out_avg as moving average
EEPROM.put( EE_V_add, V_out_avg ); //store V_out_avg to EEPROM
analogWrite(3, V_out_int); //output V_out_avg as PWM voltage on pin 3
//PLX data packet
//P1 = millis(); //send PLX packet on Tx pin every 100ms
//Pdelta = P1 - P0;
//if (Pdelta >= 100)
// P0 = P1;
// PLXpacket[5] = ethanol_int; //set data byte in PLX packet to E%
// Serial.write(PLXpacket, 7);
//TRAC switch doubleclick
TRAC_buttonMonitor = digitalRead(6);
switch (TRAC_buttonState)
case 0: //inactive
if (TRAC_buttonMonitor == LOW) // button pressed
digitalWrite (10, HIGH); //Transistor on
TRAC_buttonState = 1; //increment state
break;
case 1: //check for release
if (TRAC_buttonMonitor == HIGH) //if button released
TRAC_buttonCounter = millis(); //start counter
TRAC_buttonState = 2; //increment state
break;
case 2: //wait for doubleClick
if (TRAC_buttonMonitor == LOW && (millis() - TRAC_buttonCounter) > debounce && (millis() - TRAC_buttonCounter) < doubleClick) //second click registered
TRAC_buttonState = 3; //increment state
else if ((millis() - TRAC_buttonCounter) > doubleClick)
digitalWrite (10, LOW); //Transistor off
TRAC_buttonState = 0; //reset state
break;
case 3: //doubleClick made
if ((millis() - TRAC_buttonCounter) > longClick)
break;
case 4: //initialize after delay by default
if (millis() > TRAC_initializeDelay)
TRAC_buttonState = 3; //set state to doubleClick
break;
| The Following User Says Thank You to ztan For This Useful Post: | solidONE (06-02-2016) |
#49 |
Drives: Toyota 86
Cranking Compensation v.3
The delay in the Arduino sensor had me cranking with ethanol in the tank with the unit sending E0 for a short while (usually whilst cranking). This made me think that the IAT compensation was unable to generate a positive compensation. I found the error in the logs and have modified the Arduino code to boot with a value restored.
I have changed the cranking compensation code v.1 to work off E0 cranking tables and apply correction that are close to Wayno's cranking values (FF_Multiplier is squared so that at E85, at E85 FF_Multiplier of 1.4 becomes a FF_Cranking of 2). This code works well with the changes to the Arduino code. Cranking with Arduino Flex unplugged (E0) Cranking with Arduino Flex plugged (E75 in tank) Code:
000B9870 FlexFuel_Cranking_Comp: ; CODE XREF: Cranking_Compensations 000B9870 ; Cranking_Compensations_0 000B9870 ; DATA XREF: ... 000B9870 4F 22 sts.l pr, @-r15 ; Store System Register Long 000B9872 F4 48 fmov.s @r4, fr4 ; r4=ECT 000B9874 D2 18 mov.l #Pull_2D_A, r2 ; Move Immediate Long Data 000B9876 D4 1A mov.l #Ethanol_Cranking_Comp_Table, r4 ;Move Immediate Long Data 000B9878 42 4B jsr/n @R2 ; Jump to Subroutine with No delay slot 000B987A D4 0F mov.l #RAM_FF_Crank_Comp, r4 ; Pull_2D_A ; Move Immediate Long Data 000B987C F5 9D fldi1 fr5 ; Floating-point load immediate 1.0 000B987E D6 0B mov.l #RAM_Flex_Fuelling_Multiplier, r6 ; Move Immediate Long Data 000B9880 F4 68 fmov.s @r6, fr4 ; Floating-point move single precision 000B9882 F4 42 fmul fr4, fr4 ; FF_Mult^2 000B9884 F4 51 fsub fr5, fr4 ; FF_Mult^2-1 000B9886 F5 4E fmac fr0, fr4, fr5 ; 1+(Crank_Comp*(FF_Mult^2-1)) 000B9888 F0 5C fmov fr5, fr0 ; 1+(crank_comp * (FF_Mult - FF_Mult_Max)) 000B988A F4 0A fmov.s fr0, @r4 ; Floating-point move single precision 000B988C 4F 26 lds.l @r15+, pr ; Load to System Register Long 000B988E 00 6B rts/n ; Return from Subroutine with No delay slot 000B9890 ; --------------------------------------------------------------------------- 000B98D8 00 01 13 88 off_B98D8: .data.l Pull_2D_A ; DATA XREF: sub_B97C0 Last edited by ztan; 12-18-2015 at 07:51 PM. |
#50 |
Drives: Toyota 86
Fuel Consumption Display
This code simply multiplies the value that is returned from the Display multiplier table by the FlexFuel Multiplier (E0=0, E85=1.4).
Stock code A01G: Code:
ROM:0003F6D2 FF 9E fmac fr0, fr9, fr15 ROM:0003F6D4 D4 4A mov.l #Table_Fuel_Multiplier_Display_Offset, r4 ROM:0003F6D6 D2 3B mov.l #Pull_2D_A, r2 ROM:0003F6D8 42 0B jsr @R2 ; Pull_2D_A ROM:0003F6DA F4 FC fmov fr15, fr4 ROM:0003F6DC 02 80 88 F8 movi20 #RAM_Fuel_Multiplier_Display_Offset, r2 ROM:0003F6E0 32 F1 30 01 fmov.s fr15, @(4,r2) ROM:0003F6E4 F0 F2 fmul fr15, fr0 ROM:0003F800 00 0B 20 24 off_3F800: .data.l Table_Fuel_Multiplier_Display_Offset ROM:0003F800 ; DATA XREF: sub_3F674 Code:
0003F6D2 FF 9E fmac fr0, fr9, fr15 ; PI volume + GDI volume 0003F6D4 D2 4A mov.l #FlexFuel_Display, r2 0003F6D6 42 0B jsr @R2 ; FlexFuel_Display 0003F6D8 F4 FC fmov fr15, fr4 0003F6DA F0 42 fmul fr4, fr0 0003F6DC 02 80 88 F8 movi20 #RAM_Fuel_Multiplier_Display, r2 0003F6E0 32 F1 30 01 fmov.s fr15, @((RAM_Fuel_Volume_Display - RAM_Fuel_Multiplier_Display),r2) 0003F6E4 F0 F2 fmul fr15, fr0 0003F800 00 0B 98 90 off_3F800: .data.l FlexFuel_Display ; DATA XREF: sub_3F674 000B9890 FlexFuel_Display: ; CODE XREF: sub_3F674 000B9890 ; DATA XREF: sub_3F674 000B9890 4F 22 sts.l pr, @-r15 000B9892 02 10 13 88 movi20 #Pull_2D_A, r2 000B9896 D4 17 mov.l #Table_Fuel_Multiplier_Display_Offset, r4 000B9898 42 4B jsr/n @R2 ; Pull_2D_A 000B989A D4 04 mov.l #RAM_Flex_Fuelling_Multiplier, r4 000B989C F4 48 fmov.s @r4, fr4 000B989E 4F 26 lds.l @r15+, pr 000B98A0 00 6B rts/n 000B98AC FF F8 D4 14 off_B98AC: .data.l RAM_Flex_Fuelling_Multiplier 000B98AC ; DATA XREF: sub_B97C0 000B98F4 00 0B 20 24 off_B98F4: .data.l Table_Fuel_Multiplier_Display_Offset 000B98F4 ; DATA XREF: sub_B97C0 |
#51 |
Drives: Toyota 86
Updated Arduino Circuit and Flex sender code
A couple of issues sorted out:
1. PLX display died and I didn't figure out for a while until I read the iMFD serial chain notes again carefully - the two data bytes only use the first 6 bits of each and the last 2 need to be "00". Arduino code has been updated to send data in this format and the display works properly. 2. Occasionally, the traction control would switch back on again, usually under hard acceleration. I suspect due to noise on the circuit; went back and made the power supply more robust (caps not shown on circuit below), added filtering to the NPN transistor, and reduced the B-E current to reduce the chance of false noise switching it on. Now traction control stays off at all times. 3. Increased filtering capacitance on the output line to the ECU to reduce sender noise. 4. Ethanol moving average gets stored in EEPROM every 5 minutes rather than every cycle and is the first thing to get sent out when booting the arduino in order to reduce the time a flex signal is available to the ECU. Code:
//V_out pin 3 - 0-5V output through 1.8K resistor with 100uF capacitor to ground
//Input switch on pin 6 - pulled up to 5V through 3.3K resistor + 3.3uF capacitor.
#include <EEPROM.h>
//FlexFuel sensor
double sum = 0;
int count = 0;
//EEPROM store
int EE_V_addr = 0;
long Elast, Enow, Edelta;
//PLX data
long Plast, Pnow, Pdelta;
//0x80 Start byte
//0x40 Stop byte
int debounce = 20;
int longClick = 3000;
int TRAC_initializeDelay = 5000;
void setup()
pinMode (6, INPUT);
EEPROM.get(EE_V_addr, V_out_avg); //load last V_out_avg
Elast = millis();
Plast = millis();
void loop()
count = count + 1;
if (count > 24)
sum = 0;
count = 0;
if (ethanol > 100)
ethanol = 100;
if (ethanol < 0)
ethanol = 0;
V_out_avg = V_out_avg + (0.1 * (V_out - V_out_avg)); //V_out_avg as moving average
//Store EEPROM data every 5 minutes
Enow = millis();
Edelta = Enow - Elast;
if (Edelta >= 300000)
Elast = Enow;
EEPROM.put(EE_V_addr, V_out_avg ); //store V_out_avg to EEPROM
//PLX data packet
Pnow = millis(); //send PLX packet on Tx pin every 100ms
Pdelta = Pnow - Plast;
if (Pdelta >= 100)
if (ethanol_int > 63) { //PLX iMFD only uses 6 LSB bits, 2 MSB must be 00 in each byte
Plast = Pnow;
PLXpacket[4] = 0x01;
int ethanol_int_LSB = ethanol_int - 64;
PLXpacket[5] = ethanol_int_LSB;
else {
Plast = Pnow;
PLXpacket[4] = 0x00;
case 0: //inactive
break;
break;
break;
break;
break;
| The Following 6 Users Say Thank You to ztan For This Useful Post: | DustinS (02-22-2016), elBarto (02-20-2016), freerunner (02-20-2016), keen as (02-21-2016), solidONE (06-02-2016), tato.valverde (02-22-2016) |
#52 |
Drives: 2013 FRS
I'm testing ztan's FlexFuel and Speed Density code in my our turbocharged shop car right now. It works brilliantly. You guys are going to be pumped.
| The Following 11 Users Say Thank You to Shiv@Openflash For This Useful Post: | BRZ_HaVoKx (04-16-2016), DustinS (06-02-2016), D_Thissen (03-01-2016), freerunner (03-05-2016), JonAvalon (03-01-2016), keen as (03-02-2016), phrosty (03-02-2016), solidONE (06-02-2016), tato.valverde (03-02-2016), WRBrzRX (03-04-2016), ztan (03-05-2016) |
#53 |
Drives: gt-86 2013
Just wanted to give ztan a big thank you for all the great work he has done for shiv and all of the OFT boosted users.Ztan has put a lot of work into developing the soft wear for us to use.Awsume job
#55 |
Drives: Toyota 86 GTS
So, just to confirm if people are buying commercial flex kits, they should go with the evap option, not rear 02?
Since I have all 10 cranking tables defined in the AU roms, my example roms have these values. 60 x1.05 50 x1.1 40 x1.2 30 x1.3 20 x1.7 10 x1.9 <= 0 x1.5
| The Following User Says Thank You to Wayno For This Useful Post: | solidONE (06-02-2016) |
#56 |
Drives: 2015 HL FR-S
Wow amazing job! I wish I could know the E lvl of our fuel here. I can't wait =D
[||•]=(86)=[•||] 2015 Hot Lava FR-S (Sold) OFT → My non sensor flexfuel UEL tune Plus other mods |
| Open source Over Boost Fuel Cut | ztan | Software Tuning | 19 | 02-15-2026 01:32 AM |
| Open Source Electric Supercharger | neutron256 | Forced Induction | 913 | 08-22-2021 05:16 PM |
| open source software question | GeeTee86 | AFRICA | 15 | 02-15-2015 06:52 PM |
| The Retrofit Source summer open house! | soundman98 | Southeast | 0 | 06-23-2014 08:41 PM |
| ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! | Visconti | Engine, Exhaust, Transmission | 356 | 05-20-2013 09:36 AM |
