#15 |
Drives: 2018 Golf R
The OEM setup in the BRZ looks like it puts more usable light on the road, and the kit in the FR-S glares quite a bit more then the BRZ projectors.
How far from the wall were the cars?
Parting out HERE
#16 |
Proud of FR Layout
Drives: 2013 Scion FR-S 6MT
wow, this is still going on, huh? Both headlamps seem to be more or less complete shit. Cheap headlamps for a cheap car, unless you are a pedant or a headlamp fetishist (seems like we have a few of both) a quick and dirty chinese ballast/bulb retrofit will be good enough for the majority of people. Its cheap, easy to install, easy to adjust, and provides more light than stock. Good enough. Done.
| The Following User Says Thank You to mattles For This Useful Post: | DarrenDriven (06-19-2012) |
#17 | ||
NW Region Moderator
Drives: FR-S No More
#18 | |
Registered you sir
Drives: 99 impreza coupe
| The Following 3 Users Say Thank You to chulooz For This Useful Post: |
#19 | |
Drives: Subaru
Here's some good reading for you in regards to lighting. http://www.danielsternlighting.com/t...nversions.html http://www.hidplanet.com/forums/show...uths-and-Myths http://www.hidplanet.com/forums/show...b-Crash-Course If you truly want to improve the lighting of your car, there are Halogen Infrared Reflecting bulbs that you can get that would actually increase the amount of lumens coming out from your FR-S's halogen lenses when compared to the HID kit that you have bought. Plus, this is done without all the harmful side effects of the HID kit. Sylvania Silverstars would probably be a great improvement for your car. If you continue to be adamant about having HID's, I recommend that you do a correct retrofit. If your response to this is that a complete retrofit is too expensive, I only have words that have been echoed throughout countless automotive forums: "You gotta pay to play." I hope you do the correct thing by taking the kit out and performing a complete retrofit. You already spent $25k on the car, what is another $800. To put things into perspective, $800 is only 3% of what you paid for the car. |
| The Following 2 Users Say Thank You to engee For This Useful Post: | civicdrivr (06-19-2012), Surok (06-21-2012) |
#20 | |
NW Region Moderator
Thanks for the links, I am going to read them over tonight when I have more time. By the way, I went with the Silverstars on my Jeep Wrangler Unlimited about a year ago because those housings would not convert to HIDs well. The Silverstars were a HUGE disappointment and I couldn't tell them apart from the bulbs that came from the factory lighting that I pulled out. On top of that, one bulb burned out after a few months and when I went to return it they pointed out on the box that those bulbs have a VERY SHORT life expectancy. This reminded me of the value of an HID conversion. I payed about the same for my HID upgrade and the life span is much longer (same brand in my Ram 1+ years, and in my Buell motorcycle for ~3 years)
#21 |
Site Moderator
Drives: Stuff
Couple of posts removed. Keep it clean and focused on the topic at hand please.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#22 |
Drives: 2018 Golf R
Quite frankly, you can do a retro for half that. The car already has projectors in it, all thats needed is a new bracket to drop HID projectors in.
TSX/S2k/RX300 projectors can be had for $150-300. A set of Phillips 85122+ bulbs are another $80. You already have ballasts but you'd need a converter for the ignitor ($30 IIRC). Sheet of metal from the hardware store for the brackets is about $5. Another $5 for hardware, and thats being generous. A few hours lining everything up and youre done. Believe me, if you use good projectors (S2k, RX300s), youll look back at the stock projector and wonder why you even messed with it. There is no small improvement. There is a HUGE difference in the optics of a well designed HID projector vs a well designed halogen projector running a PnP HID kit. This is not regurgitated forum talk from me, this is actual experience. Im running Silver Star Ultras until I can finally decide what projector I want to swap in, and the difference between them and stock was quite noticeable. The one question I have is whether or not the stock wiring is stout enough to handle the power demands of an HID kit. Typically, Id say to use a relay harness straight off the battery, but is the stock wiring the same as the BRZ which has an HID system stock?
Parting out HERE
#23 | |
Drives: Subaru
In regards to the Silverstars, that was my fault. It's been a while since I talked about lighting. I still stand by the Halogen Infrared Reflecting (HIR) bulbs. Here are some stats about HIR bulbs (notice the increase in lumens): http://www.hirheadlights.com/stats.htm The sylvania silverstars are on the left. HIR bulb on the right: ![]() Here is a photo of the light output compared to a Sylvania Silverstar. The HIR light is on the right, and the Silverstar is on the left. (NOTE: In the picture with the Syl. Silverstars on, the steering wheel is covering up the indicator for the highbeams.) ![]() Once again, I hope you take out your kit. My personal opinion is that I do not like getting blinded by these kits, especially when these kits are in trucks where the headlight is higher up and will easily blind normal size passenger cars. I appreciate when things are done correctly on cars and I normally do not care what you do to your car until said mod affects other people. |
| The Following 2 Users Say Thank You to engee For This Useful Post: | civicdrivr (06-20-2012), Dadhawk (06-20-2012) |
#24 | |
Drives: Scion FantasticRoad-Sex
#25 |
And do they make those bulbs for our cars?
#26 |
Drives: Subaru
The bulb sizes for the FR-S:
Low Beam (Halogen): H11 High Beam (Halogen): 9005 If you really want an increased light output in lumens, my recommendation would be to : Low-Beams = H11 size 55W Ultra High Efficacy Plus 50 some good brands are: Philips VisionPlus, Osram SilverStar, Narva RangePower+50, Tungsram Megalicht (whatever bulb you buy, try and get the european bulb) High-Beams = HIR 9011 You will need to to some slight modification here. It is super simple though Here's a DIY from another forum: http://www.iwsti.com/forums/gr-exter...onversion.html This is a great alternative to PnP HID kits and will provide a ton more light than any PnP HID kit. |
| The Following 4 Users Say Thank You to engee For This Useful Post: |
#27 |
Proud of FR Layout
I agree with you 100%, but I think you are giving the stock projectors too much credit, they dont seem to be designed very well at all.
| The Following User Says Thank You to mattles For This Useful Post: | civicdrivr (06-20-2012) |
#28 |
Drives: 2012 WRX Sedan
You guys need to test out some H9 Halogen bulbs, to see if it works like it does in the WRX...
It's almost a x2 lumen upgrade for $30. |
| HID Conversion DIY | loong | DIY (Do-It-Yourself) Guides | 55 | 06-27-2014 06:27 PM |
| leather seat conversion | stalon320 | Interior Parts (Incl. Lighting) | 6 | 07-20-2012 04:36 PM |
| Colour temperature of HIDs? | proficience | AUSTRALIA | 17 | 06-18-2012 11:12 PM |
| LED Conversion | [M] | Cosmetic Modification (Interior/Exterior/Lighting) | 38 | 06-18-2012 08:44 PM |
