Old 06-06-2016, 08:50 AM   #3949
OkieSnuffBox
Drives: '23 BRZ Limited
Originally Posted by Pat View Post
Having rotors turned might cost $20 a piece. That's way cheaper than buying new rotor rings.
I've never heard of having 2-piece rotors turned. Is this even a thing?
The heat checking is from thermal fatigue, I wouldn't think having them turned is helpful, from a safety standpoint.
Old 06-06-2016, 10:17 AM   #3950
Pat
Pat's Avatar
Drives: 2023 BRZ
I've never heard of it either. I'd be surprised if it weren't possible, as I can't think of any reason for that. Of course, there may be something I haven't considered. I've never owned two piece rotors.
Old 06-06-2016, 10:55 AM   #3951
Icecreamtruk
Drives: Track preped NA FRS
Aero questions. Im going to get a wing for my car, the rear is really loose, its fast but its scary driving specially on long sweepers. I dont want to turn the oversteer into understeer and my suspension isnt adjustable (its stock actually). Should I worry about a front splitter or air dam at first or should I just try the wing by itself? Im affraid the wing might lift the front without any aero that transform all of that happy tail oversteer into understeer.
Also, im not only doing it because I find it scary, im really chicken anyways so that probably wont change but I think I can find more time if I can have some more late apexes with early gas applications. I find myself having to give up on some late apexes because the rear will slide out at turn in, I can probably trail brake some more too, currently lifting off brakes completely halfway between turn in and apex, I could probably trail brake all the way to the apex with a wing, allowing me to brake later.
Edit: alignement is -3 camber up front, -2 camber rear, 0 toe all around.
Edit 2: more info, 28k miles on stock dampers with around 15 track days (2-3 hours of track time per day). Surface is tarmac not asphalt so it is smooth, but no rubbery smooth. Tires are 225/45/17 Maxxis RC1. So far I have tried 38, 35 and 32 hot pressures on them. 32 produced the fastest times and better turn in.
Icecreamtruk is offline   Reply With Quote
Old 06-06-2016, 11:03 AM   #3952
Pat
Pat's Avatar
Drives: 2023 BRZ
"...the rear is really loose..."
"...my suspension isnt adjustable (its stock actually)..."
Something doesn't add up. Before getting a wing figure out what is wrong with the car right now. If you're on stock suspension and the car is really loose there is something that needs to be address before aero.
Old 06-06-2016, 11:46 AM   #3953
Icecreamtruk
Well suspension is stock but it is a 2013 FRS (way softer springs up front than rear) and the alignement is far from stock. I will try dialing in more rear camber and see how that helps but since it isnt something I can adjust at the track... well... its hard to get it right.
Old 06-06-2016, 12:11 PM   #3954
Pat
Pat's Avatar
Drives: 2023 BRZ
You might get better feedback here if you share your alignment specs.
The Following User Says Thank You to Pat For This Useful Post:
Icecreamtruk (06-06-2016)
Old 06-06-2016, 12:31 PM   #3955
Icecreamtruk
edited post to show the information, -3 camber front, -2 rear, 0 toe all around.
Old 06-06-2016, 12:40 PM   #3956
dp1
driving smoother faster
Drives: Sold
Camber? Ride height - are you slammed if you say that alignment is far from stock? Miles on your oem dampers (street vs track)? Tire type/size/age/miles/thread left/hot pressures? Tires same type/size front and back? Rim size front/rear? Number of hours you've had on track/ax to date? Road surface smooth in the sweepers where you brake loose?
Something could be shot for you to experience sudden oversteer or you may simply find oversteer uncomfortable to deal with. You may get better advice if you offer more information.
dp1 is offline   Reply With Quote
The Following User Says Thank You to dp1 For This Useful Post:
Old 06-06-2016, 01:40 PM   #3957
Icecreamtruk
Suspension is stock, so stock ride height? How can I be slammed with stock suspension?
It is not sudden oversteer, its stable, predictable, always there at every turn in oversteer. The car has no understeer on it at turn entry, at all, ever, it goes straigh to oversteer. The only way I can kind of experience understeer is at corner exit on slow corners if I stat accelerating too soon.
Old 06-06-2016, 01:52 PM   #3958
Pat
Pat's Avatar
Drives: 2023 BRZ
If it happens at every turn you need to address something other than aero. That will only make a significant difference in high speed turns.
Old 06-06-2016, 02:02 PM   #3959
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Try leaving the spare and accompanying junk in the trunk. Cheaper than a wing and gives "downforce" on the rear. Also, I haven't done it, but the pedal dance might help because it will turn off the e-differential. In the end, the light rear end is a blessing because, on every single sweeper, we get to play with steering by throttle. You can also stay in a gear higher than optimal. This will limit your torque and make throttle control easier. An upgraded LSD should help, too. I think a wing is a later mod, not an earlier one.
Try going into a corner too fast. You'll understeer, at least at first.
The Following 2 Users Say Thank You to EAGLE5 For This Useful Post:
CSG Mike (06-06-2016), Icecreamtruk (06-06-2016)
Old 06-06-2016, 02:15 PM   #3960
Icecreamtruk
Hmm havent though about adding weight and seeing what the differences are, I will try it out next time just to get an idea at least.
For the pedal dance, I have been doing it, I dont think the electronics would allow for so much slip angle even in "off" mode.
Old 06-06-2016, 02:24 PM   #3961
dp1
Drives: Sold
You've spent some time on track and your alignment and pressures look ok. FR-S has some oversteer built from the factory. Heard that RC1 like clean lines so smooth inputs near the limit can make a difference. Does it behave the same on both left and right turns? May be worth having somebody familiar with twins inspect the suspension, also a more experienced twin driver take a few laps with your car on track, if that's an option. To each their own but I wouldn't touch aero before upgrading dampers, and perhaps some bushings if you want a more track focused car.
Old 06-06-2016, 02:37 PM   #3962
Icecreamtruk
Been asking in some other local forums and the answers are similar to yours. My fastests laps were indeed those were there was no sliding at all, just clean turns with very little slip and tire noise. It does the same on right and left and the car was inspected a few weeks prior to the event by a local shop that specialises on race and rally cars and everything was perfect. I guess its just the built-in oversteer and the maxxis which dont really like oversteer playing agaisnt me. I will try nittos towads the end of the season and see if those play better with my setup. In the meantime I think I will add a touch of toe-in in the back.
Thanks everyone for the input, seems like aero is not really the solution yet.
The Following User Says Thank You to Icecreamtruk For This Useful Post:
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
