Old 06-02-2016, 01:54 PM   #1
kev60625
Drives: 2013 WRB Subaru BRZ
Who has had to change their pinion bearings with final drive mod??
Hello,
I am trying to change my final drive gear to a 4.556 and am wondering who has had to change their pinion bearings? I see it can be re-used and wondering if I should just go that route. My car is a 2013 with 24k miles if that matters, Thanks!
The price difference with getting the pinion bearing is huge, it would add $120 to the total
kev60625 is offline   Reply With Quote
Old 06-02-2016, 02:43 PM   #2
Icecreamtruk
Drives: Track preped NA FRS
Well, I can see we dont have the same idea of what huge means (120 huge? really?). I had to get mine changed for a 4.88 final drive. I know someone with the 4.65 from MFactory who didnt. So there`s that, I guess it depens on who installed it and what kind of final drive you are using.
Icecreamtruk is offline   Reply With Quote
Old 06-02-2016, 03:07 PM   #3
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
Sometimes the pinion bearing comes off just fine but we typically replace them anyway mostly for peace of mind. It's a lot of work and money to go back through there and replace it again if you find out shortly after break in that it's failing.
Gear_One_Performance is offline   Reply With Quote
Old 06-02-2016, 09:25 PM   #4
mrk1
Drives: Sterling BRZ Ltd
Its a "replace while your in there" item
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
Gear_One_Performance (06-03-2016)
Old 06-02-2016, 11:38 PM   #5
kev60625
Got it guys. I was just under the impression it wasn't always necessary if it comes off fine, only from reading the final drive threads on this site. I will for sure get a new oem set to go with it. Thank you all
Old 06-03-2016, 01:12 PM   #6
mrk1
There is your problem, the DIY is a pretty shade tree mechanic way to go about it. Does it work, maybe. Is there a more professional way to do it, yes. Its very important to note that not all brand's and ratio's install the same, primarily when it comes to setting pinion height.
The Build Thread
How-To: Change final drive ratio (relatively) cheaply PantsDants Engine, Exhaust, Transmission 84 03-22-2020 03:58 PM
Mfactory Final Drive Ring and Pinion Crossover Auto Engine, Exhaust, Transmission 87 05-26-2017 02:21 AM
4.556 final drive with TRD gear ratio change - good or bad idea? nzer Engine, Exhaust, Transmission 51 12-26-2015 09:15 PM
3.9 final gear - ring and pinion PantsDants Engine, Exhaust, Bolt-Ons 5 11-08-2013 03:06 AM
Change FD ratio to 4.56 by changing only pinion peachch Engine, Exhaust, Transmission 1 08-31-2013 01:25 PM
