Old 05-13-2016, 03:17 PM   #43
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
Originally Posted by dustmann View Post
That is the wrong (NPT) galley plug for the innovate sender. You need the silver (PT) adapter.
Link: http://www.rallysportdirect.com/shop...il-galley-plug
See my post #8 for the autometer adapter for the pressure sender (p/n 2269). I would not recommend using a t adapter as it may break over time and create an oil leak. The gauge can be programmed to indicate low pressure.
I mean if you don't get a badly built t fitting it will be just as solid/resistant to leaks as the actual sensor?!? You know they make them in oter material than brass right? If you're worried about it breaking or cracking over time just get one that's built from a different material (chromoly, stainless, hell titanium if you really want to)
fumanchu1 is offline   Reply With Quote
Old 05-13-2016, 07:42 PM   #44
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by ChrisD View Post
But I don't know where to find a "power line with ignition on" and an "illumination power line" as I've never done anything with car electronics before.
I tapped all the wires I needed from the back of the factory radio.
Suggest you download the factory service manual and browse through it.
http://www.ft86club.com/files/BRZwiringi.pdf
Page 316 onward. I'm going to disassemble my Blitz setup in the next week or so, I'll snap some photos of how it's wired up.
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
ChrisD (05-16-2016), Initial_RD (06-08-2016)
Old 05-15-2016, 09:45 AM   #45
Teclis
Marine Electrician
Teclis's Avatar
Drives: Toyota TRD86, 2014
Originally Posted by fumanchu1 View Post
why don't you just get an m18x1.5 to 1/8 adapter and tap into the oil galley plug like you should?
For pressure only, you could also buy a T adapter disconnect factory sensor(green wire) and replace with the T adapter and both sensors plugged (can't also do temp here as it is not in the flow).
Hi
Well I have not installed the innovate pressure/temp sensor anyway, and got my self a TRD oil temp gauge instead so i put my temp sensor in the oil gallery.
I'll use the innovate for a future track car or something
Teclis is offline   Reply With Quote
Old 05-16-2016, 10:20 AM   #46
ChrisD
ChrisD's Avatar
Drives: GT86
Got mine installed the other day and we ended up going off the wires that go into the back of the clock. The red/black wire is constant power, green/white is ignition on, and black/yellow is ground. We didn't bother with the dimmer but might look into that in future if it's too bright at night.
My GT86 build so far:
AVO Stage 4 Turbo, Carrillo forged con rods, 10:1 CR Carrillo pistons, AVO 3 inch turbo back exhaust, Helix clutch, TheDriveShaftShop drive shafts, lightweight flywheel, NamelessPerformance hydraulic hand brake, KW V3 coilovers... and lots of other little bits
ChrisD is offline   Reply With Quote
The Following User Says Thank You to ChrisD For This Useful Post:
Old 06-02-2016, 02:17 PM   #47
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Anyone try to install the Perrin Oil Temp Adapter with the Innovative MTX Dual Oil Temp / Oil Pressure gauge?
I have the Perrin Oil cooler, so the temp adapter would just be a direct swap for that spacer, but the problem lies in the Oil Temp sender - it's too long for the depth of the adapter. Any thoughts?
http://perrinperformance.com/i-22245...e-adapter.html
http://www.innovatemotorsports.com/p.../MTXD.php#3852
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 06-02-2016, 07:17 PM   #48
mav1178
mav1178's Avatar
Suggest you take a look at another kit w/ multiple temp ports for reference.
Blitz: https://www.flickr.com/photos/137904...h/23290625593/
My install:
http://www.ft86club.com/forums/showthread.php?t=99441
For your reference, the Blitz kit allows the individual elements to be purchased separately. However, you may have to redo your lines.
Including the port on the spacer portion, there are a total of 6 1/8PT sensors that can be mounted on the Blitz setup.
-alex
Old 06-07-2016, 02:14 AM   #49
Arcade_West
Drives: Subaru BRZ
-alex
Did you end up taking some pics of the wiring set up?
Arcade_West is offline   Reply With Quote
Old 02-13-2017, 12:21 AM   #50
HotlavaFRSGT86
Keep ICE alive+manuals
HotlavaFRSGT86's Avatar
Drives: 2015 Hot Lava 6 spd
Oil gauge
I bought the Beatrush sandwich plate as its one of only 2 i think that will clear the lip on our oil filter flanges, works great, no leaks yet. I have the Defi oil pressure gauge installed in the ATI vent pod. Follow this install guide, its rock solid http://theattack.rallysportdirect.co...r-ssubaru-brz/
If your not first your last - Ricky Bobby
HotlavaFRSGT86 is offline   Reply With Quote
The Following User Says Thank You to HotlavaFRSGT86 For This Useful Post:
CHMBRZ (04-13-2017)
Old 02-13-2017, 12:23 AM   #51
HotlavaFRSGT86
Gauge
Would'nt let me upload 2 pics at a time, so heres a pic of the Defi gauge in my air vent. Looks good in there too and very responsive, should be for what they cost, lol, but u got to pay for quality.
Old 04-04-2018, 05:06 PM   #52
srscion
srscion's Avatar
Drives: 2016 FRS
Originally Posted by Lunatic View Post
Here's my gauge pod I made for 2 1/16th inch gauges.
Is your oil pressure reading still low with that gauge?
srscion is offline   Reply With Quote
Old 04-04-2018, 11:32 PM   #53
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Not with the mechanical gauge. It did with the digital gauge.
Lunatic is offline   Reply With Quote
Old 10-22-2019, 08:57 AM   #54
Antisocialspeed
Drives: 2013 FRS
Bringing thread back with some questions regarding oil press gauge, which I'm installing due to other issues and wanting to keep an eye on oil.
I snapped a brass oil galley adapter at 27 ft/lbs, using my craftsman torque wrench. Only mentioning the brand as it is more accurate than my harbor freight for lighter torque numbers. I read that 27 was OEM spec.
1.) Anyways, because of this I'm a little concerned with long term use, and removal of the brass fitting down the road. Has anyone had issues removing the brass oil galley plug after it has been installed for a period of time?
2.) There are steel oil galley plug adapters, any issues running these? Good bad?
Antisocialspeed is offline   Reply With Quote
Old 10-22-2019, 04:18 PM   #55
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That's a bit much, 8-10 lbs is plenty. Next time you need a torque spec just google the fastener, it will usually get you in the ball park.
https://www.air-way.com/Assets/n2upl...structions.pdf
Old 10-22-2019, 04:49 PM   #56
Grady
Grady's Avatar
Never use brass or aluminum in a high vibration area. (AKA screwed into a block) Steel is always good.
Oil Pressure and Temp Gauge Install BokChoiTV Cosmetic Modification (Interior/Exterior/Lighting) 14 12-29-2015 06:19 PM
Defi Oil Pressure Gauge and Cravenspeed Flexpod Gauge Mount Install and Review Tye300 Cosmetic Modification (Interior/Exterior/Lighting) 10 05-22-2015 12:48 PM
DIY request: Gauge install and wire routing mikepaul21 DIY (Do-It-Yourself) Guides 3 07-05-2014 12:43 PM
Plot your oil pressure vs temperature Gords_zenith Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-22-2014 06:09 PM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 04:29 PM
