Old 06-28-2015, 06:51 AM   #1
Teclis
Marine Electrician
Teclis's Avatar
Drives: Toyota TRD86, 2014
Question DIY Request: install Oil Pressure & Temperature gauge
Hi
First off I did but could not find what I'm looking for.
Does anyone have a DIY for where to place the Oil Pressure sensor & Temperature sensor?
Planning to get the mishimoto oil cooler, so I can't use a trd sensor plate.
And for Gauge I'm going with Innovate Oil Pressure & Temperature http://www.ft86speedfactory.com/mtx-...ture-1402.html
Pictures of where you mounted the sensors, and a description of what is needed for the job would be great!
Last edited by Teclis; 06-28-2015 at 08:42 AM. Reason: Fixed so there wont be any misunderstanding
Teclis is offline   Reply With Quote
Old 06-28-2015, 07:31 AM   #2
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Here's my gauge pod I made for 2 1/16th inch gauges.
Lunatic is offline   Reply With Quote
The Following 6 Users Say Thank You to Lunatic For This Useful Post:
8R6 (06-03-2016), GhostOp86 (07-24-2015), hmong337 (07-01-2015), juliog (06-28-2015), Teclis (06-28-2015), YamahaR86 (01-31-2019)
Old 06-28-2015, 08:42 AM   #3
Teclis
Marine Electrician
Teclis's Avatar
thanks, but I ment where you mounted the sensors
Old 06-28-2015, 09:48 AM   #4
nunonuna
nunonuna's Avatar
http://www.ft86club.com/forums/showthread.php?t=82414
nunonuna is offline   Reply With Quote
The Following User Says Thank You to nunonuna For This Useful Post:
Teclis (06-28-2015)
Old 06-28-2015, 09:57 AM   #5
armyoffoo
Drives: 2015 Scion FR-S
Find a sensor adapter for the oil galley plug on google:
M18x1.5 sensor adapter
Not sure if a Y adapter can fit in there with both sensors, but here's a post showing the plug location:
You can get oil temp through ODB2 port, really only need the pressure sensor.
armyoffoo is offline   Reply With Quote
The Following User Says Thank You to armyoffoo For This Useful Post:
Teclis (06-28-2015)
Old 06-28-2015, 10:20 AM   #6
Teclis
Marine Electrician
Teclis's Avatar
Yeah but the innovate gauge got both in one gauge
Old 06-28-2015, 10:37 AM   #7
nunonuna
nunonuna's Avatar
You can find extender for bulky sender unit.
Teclis (06-28-2015)
Old 06-28-2015, 12:49 PM   #8
dustmann
Drives: '14 WRB BRZ Limited
I have the exact same gauge mounted in my car. I'm using one of the block8head defrost vent dual pods. See here: http://www.ft86club.com/forums/showthread.php?t=66333
As for the installation, I used this as a guide: http://www.autometer.com/resources/i...uide_view/id/3
**edit 1/5/16 I had the incorrect part number listed for the autometer adapter... This has been corrected
Note for the innovate pressure sender, you WILL need the autometer adapter (**2269) if you're going to install it in the stock sending location (what I did). I used a galley plug and gasket from rallysport direct, which worked perfectly for the temp sensor. (the innovate temp sensor is threaded for PT, which matches the galley plug at RSD) http://www.rallysportdirect.com/cata...eywords=galley
dustmann is offline   Reply With Quote
The Following 2 Users Say Thank You to dustmann For This Useful Post:
Asian (07-17-2019), Teclis (06-29-2015)
Old 06-28-2015, 01:04 PM   #9
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
if your patient give me 2-3 weeks i can make a guide for the install..
i will be using innovate oil temp/pressure gauge which i sort of already installed
but will re-adjust to make fit for my turbo
and a AEM FAIL SAFE gauge as well
I'm using an ATX vent Pod Gauge
and block8head vent defrost gauge
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
The Following User Says Thank You to BRZtoni For This Useful Post:
Teclis (06-28-2015)
Old 06-28-2015, 05:56 PM   #10
Teclis
Marine Electrician
Teclis's Avatar
Sounds awesome! And yeah I got time.. stuck at sea until the end of July
I'm also going to use a block8head defroster pod for my innovate oil temp/pressure gauge
Old 06-28-2015, 11:02 PM   #11
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Note for the innovate pressure sender, you WILL need the autometer adapter (2280) if you're going to install it in the stock sending location (what I did). I used a galley plug and gasket from rallysport direct, which worked perfectly for the temp sensor. (the innovate temp sensor is threaded for PT, which matches the galley plug at RSD) http://www.rallysportdirect.com/cata...eywords=galley
but if u install in factory location its rt by the OEM pressure switch which Innovate specifically says NOT TO DO....
that leaves just the galley plug and pressure would go there, but then temp is left out
lbroskee is offline   Reply With Quote
Old 06-28-2015, 11:29 PM   #12
dustmann
The innovate pressure sender is too large to fit in the galley location under the alternator, I didn't have a relocation kit, so I replaced the factory pressure switch with the innovate sender and it's been working fine for the few months I've had it installed.
The manual for the gauge says not to install it next to the oil pump, or to the pressure switch itself. It didn't say anything about replacing the switch
The Following User Says Thank You to dustmann For This Useful Post:
Teclis (06-29-2015)
Old 06-28-2015, 11:42 PM   #13
lbroskee
lbroskee's Avatar
No cel or issues with the OEM light it controls? And what did u do about the connector that plugs into it, just tie it back?
Old 06-28-2015, 11:48 PM   #14
dustmann
Yes the switch is normally grounded, so disconnecting it doesn't trigger a CEL or the pressure light on the dash. Note that you will lose that functionality (but it is replaced by your gauge) And yes, i just zip tied it out of the way.
Oil Pressure and Temp Gauge Install BokChoiTV Cosmetic Modification (Interior/Exterior/Lighting) 14 12-29-2015 06:19 PM
Defi Oil Pressure Gauge and Cravenspeed Flexpod Gauge Mount Install and Review Tye300 Cosmetic Modification (Interior/Exterior/Lighting) 10 05-22-2015 12:48 PM
DIY request: Gauge install and wire routing mikepaul21 DIY (Do-It-Yourself) Guides 3 07-05-2014 12:43 PM
Plot your oil pressure vs temperature Gords_zenith Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-22-2014 06:09 PM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 04:29 PM
