Old 05-30-2016, 07:05 PM   #3137
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
Originally Posted by DigitalVeil92 View Post
What do you mean by "not ideal?" Are we talking just the speedometer being thrown off, or are there some performance impacts as well?
Also, just from looking around, I've seen a few people talk about needing to cut/trim something they call a bumper tab in the rear wheel well to make some larger tires fit? Can anyone tell me more about that?
Well, speedometer is one thing, your car will also be 1.8cm higher of the ground than with the stock wheels, aswell as having a 1.8cm higher tireflank giving it a more "offroadish" look.
There is ofc performance impact on this (accelleration and cornering) however its in the lower % range, so I doubt you will actually notice a big difference.
No clue about the "bumber tab" thing, 255 will fit in the rear with no modifications
Killerbee is offline   Reply With Quote
Old 05-30-2016, 08:54 PM   #3138
swarb
255/40 is a size people run on 17's and is not ideal on 18's.
Stock 215/45-17 is about 24.6/24.7 inches tall. 255/40 is 26 inches tall. 25inches or so is a good size, +/- a half inch a so(2-3%).
26 inches is pushing it, it is a mustang(aka bigger car) size.
Performance impact, they will be taller and make your gearing longer, about 4%.
They won't rub because of width, more likely they will rub because of height.
Bumper tab is the area that connects the bumper to the rear fender/quarter panel.
You also might rub on the side markers up front.
Old 06-01-2016, 02:08 AM   #3139
RavenFish
Drives: 2016 Raven FR-S
Will I be able to fit 18 x 9.5 wheels on stock struts with lowering springs?
Wheels are
18x9.5
Offset 35
Tires:
225/45/18
Thanks
-Fish
RavenFish is offline   Reply With Quote
Old 06-01-2016, 02:35 AM   #3140
swarb
Wheels are
18x9.5
Offset 35
Tires:
225/45/18
Thanks
-Fish
Every car is slightly different.
9.5's are difficult on stock struts without major poke.
225/40/18 is a better tire size diameter wise. 225/45 are for 17's. Tires will be stretched quite a bit.
You may need a 3-5mm spacer up front.
Wheel will poke out quite a bit.
Clearance on a +38 9.5 is around 10mm on stock suspension.
+35 gives you 3 more mm.
BUT lowering gives you camber which takes that all away.
http://www.ft86club.com/forums/showp...postcount=2768
http://www.ft86club.com/forums/showp...postcount=2762
Will it fit? Probably with a spacer.
Will it fit good? Probably not.
Is it safe?
Old 06-01-2016, 12:06 PM   #3141
RavenFish
Is it safe?
I'm lowered on Sportline springs right now just to get rid of the wheel gap until I get coils, I don't really care about poke and I know it will be stretched a little, but do you think I will rub when I turn at full lock ? That's the only thing I don't want to happen
Old 06-01-2016, 12:47 PM   #3142
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Here are 9.5 all around on stock suspension with 235 tires. POKE MUCH?
http://www.ft86club.com/forums/showthread.php?t=11222
Old 06-01-2016, 02:06 PM   #3143
swarb
My reply to you was about width.
Now read my post #3138 about tire height. http://www.ft86club.com/forums/showp...postcount=3138
Go look up your tire height.
And then go outside with a ruler and figure out if that difference in height and clearance.
Soft suspension, combined with tall tires means your suspension would move more than a firmer setup(coilovers).
If you wanna look cool , you gotta take chances, or just buy coils and a correct tire and wheel size.
You are cutting it close with width and diameter.
Good luck.
Old 06-02-2016, 05:15 PM   #3144
CatalystPLUR
That Auto Guy
CatalystPLUR's Avatar
Drives: Ultramarine FRS
Looking at 18x8 +45 Raijin with
225/45 tires
Stock everything looking at coils for later but currently just looking at some new shoes
Will this rub on stock?
CatalystPLUR is offline   Reply With Quote
Old 06-02-2016, 06:07 PM   #3145
Leonardo
Country Boy 4 Life
Leonardo's Avatar
225/45 tires
Shouldn't rub. I have 18x8+45 with 245/35 front no rubbing. I would suggest a 225/40/18 over the 225/45, because the 225/45 is 1.35 inches taller than stock. Too much. The 225/40 is already a 1/2" taller, so it will help fill the gap and be closer to stock diameter. The rule of thumb is +/-%3 or less.
Tire calculator.
http://www.discounttire.com/dtcs/infoTireMath.do
Old 06-02-2016, 06:39 PM   #3146
CatalystPLUR
That Auto Guy
Tire calculator.
I messed up my tire size.... wanted a wider tire less tread I think im going 245/35 now that I realize my Mistake
Old 06-03-2016, 01:22 AM   #3147
Lastexile
Lastexile's Avatar
Drives: 2013 Firestorm FR-S
Just bought my FRS and I don't know much about sizing etc. I'm trying to learn which is why I'm here lol. I was looking at getting some new tires and rims so I guess My question is, would these fit?
Tires: Hankook rs3 255/35 r18
Rims: Advan Racing - GT 18x8.0 Offset:45 Bolt pattern: 5x100
If those don't fit then what would you guys recommend? Remember, I don't know much so I'm learning lol. Thanks in advance guys.
Lastexile is offline   Reply With Quote
Old 06-03-2016, 10:26 AM   #3148
Leonardo
Country Boy 4 Life
Leonardo's Avatar
245/35 is as big as I would go on an 18x8 +45. (This is what I have) It is so close to rubbing, the 255/35 won't fit, and look pinched. Don't do it.
The RS3 is also wider than normal. A 225/40 might fit best. Do you AutoX? If not, you may want another tire for longevity. It is soft and wears faster than other street tires.
Good luck!
Old 06-05-2016, 02:41 AM   #3149
Lastexile
Lastexile's Avatar
Good luck!
I don't AutoX. Sorry, I'm still very new to all of this. I drove a 2002 Chevy Cavalier before my FR-S .
So a 225/40 18x8.0 45 will be a good fit then? I want the off-set to be lined up with the sides if that makes sense. I don't want it to be really close to rubbing the wheel well. What tire would you recommend? I was looking at the Proxy T1 Sport. Would they be better?
Old 06-06-2016, 12:10 PM   #3150
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
Looks to be the same as @Leonardo but I am not sure if lowering will affect/how much @Leonardo is lowered. This was as close as I could get to stock radius: http://www.1010tires.com/Tools/Tire-...5R17/245-35R18
Enkei Ts-10
18x8
+45
245/35/18 either S-04s or PSS for the tires which don't seem to run super wide.
Lowered ~20mm on the RCE Yellows. ~-.5 camber in front, ~-2.5 camber in rear, with stock LCAs.
Thanks
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
