Old 05-31-2016, 12:31 PM   #1
Mr Miyagi
Drives: Blue Subaru Brz
4 bar map sensor on complete stock brz
Hi so I just but my brz back to stock. I had an ecutek tune with the ptuning turbo kit. I have not been able to find a stock map sensor and a new one is $300. I was wondering if I could just use an aftermarket 3 bar or 4 bar map sensor on a stick brz since they are about $100?
Mr Miyagi is offline   Reply With Quote
Old 05-31-2016, 01:57 PM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
Yes, you just need to adjust the MAP sensor scaling.
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-31-2016, 02:50 PM   #3
Mr Miyagi
map sensor scaling
Ok is this hard to do or should i just try and find a used map sensor. im pretty savvy with computers but i never messed with the tune. I just recenlty flashed a stock map back on to my ecu.
Old 05-31-2016, 04:20 PM   #4
steve99
Drives: FT86
you will need access to a flash system anf ecu rom editor if you have ecutek cable/licience ect you wll be able to do it
find the MAP multiplier and offset tables in the tune tables and change the two parameters to suit the MAP sensor,
o it might just be easier to get a used stock MAP sensor from an auto wreckers/recycler
Omni 2.5 Bar MAP
The OFT300 (Vortex supercharger) map uses the 2.5 BAR Omni and has CEL-P0068 disabled in the map
ok for 2.5 Bar OMNI MAP sensor ECUTEK scaling in BAR
Manifold Pressure Sensor multiplier in bar per volt. = 0.500
Manifold pressure sensor offset. Value is measured in bar. = 0.100
MAP Sensor voltage max = 5.0v
MAP sensor Voltage min = 0.0v
Omni 3 Bar MAP Sensor (Metric in Bar)
0.617 - MULTIPLIER
0.03 - OFFSET
scaling limits 0 - 4.75v
Omni 4 Bar MAP Sensor
Manifold Pressure Sensor Scaling - (imperial PSI)
Multiplier - 12.087
Offset - 0.168
Metric/Bar
bar/volt .833
offset (bar) .012
Manifold Pressure Sensor Limits - (CEL still comes on )
High Input CEL Above - 5.00v
Low Input CEL Below - 0.00v
Disable CEL P0103 and P0068
callisto (01-14-2026)
Old 05-31-2016, 05:03 PM   #5
Mr Miyagi
Omni 2.5 Bar MAP
0.617 - MULTIPLIER
0.03 - OFFSET
Multiplier - 12.087
Offset - 0.168
Metric/Bar
bar/volt .833
offset (bar) .012
Awesome thanks for your help!
Old 05-31-2016, 05:06 PM   #6
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
I'll trade you.
I'm pretty sure have an extra stock one. I'll trade you it for your 4 bar. If you'd like me to check. let me know.
Jaden
Jaden is offline   Reply With Quote
Old 05-31-2016, 06:01 PM   #7
Mr Miyagi
Jaden
ya i will buy it from you, i just sold the 4 bar with the turbo kit, so right now i have no sensors.
Old 05-31-2016, 06:19 PM   #8
Jaden
Road-hole
ok...
I'll stop by my ranch on the way home and make sure it's still on my other intake.
Jaden
WTB: Stock MAP sensor, and stock port injectors Agent_D Want-To-Buy Requests 2 05-25-2016 05:08 PM
WTB stock rear tophats or complete stock suspension s13kid989 Want-To-Buy Requests 3 10-09-2014 07:11 AM
WTB: Stock MAP Sensor, Stock Frontpipe, Stock Midpipe. Sterz Engine, Exhaust, Bolt-Ons 4 07-02-2014 09:22 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 06:39 PM
FS: Stock Wheels+Stock Tires+TPMS sensor Pin Flare Wheels and Tires 1 03-26-2013 11:07 AM
