Old 05-27-2016, 08:20 PM   #15
funwheeldrive
Originally Posted by Packofcrows View Post
Its basically a FRS with a TRD Intake/Exhaust haha
I think this refresh will impress a lot of people, including current owners. I feel like they spent a lot of time trying to really 1up the ND Miata.
Old 05-27-2016, 09:00 PM   #16
Ezio
Ezio's Avatar
Drives: 2022 BRZ
The power gain was by drag reduction via engine internals. They also changed the Findal Drive Ratio to 4.31 from 4.1, which either had a middling effect with the automatic transmission or they really didn't want to bother reprogramming it.
Ezio is offline   Reply With Quote
Old 05-27-2016, 09:03 PM   #17
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
I dont understand that. Whats it do? The final drive.
Old 05-27-2016, 09:07 PM   #18
Ezio
Ezio's Avatar
Drives: 2022 BRZ
The Final Drive is the last effective "gear" that a car will use to amplify torque or speed. Automatic transmissions have their TC (Torque Converter), which amplifies torque significantly on their own, so it would be redundant or detrimental to adjust the final value when you can't change the TC.
It's usually why manufacturers like Honda have high ratios such (+4.2:1 and on), because most are torque based and automatic, which further increases torque, so they just need to have a higher output speed.
Edit:
In a horrific amount of hindsight, I've realized that Subaru messed up their wording and what they meant to say was that they reduced the ratio to 4.1 from 4.31. Which improves wheel torque.
Old 05-27-2016, 09:42 PM   #19
gramicci101
Off Topic
The final drive ratio is another name for the ring and pinion in the differential. Changing the ring and pinion is already a well-known and very effective mod for automatics, but I think they go the other direction with it. In this case, they're changing to diff for one with a 4.10:1 ratio. This will make for quicker acceleration, but it also means higher cruising rpm.
Old 05-27-2016, 10:06 PM   #20
nico_rsx
Drives: BRZ 2017 Pure Red, MT
If you look at the press release for the 2017 BRZ, they said they changed the intake, camshaft and exhaust manifold. I'm guessing they only change that in the manual version in an effort not to increase the price of the automatic which is already higher than the manual. I'm pretty sure both transmissions option will now be the same price (higher than 2016).
nico_rsx is offline   Reply With Quote
Old 05-27-2016, 10:14 PM   #21
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
While that sounds nice, the price increase for that I wouldn't buy it. And I'm sure a lot of others wouldn't either.
What is the cheapest dual clutch out there right now?
Volkswagen, it's their primary transmission even the most basic of base models.
https://en.m.wikipedia.org/wiki/Direct-shift_gearbox
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Cole (05-30-2016), funwheeldrive (05-28-2016)
Old 05-28-2016, 01:30 AM   #22
darthpnoy1984
Drives: 15 ZN6 Asphalt
http://www.zf.com/corporate/en_de/pr...smission.shtml
Or maybe even the 8 speed sport direct shift from the GS-F and RC-F we'll see in 2nd generation.
2015 ZN6 DD AT
darthpnoy1984 is offline   Reply With Quote
The Following User Says Thank You to darthpnoy1984 For This Useful Post:
wireman957 (05-28-2016)
Old 05-28-2016, 09:00 AM   #23
Zaku
-Proud of Brzerhood-
Zaku's Avatar
Drives: '17 BRZ CWP LMT.
Cheapest and best I think the one in the Acura ILX
Cheapest in general and kinda crappy is prolly the one in Hyundai Velosters early models
Old 05-28-2016, 11:34 AM   #24
Vivos71
Vivos71's Avatar
Drives: R.S. 2.0
I think that would be the base Ford Fiesta, but there is an obvious sign that it is the cheapest.
Vivos71 is offline   Reply With Quote
The Following User Says Thank You to Vivos71 For This Useful Post:
Old 05-28-2016, 01:08 PM   #25
raven1231
All dat speculation do! I love everyone pretending they know all this unreleased information...
Old 05-28-2016, 02:26 PM   #26
Ezio
Ezio's Avatar
Drives: 2022 BRZ
Except for the part that Subaru released the information. Which I posted.
http://media.subaru.com/newsrelease....features&mid=1
The Following User Says Thank You to Ezio For This Useful Post:
Yoniyama (05-28-2016)
Old 05-29-2016, 07:25 PM   #27
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
DSG wouldn't be as reliable or smooth as a traditional planetary gear auto. VW double clutch gearbox as unreliable as it is, actually operates smoother than the ones from Ford or BMW.
I think the base model twins had a 3.9 final drive in Japan, 4.1 with the higher trim and we got that stock.
I guess the stiffer rear subframe and chassis would allow for a 4.3 final drive to put down that slightly better power. I wonder what would be the cruising rpm on the highway.
krayzie is offline   Reply With Quote
Old 05-30-2016, 05:53 AM   #28
FRSW12
Drives: FRS
No experience with Ford, but I have driven the new VW GTI with DSG, and an E92 M3 with DCT. The DSG is smoother from everyday perspective but still have it's own problem, especially when you go from 1300 to 2600rpm, the lag is pretty noticeable. Haven't tried the new DCT on the F8x generation M3/M4s, but the DCT on the E9x Ms are not as good as the VW ones for DD, but they are more performance oriented, and pretty good when you are going a little nuts. The F8x DCT is suppose to be better in DD and a better performer at the same time from what I heard.
FRSW12 is offline   Reply With Quote
The Following User Says Thank You to FRSW12 For This Useful Post:
krayzie (05-30-2016)
Is there anyway I can swap out my automatic transmission to a manual Kushbrz13 Engine, Exhaust, Transmission 23 01-02-2016 06:10 PM
Which transmission do you have ? Manual or Automatic ? PRO Import Tuners Engine, Exhaust, Transmission 14 08-24-2012 09:21 AM
changing the transmission of an fr-s from automatic to manual. enjoi23 Engine, Exhaust, Transmission 55 08-22-2012 11:24 PM
FT-86, manual or automatic transmission??? luisjr Scion FR-S / Toyota 86 GT86 General Forum 22 07-25-2012 03:00 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
