Old 03-01-2015, 03:49 PM   #57
Kostamojen
His stock run was at 180whp which is unusually high though.
First rule of Dyno charts: Different dynos read differently
Old 03-01-2015, 04:44 PM   #58
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Which is why the 200whp figure is meaningless.
I was mostly pointing out this dyno probably reads high without really saying so. Which would make these gains less than the people putting down 160ish stock baseline and after tune and header putting down close to 200 (same dyno of course).
Old 03-01-2015, 06:53 PM   #59
sachu
Drives: rocketship
Not that this matters honestly, This is on the same dyno and the conditions are the same between the two runs.
The Dyno numbers were verified to be on par with that up in drift office as I got a couple of runs there.
sachu is offline   Reply With Quote
The Following User Says Thank You to sachu For This Useful Post:
Hyper4mance2k (03-01-2015)
Old 03-01-2015, 11:49 PM   #60
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
And others typically dyno at the expected 160 level... I, for one, am impressed.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 03-02-2015, 01:04 AM   #61
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by Hyper4mance2k View Post
From that perspective, I could see how you think that makes sense, but the OFT is marketed as a one stop shop with optimized tunes specified for a variety of products. When a tune designed for a certain product is outperformed by a tune designed for something entirely different, I find fault in that. If it's a better tune overall, then call it a header tune for both UEL and EL. This just shows me that the the EL optimised tune is in fact not optimized for an EL header.
It's like Darigold saying skim milk has all the flavor of whole milk... But, now we're entirely off topic. Obviously any header needs a tune to make the most power out of it, but you have to admit, a tune for an EL manifold should out perform a tune optimized for an UEL manifold, and that's where I find fault.
Back on topic. This header rocks for the price, and we need some more people who have it to get tunes to see how it compares accross the market.
It is impossible for a single EL tune to work optimally on all EL headers. Due to differences in primary runner length and diameter, all differently designed EL headers will have different tuning requirements. The same goes for UEL headers. Of course, our UEL tune for the OFH is going to provide the best overall result because this is a case of a tune being developed for a specific header.
Different headers will provide different VE profiles. And these VE profiles will benefit from very specific VVT mapping. After all the testing we have done, we have gotten to the point where we can quite successfully map the VVT tables after just one dyno run to see where the torque dips and peaks are. This can also be done through custom e-tuning by look at engine load and MAF logs. But offering an optimized OTS tune for any untested header is impossible. I have a good example of this from a custom dyno tuning job I did last week on a catted UEL header. Despite being UEL, it required some pretty significant mapping changes from the UEL OTS map. Later this week I'll make a thread outlining the changes I made and why I made them.
Cheers,
shiv
Shiv@Openflash is offline   Reply With Quote
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
Hyper4mance2k (03-02-2015), Turdinator (03-02-2015)
Old 03-02-2015, 02:57 AM   #62
sachu
Drives: rocketship
Drove down and met up with Vit of VitTuned in Albany today.
Got to drive his 2015 FRS car with similar mods ( hks front pipe, perrin over pipe and perrin 3 inch exhuast, intake and header the same as well as his own flex fuel kit and tune) and man his car was buttery smooth.
Got to try out flat foot shifting, auto blip and launch control, very cool!
We then did some driving around and logging my car and spent a good two hours going over it and him just educating me on what these cars are about and what the logs meant and what the ignition timing maps do, compared them to his own car's and other customer's cars maps look like and where mine was, what the exhuast and intake cam timing maps do and how he sets his IAM and ignition advance maps, his tuning methodology and how he does part throttle tuning and how Dyna pack helps in giving him more granular control over the tune.
End of the day, I came away learning more about our cars today than I have since owning it.
Here is Vit Tuned final NA results on his own personal 2015 FRS with the skunk2 header, intake, perrin overripe, HKS front pipe , 3inch perrin resonated catback and E85.
The gains going from car with header, intake and E85 tune with stock overripe,front pipe and catback to the aftermarket header back system is pretty impressive.
And this is a comparison between his bone stock to current..
That's some massive gains all the way from 1500 Rpm!!!
This header is the real deal. Just need the right tune.
The Following 2 Users Say Thank You to sachu For This Useful Post:
Hyper4mance2k (03-02-2015), Raven604 (03-06-2015)
Old 06-02-2015, 06:27 PM   #63
Darkparadox911
Drives: 2015 Subaru BRZ Pearl White 6MT
Hey all, had my Header Skunk installed about 4 days ago and I truly love it. Feels like there is virtually no Dip at 4k rpm and I am very happy with the extra power at the high end. Throttle response is noticeably better. 3" Perrin MAF CAI en route and Vishnu tune being ordered very soon
Darkparadox911 is offline   Reply With Quote
Old 09-05-2015, 12:29 AM   #64
ron_n_tx
ron_n_tx's Avatar
Drives: 2013 Scion FR-S - Ultramarine
Just installed the Skunk2 header along with OFT Stage 2 EL. Have a GReddy CAI and GReddy SP Elite axleback, stock OP, FP and MP. Runs better than ever. Curious though should I consider loading the UEL tune based on the discussion in this thread? Anyone else doing this?
ron_n_tx is offline   Reply With Quote
Old 10-20-2015, 06:47 PM   #65
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
Hey we have a used Skunk2 header was on for about 3-4 months tops maybe 2-3K miles
We only used it for testing
Ill put it out there here first - we will sell it for $250.00 and include new grimspeed gaskets - message us for photos or a quote to see if we can ship it for that price
86SPEED is offline   Reply With Quote
The Following User Says Thank You to 86SPEED For This Useful Post:
ort895 (10-22-2015)
Old 10-22-2015, 09:44 PM   #66
ort895
ort895's Avatar
Message me back!
I'm down to buy!
Yeah its an auto, deal with it.
ort895 is offline   Reply With Quote
The Following User Says Thank You to ort895 For This Useful Post:
86SPEED (10-23-2015)
Old 10-23-2015, 02:49 PM   #67
86SPEED
86SPEED's Avatar
Originally Posted by ort895 View Post
Message me back!
I'm down to buy!
Send me an email
Malen@fteightysix.com
Old 02-14-2016, 11:30 AM   #68
THE_FRS_KID
Originally Posted by xDanger_208x View Post
I just bought a Tomei UEL but these are looking awfully tempting.
I'm curious if the top end difference will be substantial with my Kraftwerks setup over the uel design??...
I've got the kraftwerk C30 Kit with the skunk2 header. I don't like the sound, I'm actually tempted to switch to an UEL header even if it means lost gains. Did you end up switching? Do you have a sound clip with your tomei? If you switched, were there noticeable gains?
Thanks in advance!
THE_FRS_KID is offline   Reply With Quote
Old 05-26-2016, 09:04 PM   #69
KHANrad_SIN
Drives: Whiteout
Originally Posted by sachu View Post
Here's my current tune with thefollowing mods.
Skunk2 header
Skunk2 intake (with insert)
Nameless overpipe/front pipe with cat
Perrin 2.5 inch resonated catback
Stock car versus modded tuned car.
The insert on the intake needs to be removed and the MAF rescaled again. SO more gains to be had likely.
I might go back to the stock overpipe and front pipe and see if that gives me more torque as well.
Want to give a shout out to Wryaan at VIP performance for working on the tune.
was this dyno done when you had the UEL or EL tune?
KHANrad_SIN is offline   Reply With Quote
Old 10-11-2019, 09:42 AM   #70
TheJet
Drives: 2015 BRZ Series.Blue WRB
Originally Posted by limitedblkwrx View Post
I don't have dyno numbers but I I am running
OFT stage 2 EL tune
Skunk2 Header
Tomei Overpipe
@MAPerformance 3" front pipe and catback
I have noticed that where the header meets the tomei over pipe has a small leak at the bottom. I am going to try and replace the gasket that came with the Skunk2 header with the tomei overpipe gasket that I have and see if that fixes it.
Installed pic:
Attachment 102352
Cold Start Video:
About 70% Acceleration Video: (yes I changed my wheels while it was in the air)
Have you been able to fix your leak? I have one that I thought was at the engine, but after fixing that I still am getting some of that smell. Did replacing the gasket at the over pipe help?
TheJet is offline   Reply With Quote
Skunk2 Lowering Springs NOW AVAILABLE! KraftWerks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 01-10-2015 09:22 PM
Skunk2 BRZ Intake Results! Xero-Limit Engine, Exhaust, Transmission 21 10-20-2014 01:43 PM
New skunk2 frs brz cold air intake 831GT86 Engine, Exhaust, Transmission 17 09-09-2014 04:09 PM
Skunk2 Garage Sale: 06.28.14 KraftWerks Southern California 4 06-24-2014 08:53 PM
FS: Skunk2 Racing 1.3 kg/cm Rad Cap ***SOLD*** JPxM0Dz Canada Classifieds 0 10-01-2013 01:25 PM
