Old 05-24-2016, 01:11 PM   #1
I<3myFRS
Drives: FRS
Aftermarket Intake HP Test
Hey guys,
Here are two great articles to see how much power you're actually making with your aftermarket intake. Not that surprised that a tune is required to see maximum gains. Hope you guys find this useful!
http://dsportmag.com/the-tech/scion-...programed-ecu/
http://dsportmag.com/the-tech/scion-...esting-ecutek/
I<3myFRS is offline   Reply With Quote
The Following 5 Users Say Thank You to I<3myFRS For This Useful Post:
banane63 (05-26-2016), humfrz (05-24-2016), Metabrz (05-28-2016), mizzta21 (05-24-2016), Mr.Impreza (05-24-2016)
Old 05-24-2016, 01:38 PM   #2
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
Yep, just a drop in filter will be the wisest choice.
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
Old 05-24-2016, 02:00 PM   #3
mizzta21
mizzta21's Avatar
Drives: 2014 whiteout, scion fr-s
i own a K&N like everyone else on here i assume, but a little suggestion for you guys. try the Blitz Drop In filter, that filter is underrated and to me i feel has better high end and throttle response. i currently have the blitz over the K&N in my stock box.
mizzta21 is offline   Reply With Quote
Old 05-24-2016, 02:04 PM   #4
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
I have an Apexi Drop in filter =P
The Following User Says Thank You to Mr.Impreza For This Useful Post:
Old 05-25-2016, 11:38 AM   #5
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
This article is one that comes up every so often, and was published I believe about 3 years ago, before people really knew a lot about these ECUs.
The main issue with their testing: Ignition Advance Multiplier is not at 1, so every single intake is limited in horsepower. Resetting the ECU before every single install makes sense (and is what we did when we tested intakes the same way), except that if you don't force the IAM to 1.0 the results you see are gimped. Every single intake and drop in filter makes about the same power because the ignition timing is still lowered.
So it's not the most accurate source of intake information out there, by far.
The other thing I don't like is how they don't show the AFRs for drop in filters, but they do for everything else. This makes the assumption that there is no change (which we saw big changes in AFR in our testing with just DIFs), so why aren't they showing this information?
So while they might look like good 3rd party tests, it's important to pay attention to the details, especially when the things that are overlooked are the MOST important.
Chase
Engineering
GrimmSpeed is offline   Reply With Quote
The Following 6 Users Say Thank You to GrimmSpeed For This Useful Post:
calmtigers (05-25-2016), FirstWinter (05-25-2016), gramicci101 (05-25-2016), Hostile_Kittens (05-25-2016), mizzta21 (05-25-2016), Teseo (05-25-2016)
Old 05-25-2016, 12:06 PM   #6
Icecreamtruk
Drives: Track preped NA FRS
You mean this one? Did you previously had a K&N and decided to change to the blitz afterwards? Did you have a tune?
Icecreamtruk is offline   Reply With Quote
The Following User Says Thank You to Icecreamtruk For This Useful Post:
Old 05-25-2016, 02:32 PM   #7
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
It's painfully obvious OP is affiliated with DSport...
-alex
Old 05-25-2016, 02:43 PM   #8
mizzta21
mizzta21's Avatar
i have them both, switched back and forth between the two as well as resetting the ECU. whats interesting is (note*and this is all going by my butt dyno.) that when i had my stock front pipe the K&N felt better, better throttle response throughout the whole rpm band. (i currently have stock headers, catless FP and N1) when i switched over to a catless Frontpipe the car seemed to like the Blitz drop in better. ive switched back and forth countless times, reset the ECU before every switch. tested the filters in the cold mornings and evenings, tested the filters in the warmest part of the day and imo the Blitz has felt better. i have no dynos to prove it and im willing to bet the differences are miniscule and probably not worht spending another $45 for a .07 hp difference if you have one or the other. just my 2 cents!
p.s. no tune. i will be getting OFT soon tho
The Following User Says Thank You to mizzta21 For This Useful Post:
Icecreamtruk (05-25-2016)
Old 05-25-2016, 02:54 PM   #9
Icecreamtruk
Thanks a lot for the info. I do have the K&N already im just wondering for other options as the time to clean mine will come soon and its $25 for a cleaning kit or $55 for a blitz. Altho I have a full exhaust and tune, so I dont know how wise it will be to switch the filter (the tune was a custom one on dyno).
Old 05-25-2016, 03:02 PM   #10
mizzta21
mizzta21's Avatar
If you don't mind spending the money get the blitz and try it. It certainly has a larger filter area than the K&N. Doesn't hurt to have two filters laying around. I'm sure urs custom tune won't be too far off if u switched.
Old 05-25-2016, 05:23 PM   #11
Falcon
Drives: WRB BRZ
If you change more than just a Filter, only a remap can bring out the full Potential of the System.
Falcon is offline   Reply With Quote
Old 05-26-2016, 10:57 PM   #12
stevo585
Drives: White 2014 BRZ
Chase
Engineering
Initially yes it will show gains. Are those gains still there after a 1k miles? No the ecu will correct the lean condition. If you get a tune then you negate the effect even more.
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
Where To Test Aftermarket Seats itsibarra Southern California 5 03-31-2015 01:07 AM
Vortech with aftermarket intake? Sniper2606 Forced Induction 2 01-24-2014 03:17 AM
WTB aftermarket intake Vlady Want-To-Buy Requests 3 10-23-2013 06:30 PM
Aftermarket Intake Mani. usptwins Engine, Exhaust, Transmission 14 10-10-2012 04:57 AM
FR-S/BRZ aftermarket intake thread usptwins Engine, Exhaust, Transmission 1 09-03-2012 07:49 AM
