Old 10-08-2012, 10:13 PM   #1
usptwins
Toyota Soul
usptwins's Avatar
Drives: 96 taco
Aftermarket Intake Mani.
So, im starting to wonder how much boost this lil plastic manifold can hold.... I sure hope someone is developing an aftermarket one out of aluminum... This would be great. Please, someone, tell me that this is being done.
No replacement for Displacement??? Tell that to the people with a 2JZ.
usptwins is offline   Reply With Quote
Old 10-08-2012, 10:46 PM   #2
xwd
The plastic manifolds on the WRX can handle 30+ PSI. Generally they are better in every way than the old aluminum ones. I don't think that will be an issue.
Old 10-08-2012, 10:47 PM   #3
Mitch
form follows function
Drives: RIP '13 BRZ
I've seen north of 20psi on 15 year old BMW plastic manifolds.
Mitch is offline   Reply With Quote
Old 10-08-2012, 11:04 PM   #4
usptwins
Toyota Soul
usptwins's Avatar
Drives: 96 taco
Yall really think so? Im just so use to aluminum mani's that they seem sceptical... But, do they really flow that much better?
Old 10-08-2012, 11:06 PM   #5
dabocx
dabocx's Avatar
Drives: Scion FRS
I doubt the material used would affect flow much if at all, its more a matter of the way the manifold is designed that affects flow.
Still im sure we will see aftermarket ones soon.
dabocx is offline   Reply With Quote
The Following User Says Thank You to dabocx For This Useful Post:
usptwins (10-08-2012)
Old 10-08-2012, 11:38 PM   #6
gmookher
plastic has less heat soak
gmookher is offline   Reply With Quote
Old 10-08-2012, 11:41 PM   #7
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Plastic is smoother than cast aluminum and has less heatsoak.
Arguably, it is not as shiny. But that can be overlooked for the sake of performance.
- The Ancient BRZ Sacrament
by Zaku
Old 10-09-2012, 01:28 AM   #8
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Is it really plastic? I thought it was a composite fiber material. FRM?
At any rate, it is much more rigid and won't melt until very high temperatures.
Coheed is offline   Reply With Quote
Old 10-09-2012, 04:51 AM   #9
usptwins
Toyota Soul
usptwins's Avatar
Drives: 96 taco
Well, whatever it really is. I was just wondering.
Old 10-09-2012, 11:45 AM   #10
Turbowned
Turbowned's Avatar
Well, it's not a Ford plastic manifold, so I think we're safe
Though I would be interested to see if Cosworth designs a manifold for the FA20 like the one they make for the EJ257:
Old 10-09-2012, 12:41 PM   #11
chutrain
chutrain's Avatar
Drives: WRB BRZ
I was running around 20psi on my LGT manifold and never had an issue. The stock top mount would fail way before. Never heard of any issues with the plastic manifold to be honest. They are not prone to heatsoak like the aluminum ones that are found on the STI.
In the garage:
1988 BMW E30 M3
2003 Ducati ST4s ABS
2006 Subaru Legacy GT Spec B #444/500 (For Sale)
2013 Subaru BRZ WRB Limited - Acquired 9/15/12
chutrain is offline   Reply With Quote
Old 10-09-2012, 12:59 PM   #12
jeebus
Drives: 2015 Mustang GT (on order)
I'm actually wondering if someone will make an intake manifold that manages to cure the power dip.
jeebus is offline   Reply With Quote
Old 10-09-2012, 09:06 PM   #13
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
Think about the pressures that a 2 liter soda bottle can take. I don't know any figures offhand but a quick Google search is giving me 70+ psi....
Don't assume that just because it's not metal that it is weak...
Sent from my Galaxy Nexus using Tapatalk 2
Chewie4299 is offline   Reply With Quote
Old 10-10-2012, 02:21 AM   #14
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
Plastic manifolds are fine, plenty of LSx guys make 700+ with an LS6 style plastic one, or even more with a FAST 90/92/102mm intake manifold - had a 102mm on my corvette.
seven is offline   Reply With Quote
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 12:43 AM
So cold air intake or air intake? bcmakesiteasy Engine, Exhaust, Transmission 12 02-01-2014 08:06 PM
Aftermarket Intake + Bog Issues - Read Here Jidonsu Engine, Exhaust, Transmission 244 08-10-2013 07:35 PM
aftermarket rubber intake tubing??? 20valvewynn83 Southern California 39 09-13-2012 11:12 PM
FR-S/BRZ aftermarket intake thread usptwins Engine, Exhaust, Transmission 1 09-03-2012 06:49 AM
