Old 05-17-2016, 02:10 PM   #1
Remmenator
Drives: Black 2013 FR-S
Offset on rpf1 for a lowered car
I am going to be buying a set of rpf1s in 17x9 for my car, and was wondering what offset I should buy, +35 or 45. I would like to be able to avoid spacers so I was thinking the +35, but I want to be sure I won't get rubbing with the 35 because it has been lowered on swift springs an inch. It's running 1.5 degrees camber in the front and 2.5 in the rear. I would think with the camber I would be fine, but I want to be sure. If I get +35, I was also wondering if I would need my fenders rolled. Thanks in advance! Share any picks of a similar set up if you have them please
Remmenator is offline   Reply With Quote
Old 05-17-2016, 11:21 PM   #2
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
when in doubt, always go lower offset.
DuMa is offline   Reply With Quote
The Following User Says Thank You to DuMa For This Useful Post:
15limited (05-21-2016)
Old 05-17-2016, 11:30 PM   #3
gramicci101
Off Topic
This thread will tell you all you need to know. http://www.ft86club.com/forums/showthread.php?t=7535
Old 05-18-2016, 11:49 PM   #4
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
depends how low you're going. +45 will tuck, but at full lock you'll probably rub. +35 will poke if not low enough. if low enough, will be cambered atleast 3 deg in the front. rears will fit with like -2--3
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
Old 05-19-2016, 12:52 AM   #5
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
Our cars rarely need the fenders rolled. With the setups you're considering, you will not need the fenders rolled.
tyler_win_photo is offline   Reply With Quote
The Following User Says Thank You to tyler_win_photo For This Useful Post:
Old 05-20-2016, 07:35 PM   #6
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
-1.5 front
-2.2 rear
http://www.ft86club.com/forums/showp...&postcount=634
Very slight poke up front
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 05-20-2016, 08:05 PM   #7
HachiRo
Drives: 2013 White-Out FRS
Instagram - BattleBunny86
I'm lowered on RSR Superdowns (1.4ish) springs with 17x9 +35 RPF1s and a pretty meaty 245/40/17 tire setup.
No rubbing at all.
Camber is -1.5 in front (SPC camber bolts) and -3.0 in back (natural).
I live my life one quarter-pounder at a time.
HachiRo is offline   Reply With Quote
The Following User Says Thank You to HachiRo For This Useful Post:
Old 05-21-2016, 11:39 PM   #8
15limited
15limited's Avatar
No rubbing at all.
Same springs, wheels size, camber. 245/45/17 tires but with stock struts the tires are VERY close to rubbing on the spring perch , but haven't rubbed yet. I must not get much sidewall deflection with Falken RT615K's because after inspection of the inside of the tire, where the tires would rub the perch, I haven't noticed even the slightest wear.
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
The Following User Says Thank You to 15limited For This Useful Post:
HachiRo (05-22-2016)
enkei, fit, offset, rpf1, wheels
WTB: 2 enkei rpf1 16x7 offset +35 LFA.Baby Want-To-Buy Requests 0 09-18-2015 11:50 AM
Enkei rpf1. 17x9+35 offset Geeteepee Southern California 4 01-27-2015 07:12 PM
Best offset for RPF1 (+35 or +45) in 17x9 and track/AX use dp1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-19-2014 04:01 PM
Lowered 1" and have a 265/35 or 255/35 tire +38 offset please post pics! ScionFR-S Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 01-30-2014 02:26 PM
FS: Socal rpf1 black 17x9 45 offset toby714 Wheels and Tires 13 08-18-2013 11:17 PM
