Old 05-17-2016, 02:16 AM   #15
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
As mentioned before, please don't make repeat threads.
- The Ancient BRZ Sacrament
by Zaku
Old 05-17-2016, 02:52 AM   #16
Amourii
Drives: Toyota 86 GTS
No pain at all. I went through this with my MX-5. No matter how I adjusted the seat, my back would hurt on long trips. In that instance, we put 88,000 touring miles on our Miata in 7 years.
After consuming as much codeine as I could talk my Doctor friend out of, my body told me there had to be a better way.
So, I went to this "therapist" for treatment. She (a cute little thing, bye the way) worked be over for a few sessions then accompanied me out to my car and ask me to sit in it. She determined that there was a gap behind my back that wasn't being supported (lumbar area) and my tail bone wasn't being cushioned adequately.
I tried several store bought cushions (like gel cushions) but they "bugged" me and didn't work for me.
So, I took a "wedge" type store bought cushion and cut it in half longways, to fill the gap in the back of the seat (lumbar support).
Then I purchased some 3/8 (or 1/2") thick closed cell foam roll and cut a section off of it for the seat cushion and covered it with the pillowcase, so I could slide off it easier and so it wouldn't look so hookie. You may wish to use two layers of foam.
FINALLY relief! Now, I could just use my codeine for mrs humfrz, to knock the edge off. when I'm roaring through the mountains (like pikes peak) .... yep, that one took a double dose ......
Something else I picked up from that pretty little therapist, was an easy exercise ....... simply sit upright on a chair put your hands on your knees and rock your pelvis up and back for a few minutes each day.
However, keep in mind, you are in your 20's and I'm in my 70's, so ....... results may vary........
I hope you find some relief so you can enjoy driving your car.
Could you please show me a photo of the "wedge" type store bought cushion and cut it in half longways, to fill the gap in the back of the seat (lumbar support). As I would like to see what it looks like it in thickness , I am now very paranoid at how my seat sits I keep changing it haha because I don't know what feels right !
Amourii is offline   Reply With Quote
Old 05-17-2016, 03:10 AM   #17
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
When you sit, don't slouch. Shove your ass way back in the seat, then lean back.
The Following 2 Users Say Thank You to EAGLE5 For This Useful Post:
humfrz (05-17-2016), Ultramaroon (05-17-2016)
Old 05-17-2016, 03:34 AM   #18
Well, here is.
The cover looks all saggy because I cut half of the foam out of it.
I suggest you just do some experimenting ........ your back will tell you when you got it right .......
Old 05-17-2016, 08:03 AM   #19
Amourii
Well, here is.
Any reason why you cut half the foam out ?? Do you think bean bag beads would be a good option too ?
Old 05-17-2016, 02:23 PM   #20
nos145
Cognite
nos145's Avatar
Drives: 2013 Whiteout FRS
here, you could try these too:
sounds like you need lumbar support.
also. hit the gym. that's the only thing that is keeping me in a single piece. lower back extensions and stretching those hamstrings out.
nos145 is offline   Reply With Quote
Old 05-17-2016, 02:28 PM   #21
I cut half of the foam out because it was too thick for my use.
You might try bean bags .......
I have more old, used once, seat cushions (for my old cars) in my garage than @Cole has mufflers .........
Cole (05-17-2016)
Old 05-18-2016, 01:47 AM   #22
Amourii
I bought one of those but the problem is its too big for the seats like where the bolsters come out it touches it doesnt actually go inside !
Old 05-18-2016, 02:39 AM   #23
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Somehow I'm more interested in the fact does Mr. Hum still drive all the way out or not?
As for op......do you sit all the way back? Like all the way all the way & near upright? If you do everything already.... ross has those memory cell form pillow thing for like 10 buck... >___>
Old 05-18-2016, 03:37 AM   #24
BeRZed
Have you tried adjusting the steering wheel? Maybe have it closer to you, and then adjust your seating position from there.
BeRZed is offline   Reply With Quote
Old 05-18-2016, 10:52 AM   #25
nos145
Cognite
nos145's Avatar
fuck it, swap the seat like i wanted to.
honestly, go for a racing seat to keep it nice and low (go into a store and sit in one for 2 hours with a newspaper, if they ask questions, show them a wad of cash), or try to get one from a Mercedes with all the supports and electronics (car parts sites, car dumps, etc).
if you go latter route, make sure its not too high and ur feet are not brushing up against the steering wheel
Old 05-18-2016, 11:47 AM   #26
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I had a lot of difficulty with lower back pain with my Forester XT, very stiff, in it for 2.5 hours a day.
After swapping my seats out for 04 WRX seats, a lot of the pain eventually went away. When I got the BRZ, it was improved even further AFTER a lot of adjusting.
Keep tinkering with the seat.
JazzleSAURUS is offline   Reply With Quote
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
nos145 (05-18-2016)
Old 05-18-2016, 08:46 PM   #27
Amourii
I have kept trying to play wiht the seats cant seem to find a good sitting position because my lower back seems to be in pain even before getting in the car because of it therefore even when im sitting in the car playing with it I am unsure if it feels right if you get me ?
Old 05-19-2016, 12:13 AM   #28
@Amourii ....... it's sounding more and more to me, like you need to get your back "fixed" before you will be able to be comfortable sitting in your car.
Foot pain while braking hard? daiheadjai Other Vehicles & General Automotive Discussions 19 04-05-2015 09:46 PM
Back Pain and Long Term Use Marinrounder Scion FR-S / Toyota 86 GT86 General Forum 28 03-27-2014 09:41 PM
BRZ causing sciatic pain... halp s0sl0w BRZ First-Gen (2012+) — General Topics 24 05-30-2013 10:37 PM
Is my pain normal? boredom.is.me Scion FR-S / Toyota 86 GT86 General Forum 22 04-15-2013 07:57 AM
