Old 04-14-2013, 02:18 AM   #1
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Is my pain normal?
I drive in the 9 and 3 position, arms with a slight bend. Like every other LHD car owner, my primary arm is my left. Is it abnormal that my left elbow is in a decent amount of pain? I drove from Daytona to Tampa and back last weekend and I also just got back into Daytona a few hours ago.
Old 04-14-2013, 02:22 AM   #2
boredom.is.me
Custom User Title
It's a 2.5hr trip each way, but I probably managed to do both trips in about 8hr.
Old 04-14-2013, 02:22 AM   #3
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Not normal. I don't have any pain, and the longest stint I've driven mine was 17hrs straight. My right knee, hip, and lower back hurt, but not my elbow.
Maybe adjust your seating position? Stretch more?
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 04-14-2013, 02:31 AM   #4
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Keep adjusting your steering wheel and seat position.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 04-14-2013, 02:35 AM   #5
Exhaust
UCanThrottleMyBody
Exhaust's Avatar
Drives: 2015 GM 370z Sport
Seat position like everyone else says, Im ambidextrous and suffer on both arms if im too close mainly in my wrist.
Exhaust is offline   Reply With Quote
Old 04-14-2013, 02:47 AM   #6
Retro86
Retro86's Avatar
Drives: Awesome
This.
Retro86 is offline   Reply With Quote
Old 04-14-2013, 02:51 AM   #7
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Positioning is a primary concern. Change up your seat and wheel positions to find one that works for you.
I find it less stressful to lean back into the seat and push with the outside arm and a light grip.
You can use the seat bolster to support the motion easier than pulling with the inside arm.
Gripping the wheel tightly uses a lot of calories and will wear you out faster.
I use the 10 and 2 mostly. they've even put egonomic prosthesies(?) there for that purpose.
Old 04-14-2013, 02:51 AM   #8
ZDan
ZDan's Avatar
Drives: '23 BRZ
"Primary" arm? Both hands should be on the wheel 90% of the time!
With your shoulders firmly supported by the seat (i.e., no ridiculous strain-inducing excessive seatback lean angle), your arms should be bent quite a bit, approaching 90 degrees (not "slightly bent"), with both hands on the wheel at 9 and 3. Should be able to easily turn the wheel 90degrees and still have some bend angle in both elbows, without your shoulders coming off the seatback.
Nothing more ridiculous than to see people with a ton of seatback lean, but having to strain their backs to keep their hands on the wheel. This is a LOT less relaxing and more stress-inducing, and of course if evasive action has to be taken they are in NO kind of position to maintain control of the car.
Old 04-14-2013, 11:28 AM   #9
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
^^^^^ What he said ^^^^^
When I go back to the gangster lean position, it's fatiguing. For long car trips, I lean back one click. I'm 6' and my seat has a little room to slide back more.
Old 04-14-2013, 12:26 PM   #10
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
this car makes my right hand sweaty. I have a bad disc and the seats definitely don't help.
SloS14 is offline   Reply With Quote
Old 04-14-2013, 12:33 PM   #11
Mandy
I came from a motorbike
Mandy's Avatar
Drives: Firestorm 2013 FR-S 6MT
The only pain I have while driving is from my cheeks, due to smiling too much.
Mandy is offline   Reply With Quote
Old 04-14-2013, 12:40 PM   #12
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
I rest my left elbow on the door. If you can't do that, I suggest you slide closer to the wheel.
raul is offline   Reply With Quote
Old 04-14-2013, 12:41 PM   #13
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
If you're like me, you're going to need to dedicate some time to really finding that perfect driving position. The worst thing you can do here is settle. The second mistake you can make is not taking advantage of all the adjustable features in your car (seat, steering wheel, mirrors) and set them according to things you can't adjust (pedals/shifter).
I am very comfortable in my car and it's because I found my perfect seating position and I won't move it for anything. If I can offer you one good tip; Set your driving position up with your back fully against the seat. You should be comfortable driving with your head against the head rest. This isn't going to work for everyone but for me it's the difference between constantly fumbling to find a good position and being perfectly comfortable. This position also gives you the advantage for higher G turns.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 04-14-2013, 01:40 PM   #14
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
It took me nearly a month to find the perfect driving position.
Parting out HERE
Does this look normal to you? white_knight Issues | Warranty | Recalls / TSB 13 03-03-2013 03:10 AM
Is this normal? ArKiTeCkT Engine, Exhaust, Transmission 3 10-29-2012 02:54 AM
Is it normal to see a .... Mango22 BRZ First-Gen (2012+) — General Topics 10 10-12-2012 02:54 PM
Opti Guard/Coat, Xzilon pain protection jaytaurus Northwest 3 07-01-2012 05:47 PM
Scion goes normal terrypm Other Vehicles & General Automotive Discussions 21 05-02-2012 10:16 AM
