Old 05-16-2016, 12:44 PM   #15
NOHOME
Drives: RAVEN
If only this car ran on hype, it would be the fastest car on the planet.
NOHOME is offline   Reply With Quote
The Following 9 Users Say Thank You to NOHOME For This Useful Post:
Bristecom (05-16-2016), El Guapo (05-16-2016), extrashaky (05-16-2016), funwheeldrive (05-16-2016), JD001 (05-17-2016), lantsalot (05-18-2016), smg1138 (05-16-2016), soulreapersteve (05-16-2016), Tcoat (05-16-2016)
Old 05-16-2016, 01:33 PM   #16
About 40 miles to the blog? Even better if you switch it over to run on clickbait?
finch1750 (05-16-2016)
Old 05-16-2016, 01:45 PM   #17
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by darthpnoy1984 View Post
I'm surprised no one here has mention about hopefully having an option of a bigger fuel tank even by a 1 to 2 gallons would be nice.
#1styearlightestyear
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
funwheeldrive (05-16-2016), Tcoat (05-16-2016)
Old 05-16-2016, 03:17 PM   #18
mdm
not a twin owner
mdm's Avatar
Drives: 2016 Veloster Turbo DCT
Originally Posted by Braces View Post
Not sure you can add all that tech (hybrid) and lower the weight.
It's actually very simple, and one is related to the other. For hybrid you need batteries. I read on an Australian tech site that Toyota has a completely different type of batteries in pre-production now. They become lighter when charged!
Actually, above 50% charge the battery has negative inertial mass - but still it has positive gravitational mass, i.e. weight.
So you are still pushed down by gravity acting on the gravitational mass, giving you grip. But the inertial mass of the battery is negative, up to negative 1600 lbs at full charge, so the car accelerates as if it was ~1200 lbs. The electric part of the hybrid adds 90 HP on top of 200 from the gas engine, making about an equivalent of 4.13 lb/HP with grip of a 2800-lb car.
They are still working on ironing out some kinks, for example at low charge levels the inertial mass becomes larger than the gravitational mass, and quickly. E.g. below 25% charge you need a B747 tug to move the car at all. Below 10% you need a Saturn V rocket. Or you just need to charge the battery. But they will have it all fixed for 2018 MY.
Aren't they supersmart at Toyota, not only this will create the best sports car ever with excellent acceleration AND mileage AND grip, but in the process they figured out how to violate Einstein's equivalence principle and decouple inertial mass from gravitational mass. Which is YUGE, a Nobel Prize in physics is coming for sure.
If I only could find the link to that Australian tech site, you could read about it too.
mdm is offline   Reply With Quote
The Following 5 Users Say Thank You to mdm For This Useful Post:
akyp (05-17-2016), ConceptX (05-16-2016), finch1750 (05-16-2016), kch (05-17-2016), lantsalot (05-18-2016)
Old 05-16-2016, 07:09 PM   #19
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Those Aussies alway have the most up to date info leaks. Damn them being a day ahead...
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
mdm (05-16-2016), Tcoat (05-16-2016)
Old 05-16-2016, 07:50 PM   #20
NahumCC
Drives: 2013 FR-S 10 Series
And will it come with the Nico Rosberg edition steering wheel . Gotta be ready with that derate mode.
NahumCC is offline   Reply With Quote
Old 05-16-2016, 10:07 PM   #21
extrashaky
Drives: 2014 BRZ Limited
The big problem is mining enough unobtainium to make all those batteries.
The Following 6 Users Say Thank You to extrashaky For This Useful Post:
Braces (05-17-2016), ConceptX (05-16-2016), FRSBRZGT86FAN (05-17-2016), MarcFr-s (05-17-2016), mdm (05-16-2016), Tcoat (05-17-2016)
Old 05-17-2016, 11:04 AM   #22
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Not sure you can add all that tech (hybrid) and lower the weight. Curious about lowering the weight. I mean the car already feels like a tin can. Where are they going to lower the weight? If they did turbo the car .... say goodbye to the 2 liter. Dropping weight means a smaller FI motor.
He's only saying things to keep people speculating. Keep us entertained and on board.
I'm guessing the entire car isn't fully aluminum and can still be made even more rigid to remove even more body flex. Although I highly doubt it can shave more than 100 lbs, It would need a serious redesign to the new ND miata style of weight savings.
Old 05-17-2016, 01:27 PM   #23
kch
Senior Misanthrope
kch's Avatar
Why?
It'd be nice to have a different fuel tank for two reasons:
1) With E85, my range is realistically only about 220 miles
2) The design of the current tank makes the car fuel starve on high-G left hand turns. Again, particularly with E85.
The Following User Says Thank You to kch For This Useful Post:
Tcoat (05-17-2016)
Old 05-17-2016, 01:33 PM   #24
Thanks. I was truly baffled since it holds enough for many miles (on normal fuel) and I don't do many high-g left turns. Don't know how they could make a bigger/different style fit up in there though. Also not sure how 1 or 2 more gallons would make enough difference in miles on E85 to make the weight increase worth it.
Old 05-17-2016, 01:38 PM   #25
kch
Senior Misanthrope
kch's Avatar
Yeah, the capacity is just a minor thing. Fuel starvation is a pain in the ass, though. Starts to starve if you're around 1/2 tank, so I have to constantly fill up my car after every session.
Old 05-17-2016, 01:40 PM   #26
Symptom of the split tank design?
Old 05-17-2016, 01:46 PM   #27
kch
Senior Misanthrope
kch's Avatar
Seems to be. I know some people have tried a dual-pump setup. Not sure how well that worked out. I'm not fast enough to need something like that yet.
Old 05-17-2016, 01:57 PM   #28
DAEMANO
Time Traveller
Current tank is saddle-style. They would/could have to produce a flat bottomed tank so fuel on the side far from the pump would continue to be pumped. That would be a fairly drastic redesign that would apply really only the the racers of this world. As a person who runs e85, I'd love for them to do it, but sadly doubt it would be a priority.
You can see the shape of it here in Michelle Abbate's build.
Turn it in for next generation !!! Fred Flintstone Issues | Warranty | Recalls / TSB 43 02-08-2015 10:18 AM
BRZ/FR-S Second Generation? JGalp BRZ First-Gen (2012+) — General Topics 17 02-06-2015 01:32 PM
Tada Tetsuya Announces Updated 86 Will Be Coming... Soon ichitaka05 Scion FR-S / Toyota 86 GT86 General Forum 372 04-30-2014 10:07 AM
Do you think there will be a second generation FRS? NikostC Scion FR-S / Toyota 86 GT86 General Forum 23 05-25-2012 08:18 PM
Next generation Wrx info sparrowhawk Other Vehicles & General Automotive Discussions 10 03-25-2012 10:33 AM
