Old 05-16-2016, 03:30 PM   #43
Originally Posted by SlammedSilly View Post
higher octance fuel burns off quicker hence "race gas"
How high of octane did you get?
Old 05-16-2016, 03:47 PM   #44
SlammedSilly
Drives: 2015 Ultramarine FR-S
hehe, ummm i think it was 100+? i forget what it was
SlammedSilly is offline   Reply With Quote
Old 05-16-2016, 03:51 PM   #45
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
http://www.myomegafuels.com/products.html
I'm assuming you have a flex fuel kit?
Old 05-16-2016, 04:00 PM   #46
OK
Higher octane fuels usually burn SLOWER than lower octane ones but at 100+ then you may well have had a fuel made with a lower specific gravity than normal that may indeed burn faster. It would certainly be "racing gas". Normal pump gas octane (up to 94) is not "better", "more powerful" or in other way different than regular gas except in it's knock resisting abilities.
Going over 94 will do nothing for your car since the ECU is not designed for it. Unless you have a tune specifically for that fuel of course. There is no advantage to putting higher octane in the car with out a tune. In fact you can damage it.
The noise you heard was not likely because of the exhaust gases changing. There just would not be a big enough change to be able to notice. It could have been your car trying to cope with that high of an octane fuel though.
fumanchu1 (05-16-2016), SlammedSilly (05-16-2016)
Old 05-16-2016, 04:28 PM   #47
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
To the OP, I won't knock on you but when the other guy meant useful information related to your issue he meant what you just wrote. Had you started off by saying you were running BP Ignite 100+ octane race fuel then people would have been in a better position to assist you and would be much less likely to flame or troll you.
fumanchu1 is offline   Reply With Quote
The Following User Says Thank You to fumanchu1 For This Useful Post:
OpenFlash Header (OFH) Cracked--Worth Fixing? gonzo Engine, Exhaust, Transmission 9 12-27-2015 05:55 PM
Cracked block? seant2h Engine, Exhaust, Transmission 18 09-03-2015 01:24 PM
cracked header Jonesy86 Northwest 21 02-09-2015 09:13 PM
Cracked Oil Pan?! Jolaessss Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 11-21-2013 02:28 PM
Cracked Rim SmsAlSuwaidi Issues | Warranty | Recalls / TSB 29 04-02-2013 01:30 PM
