Old 05-14-2016, 06:39 PM   #533
sickmint79
Drives: bmw
Originally Posted by mb_ View Post
Went to the Ridge Motorsports Park yesterday in Shelton, WA. Oil temps were at 100 degrees celcius (Total 0W-30) during and after each session. But then again, it wasn't every warm. We'll see what the temps are at in a July track day.
any more days yet? 100 c is quite low!
PointMeBy - auto enthusiast / 86 / car blog - https://www.pointmeby.com
IGoByPlane - travel/credit/auto experience blog - https://www.igobyplane.com
sickmint79 is offline   Reply With Quote
Old 05-15-2016, 08:44 AM   #534
Tor
Tor's Avatar
Drives: Toyota GT86
@Kiske, what was the result of the install? Does the oil still heat up faster even with an external oil cooler installed too?
Is the Mishimoto 288 plate thermostatic?
Originally Posted by Kiske View Post
I called Mishimoto who has a new oil cooler setup for their 2015 WRX that works WITH the OEM WRX/Forester oil cooler setup. They (though customer service) let me buy just the adaptor sandwhich plate and threaded center bolt/nut for $15+shipping that fits onto the OEM style oil-cooler, clearing the larger anti-spill ring around the oil filter.
Here is the part numbers... or what is on my invoice for the bolt and sandwhich plate.
-Mishimoto 288 Kitted in US $7.50 Extended: $7.50
-Mishimoto 1020 Kitted in USA to make MMSPA-M20. M20 x 1.5 -- M20 x 1.5 (no dashes) w/ zipper poly bag. $7.50 Extended: $7.50
Will let you guys know how it goes. Hope to have the parts by next Wednesday.
Tor is offline   Reply With Quote
Old 05-15-2016, 12:25 PM   #535
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
No, it heats up about like it did when it was stock. In the 20 degree winter mornings it takes a good 4min of light driving to get the temp up to around 115*F.
In the spring and summer it heats up like normal. If the car isn't moving (like let it warm up in the garage) the effects of faster warming isn't really noticible to me anymore. It feels stock Keep in mind I have a larger radiator, low temp thermostat, a large 19row oil cooler, about 15% more incoming air into my engine bay and my gauge won't read temps below 100*F unless I'm watching with ecutek, and I haven't in a while.
There isn't a thermostatic plate. You won't have enough clearance to run it, the oem cooler and the oil cooler sandwhich plates and still fit the oil filter without smacking the hood.
Old 05-15-2016, 01:26 PM   #536
Tor
Tor's Avatar
Drives: Toyota GT86
The reason for asking is because I just installed a 13 row cooler on my naturally aspirated stock engine car. Even when I when I beat on it, I don't get more than 200 deg F.
So I was thinking about combining the heat exchanger with the external cooler. The heat exchanger to make sure it doesn't run too cool on the streets and the external to keep it from running hot at track days.
But since the oil is going from the heat exchanger directly to the external cooler, I am wondering if any effect the heat exchanger might have immediate would be countered?
In other words is it worthwhile?
The Following User Says Thank You to Tor For This Useful Post:
CxG (05-15-2016)
Old 06-17-2016, 10:52 PM   #537
mynameis940
mynameis940's Avatar
Drives: WRX
Hey if anyone is interested I have everything needed for this in my closet. I bought it then decided to sell the car. I'm going to post pictures and stuff in the market section this weekend but just thought I'd post here for now.
mynameis940 is offline   Reply With Quote
Old 06-19-2016, 01:50 AM   #538
Irace86
Drives: BRZ + Ducati M796
PM sent.
Irace86 is offline   Reply With Quote
Old 06-21-2016, 03:43 PM   #539
Irace86
Sounds like this is a good setup for anyone because it helps warm the oil faster, and acts as a regulator by distributing heat out among the system. Sounds also like it will maintain oil temps just fine for most applications.
The point that I read is that the stock coolant journals throughout the engine don't pull enough heat off the oil, so this oil cooler provides a mechanism for getting that accomplished. And the idea is that spikes in temperatures in any one area (fluids, chambers) can lead to engine failure, so distributing the heat out will allow for safer engine use at high thresholds.
The other point is that this kit doesn't increase the thermal capacity of the system because there is no addition of cooling surface area. If heatsoak was an issue then a larger radiator would be necessary. In the case that the oil regulator couldn't extract enough heat, and it was a bottleneck in cooling (coolant temps were ok, oil temps were heat soaked) then a dedicated oil cooler would be necessary. The good thing is that OEM oil regulator could work in conjunction with aftermarket oil coolers with the addition of a sandwich plate like with the Mishimoto example. In either case, with a radiator or with an aftermarket oil cooler, the system has increased its thermal capacity through the addition of more radiators/cooling surface area.
The Following User Says Thank You to Irace86 For This Useful Post:
CxG (06-22-2016)
Old 06-28-2016, 06:29 PM   #540
Irace86
Installed the oil cooler. I decided to cut the xt pipe at the curve and weld the end back on so it was straight. Then I painted it with high temp paint. Worked perfectly. Ignore my amateur MIG welds.
I used the same ebay nipple as another member.
The Following 3 Users Say Thank You to Irace86 For This Useful Post:
CxG (06-28-2016), jcw99 (06-30-2016), ZZT86 (06-30-2016)
Old 06-30-2016, 07:21 AM   #541
ZZT86
ZZT86's Avatar
Drives: BR86
Nice job, well done
ZZT86 is offline   Reply With Quote
The Following User Says Thank You to ZZT86 For This Useful Post:
Irace86 (06-30-2016)
Old 06-30-2016, 08:08 AM   #542
jcw99
Drives: swp mt '14 brz premium
Originally Posted by ZZT86 View Post
Nice job, well done
Ditto
jcw99 is offline   Reply With Quote
The Following User Says Thank You to jcw99 For This Useful Post:
Old 07-04-2016, 07:19 PM   #543
j_motion
Drives: 14 BRZ Red premium
Can any one verify if the barb on the TB is 1/2 or 3/8?
I am going wit the TB route, just want to make sure i get the right size hose
thank you
j_motion is offline   Reply With Quote
Old 07-05-2016, 08:06 AM   #544
Roberto12
Drives: scion fr-s argento
https://goo.gl/photos/nAomQwmNrGLmHBh3A
https://goo.gl/photos/fXTgxowjS5yEgySK7
I have an external oil cooler and the OEM together. It does not smack the hood.
Roberto12 is offline   Reply With Quote
The Following 2 Users Say Thank You to Roberto12 For This Useful Post:
CxG (07-05-2016), pgranberg11 (05-17-2017)
Old 07-05-2016, 02:07 PM   #545
CxG
Drives: Pearl White '13 ZN6
Does the oil warm up during winter?
Sent from my D5803 using Tapatalk
CxG is offline   Reply With Quote
Old 07-05-2016, 08:35 PM   #546
Roberto12
Yes it does. It also keeps the oil warm enough so that it doesn't run to cold in the winter.
CxG (07-07-2016), sroby (01-28-2019)
brz, fxt, oil, oil cooler
OEM Oil cooler from the 2.0 DIT Forester Kostamojen Engine, Exhaust, Transmission 119 09-10-2019 05:28 AM
Bought a 2014 Subaru Forester EAGLE5 Other Vehicles & General Automotive Discussions 10 10-02-2013 12:54 PM
2014 Forester key fob - nicer than BRZ Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 04-17-2013 03:35 PM
BRZ 2.0L Turbo in 2014 Forester Sleeperz BRZ First-Gen (2012+) — General Topics 37 03-21-2013 06:42 PM
Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… 2013GTRNate BRZ First-Gen (2012+) — General Topics 12 02-01-2013 12:29 PM
