| DIY (Do-It-Yourself) Guides For all DIYs. |
#43 | |
Drives: 2013 Brz C38 (bought not built :P)
#44 | |
Drives: 2005 Toyota Camry
Suggest you download the factory service manual and browse through it. http://www.ft86club.com/files/BRZwiringi.pdf Page 316 onward. I'm going to disassemble my Blitz setup in the next week or so, I'll snap some photos of how it's wired up. -alex |
| The Following 2 Users Say Thank You to mav1178 For This Useful Post: | ChrisD (05-16-2016), Initial_RD (06-09-2016) |
#45 | |
Marine Electrician
Drives: Toyota TRD86, 2014
Well I have not installed the innovate pressure/temp sensor anyway, and got my self a TRD oil temp gauge instead so i put my temp sensor in the oil gallery. I'll use the innovate for a future track car or something
My Toyota TRD86 can be found here:
http://www.ft86club.com/forums/showthread.php?t=63303 |
#46 |
Drives: GT86
Got mine installed the other day and we ended up going off the wires that go into the back of the clock. The red/black wire is constant power, green/white is ignition on, and black/yellow is ground. We didn't bother with the dimmer but might look into that in future if it's too bright at night.
My GT86 build so far:
AVO Stage 4 Turbo, Carrillo forged con rods, 10:1 CR Carrillo pistons, AVO 3 inch turbo back exhaust, Helix clutch, TheDriveShaftShop drive shafts, lightweight flywheel, NamelessPerformance hydraulic hand brake, KW V3 coilovers... and lots of other little bits |
| The Following User Says Thank You to ChrisD For This Useful Post: | Initial_RD (06-09-2016) |
#47 |
Drives: 13 BRZ Limited WRB
Anyone try to install the Perrin Oil Temp Adapter with the Innovative MTX Dual Oil Temp / Oil Pressure gauge?
I have the Perrin Oil cooler, so the temp adapter would just be a direct swap for that spacer, but the problem lies in the Oil Temp sender - it's too long for the depth of the adapter. Any thoughts? ![]() http://perrinperformance.com/i-22245...e-adapter.html http://www.innovatemotorsports.com/p.../MTXD.php#3852
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925 |
#48 | |
Blitz: https://www.flickr.com/photos/137904...h/23290625593/ My install: http://www.ft86club.com/forums/showthread.php?t=99441 For your reference, the Blitz kit allows the individual elements to be purchased separately. However, you may have to redo your lines. Including the port on the spacer portion, there are a total of 6 1/8PT sensors that can be mounted on the Blitz setup. -alex |
#49 | |
Drives: Subaru BRZ
#50 |
Keep ICE alive+manuals
Drives: 2015 Hot Lava 6 spd
Oil gauge
I bought the Beatrush sandwich plate as its one of only 2 i think that will clear the lip on our oil filter flanges, works great, no leaks yet. I have the Defi oil pressure gauge installed in the ATI vent pod. Follow this install guide, its rock solid http://theattack.rallysportdirect.co...r-ssubaru-brz/
If your not first your last - Ricky Bobby
| The Following User Says Thank You to HotlavaFRSGT86 For This Useful Post: | CHMBRZ (04-13-2017) |
#51 |
Gauge
Would'nt let me upload 2 pics at a time, so heres a pic of the Defi gauge in my air vent. Looks good in there too and very responsive, should be for what they cost, lol, but u got to pay for quality.
#52 |
Drives: 2016 FRS
#53 |
Drives: 2015 Raven FRS
#54 |
Drives: 2013 FRS
Bringing thread back with some questions regarding oil press gauge, which I'm installing due to other issues and wanting to keep an eye on oil.
I snapped a brass oil galley adapter at 27 ft/lbs, using my craftsman torque wrench. Only mentioning the brand as it is more accurate than my harbor freight for lighter torque numbers. I read that 27 was OEM spec. 1.) Anyways, because of this I'm a little concerned with long term use, and removal of the brass fitting down the road. Has anyone had issues removing the brass oil galley plug after it has been installed for a period of time? 2.) There are steel oil galley plug adapters, any issues running these? Good bad? |
#55 | |
Drives: Crapcan
https://www.air-way.com/Assets/n2upl...structions.pdf |
#56 | |
Never use brass or aluminum in a high vibration area. (AKA screwed into a block) Steel is always good. |
| Oil Pressure and Temp Gauge Install | BokChoiTV | Cosmetic Modification (Interior/Exterior/Lighting) | 14 | 12-29-2015 07:19 PM |
| Defi Oil Pressure Gauge and Cravenspeed Flexpod Gauge Mount Install and Review | Tye300 | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 05-22-2015 01:48 PM |
| DIY request: Gauge install and wire routing | mikepaul21 | DIY (Do-It-Yourself) Guides | 3 | 07-05-2014 01:43 PM |
| Plot your oil pressure vs temperature | Gords_zenith | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 04-22-2014 07:09 PM |
| Temperature Gauge a dummy gauge? | bambbrose | BRZ First-Gen (2012+) — General Topics | 40 | 08-19-2012 05:29 PM |
