#29 |
Drives: 10 Series #974 6m/t
Mythbusted
#30 |
Drives: 2013 FRS Whiteout
I love that this old thread is still up for debate!
#31 | ||
Drives: '15 BRZ RA
Personally, I don't like to play with the ECU tables and values. I did this once in another car with the FB20 engine, but I don't want to do it again. In the other car, the results were as stated before. I had a better drivability and the reason was not that I didn't floored the gas pedal. Anyway, I already ordered a sprint booster kit. I'll receive it today and install it tomorrow. I'll provide afterwards feedback. |
| The Following User Says Thank You to nikitopo For This Useful Post: | steve99 (05-13-2016) |
#32 |
Drives: '15 BRZ RA
I drove my car today with the sprint booster. It is the best modification I've ever done. The difference is much bigger in comparison to a similar modification in the FB20 engine. The FA20 engine has much more potential! Overall, my car is now very different in the mid-low range with much more torque. I am very happy with the change. I definitely suggest this modification.
#33 |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
This item is ideal for all those people that have leased their car. They don't want to do anything permanent, yet they want more power. So, for all those out there who want more power, but want it easily returnable to stock for lease return or dealer service, here is the product for you. It doesn't say anything about mileage though, so count on your city mileage going down.
If I say yes, will that make you think I understand?
#34 | ||
I'm confused why are people saying this gives more power and torque, all it does is remap throttle response. I won't believe this scam till someone shows dyno proof it gained power. This isn't a worthwhile mod, its a farce that gives you the assumption of speed, power and a "better torque range" as you described, buy an open-flash tablet and you can actually get some real results.
| The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | humfrz (05-14-2016) |
#35 |
Reminds me of back-in-the-day when some folks would drill out the jets in a carburetor.
Yes, that would let more gas into the intake manifold, but, without changing the cam, all that it did was ....... burn more gas ....... car didn't go any faster ...... ![]() humfrz |
| The Following 3 Users Say Thank You to humfrz For This Useful Post: |
#36 | |
I've re jet a carb on a friends car and bear in mind how young we are I dropped the float needle and lost it somewhere underneath the car, it wasn't a good day after that.
| The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | Tcoat (05-17-2016) |
#37 |
a cheap (free) easy alternative to this is to just push the gas pedal further... come on now, are you guys afraid of going past that halfway mark on the pedal?
| The Following 2 Users Say Thank You to ryoma For This Useful Post: | FRSBRZGT86FAN (05-14-2016), humfrz (05-14-2016) |
#38 | |
![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Tcoat (05-17-2016) |
#40 | |
Further and faster
#41 |
Drives: 2013 Sprintex SuperCharged FRS
I get it
When I used to have a 2000 MustangGT, it had 2 throttle return springs. I removed one spring and instantly got quicker throttle response! It didn't make it any faster, but it did make it much more responsive and fun to drive.
So I can see the point of this product assuming it works as advertised.
2013 FRS, 6Speed. HeavyDuty Clutch, AluminumFlywheel, Bilstein Coilovers, Sprintex SC w/small pulley, E85FlexFuel, WhitelineFrontSwayBar, Michelin PilotSuperSportTires, DeliciousTuning/Ecutek, AP Racing BBK, Carbon Fiber DriveShaft, JDL UEL Exhaust, Big Radiator, Oil Cooler, Ventilated Carbon Fiber Hood, Carbon Fiber Rocket Bunny Kit, Carbon Fiber Interior pieces, and a bunch of other stuff!
#42 |
I think there is something being overlooked here. The ECU's sensitivity to voltage changes is increased by this adapter. As any OFT user can tell, throttle sensitivity drops after loading a tune. I think this is because the signal is below a certain threshold, and the ECU drops that threshold over time as it "learns". I think the "off-idle" transition is at a very low signal strength, and is hard for the ECU to recognize, immediately after a flash. If this adapter sends a more recognizable signal to the ECU, it would eliminate that "off-idle" delay that infuriates every drive-by-wire performance driver.
| TOYOTA EMBLEMS FOR YOUR FRS! @ PURE AUTOMOTIVE PERFORMANCE | Pure Automotive | Exterior Parts - The Rest | 12 | 02-18-2013 05:36 PM |
| Anybody want to help me pick up my car at Pure Automotive? | TyperRspec789 | Mid-Atlantic | 4 | 01-31-2013 02:07 PM |
| Anyone tried the Sprint Booster? | Black Tire | Engine, Exhaust, Transmission | 6 | 01-27-2013 04:13 PM |
| Throttle Controllers | harajukukei | Engine, Exhaust, Transmission | 31 | 07-28-2012 12:40 AM |
