Old 05-13-2016, 06:38 PM   #29
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by SlammedSilly View Post
it was not leaking the first two weeks after install, i noticed it tuesday night leaving a car meet, the leak came from no where
See? This is the type of info relevant to the discussion at hand and can save you two pages of trolling.
From your original post, I read it to be like you've had a leak ever since you installed it, not "a leak developed two weeks after I installed the header"
Relevant, useful information helps diagnosis. You still have 5 sources of leaks, you should figure out where by putting the car up on a lift or jackstands and go from there.
-alex
nickmerronesucks (05-13-2016)
Old 05-16-2016, 10:23 AM   #30
SlammedSilly
Drives: 2015 Ultramarine FR-S
saturday looked at everything, no leak... i came to the conclusion it was the gas that i put in the car, went to a different gas station and my assumption is that it was just burning in a different matter than what my car is used to... mind you i only fill up at sunoco and time to time shell and BP. there is only 1 shell station i use thats somewhat local, and same thing with the BP. the sunoco, i got to two close ones to my house...
but the fuel that i got that that i believe was making the car sound like it had an exhaust leak was from OMEGA Fuels... basically like a BP, bought gas there before and never had an issue
SlammedSilly is offline   Reply With Quote
Old 05-16-2016, 10:38 AM   #31
mav1178
mav1178's Avatar
Please tell me how you came to this conclusion...
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
JazzleSAURUS (12-10-2020), OkieSnuffBox (05-16-2016)
Old 05-16-2016, 10:46 AM   #32
SlammedSilly
i came to this conclusion bc
1. theres no leak
2. their fuel burns quicker bc race gas, so my assumption is that is was making exhuast fumes react differently (GUESSING)
3. if you wanna diag my car, youre more than welcomed to come take a look and tell me otherwise
4. since i there is no more fuel in my tank from omega fuels, and i filled back up with sunoco, i havent had the "exhaust leak"
Old 05-16-2016, 10:56 AM   #33
mav1178
mav1178's Avatar
1. theres no leak
1) good
2) today I learned that race gas makes exhaust fumes react differently
3) I will, please book me on AA700/AA701 RT and I'll take care of the rest.
4) just because you changed fuels makes no difference on how your header sounds.
I recently put on a Tomei UEL, drove ~4000 miles to/from TX, used anywhere from 88 to 93 octane gas across a variety of gas stations. Never had any issues with exhaust sounds and it still sounds like it's leaking because it's an aftermarket thin-walled header.
But, you know, race gas makes your car sound different.
-alex
JazzleSAURUS (12-10-2020), nickmerronesucks (05-16-2016)
Old 05-16-2016, 11:00 AM   #34
SlammedSilly
1) good
-alex
ok "bro" you tell me what is could be, please... im waiting.
if the "leak" is gone after not using that gas anymore, then what could it be? please tell me... ill pay you $300 to come diag my car.
Old 05-16-2016, 11:05 AM   #35
mav1178
mav1178's Avatar
I have no idea, because it took you 3 pages to come out with relevant info about the car such as "it was fine for 2 weeks, then it started to sound like it was leaking"
I'm not waiting another 3 pages of noise in this thread for other relevant information to be revealed. Your $300 should be better spent trying to find a local, qualified mechanic to diagnose your issue, because it's clear others on the internet can't figure out what is wrong with your car from the information provided by you.
Or... you can just follow what I provided previously:
It's very simple, you have what seems to be a leak and there's really only 5 things that can leak:
1) head/manifold gaskets, either from improper torque spec or reusing old gaskets, or bad seal from gasket surface being contaminated
2) header leak from weld or slip-joint failure
3) overpipe gasket leak, same as #1
4) thin walled header making you think there's a leak
5) O2 sensors not properly torqued down
-alex
Old 05-16-2016, 11:08 AM   #36
SlammedSilly
-alex
i had a master tech look at it with me, so we are both wrong? your "trolling" is pointless, youre not gonna win
Old 05-16-2016, 11:09 AM   #37
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
did you try exhaust leak fluid additive?
797Performance.com
nickmerronesucks is offline   Reply With Quote
The Following User Says Thank You to nickmerronesucks For This Useful Post:
Spartarus (05-16-2016)
Old 05-16-2016, 11:23 AM   #38
mav1178
mav1178's Avatar
I don't have to win, it's your car that is in need of diagnosis.
-alex
JazzleSAURUS (05-19-2016)
Old 05-16-2016, 12:51 PM   #39
speeddemon
Drives: Scion frs
lol.....entertainment at work, thanks guys
speeddemon is offline   Reply With Quote
The Following User Says Thank You to speeddemon For This Useful Post:
brandonblt2 (05-16-2016)
Old 05-16-2016, 02:34 PM   #40
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
How about a comment that is constructive, for a change. To the OP, fill up at Omega fuels to see if it starts making that sound again. Then, disconnect the negative battery terminal for 10 seconds and reconnect it. Start and drive the car. Is the sound still there? That might be all it takes to eliminate the sound, because it starts the ECU learning cycle over, and it will learn what's best for that fuel. When noises suddenly appear, I have found that the car's tune is much more relevant than anything mechanical, and disconnecting the negative terminal is the quickest and easiest way to determine if the tune is the problem.
If I say yes, will that make you think I understand?
KoolBRZ is offline   Reply With Quote
Old 05-16-2016, 02:55 PM   #41
NOT A FLAME real question:
What makes it "race gas" and why does it "burn quicker"?
SlammedSilly (05-16-2016)
Old 05-16-2016, 03:25 PM   #42
SlammedSilly
higher octance fuel burns off quicker hence "race gas"
OpenFlash Header (OFH) Cracked--Worth Fixing? gonzo Engine, Exhaust, Transmission 9 12-27-2015 05:55 PM
Cracked block? seant2h Engine, Exhaust, Transmission 18 09-03-2015 01:24 PM
cracked header Jonesy86 Northwest 21 02-09-2015 09:13 PM
Cracked Oil Pan?! Jolaessss Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 11-21-2013 02:28 PM
Cracked Rim SmsAlSuwaidi Issues | Warranty | Recalls / TSB 29 04-02-2013 01:30 PM
