Old 07-06-2015, 01:54 AM   #29
Teclis
Marine Electrician
Teclis's Avatar
Drives: Toyota TRD86, 2014
I suggest people to check this out: http://www.ft86club.com/forums/showt...12#post2310412
Hopefully I can use the pressure sensor relocating kit from fastwrx (no I do not by any means have anything to to with them) http://www.fastwrx.com/products/remo...re-sending-kit
And cross my fingers for that the mishimoto housing's place for sensors are big enough for the innovate temp sensor
Teclis is offline   Reply With Quote
Old 07-06-2015, 09:02 AM   #30
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
That's what we said
lbroskee is offline   Reply With Quote
Old 12-29-2015, 06:07 PM   #31
FR-Shred
FR-Shred's Avatar
Quick question. I ordered a innovate MTX pressure/temp gauge today. I am trying to get the required accessories ordered asap so I can instal when I get it.
For temp I have:
http://www.rallysportdirect.com/shop...hreaded-center
And
http://www.rallysportdirect.com/shop...ey-plug-gasket
For the pressure I wouldn't mind replacing the oem pressure or doing a T fitting. What parts/adapters would be needed for either one of those?
Are the two parts listed for the temp the correct ones?
FR-Shred is offline   Reply With Quote
Old 12-30-2015, 11:11 AM   #32
dustmann
Drives: '14 WRB BRZ Limited
DIY Request: install Oil Pressure & Temperature gauge
That is the wrong (NPT) galley plug for the innovate sender. You need the silver (PT) adapter.
Link: http://www.rallysportdirect.com/shop...il-galley-plug
See my post #8 for the autometer adapter for the pressure sender (p/n 2269). I would not recommend using a t adapter as it may break over time and create an oil leak. The gauge can be programmed to indicate low pressure.
dustmann is offline   Reply With Quote
The Following User Says Thank You to dustmann For This Useful Post:
FR-Shred (12-30-2015)
Old 12-30-2015, 07:32 PM   #33
FR-Shred
FR-Shred's Avatar
See my post #8 for the autometer adapter for the pressure sender (p/n 2280). I would not recommend using a t adapter as it may break over time and create an oil leak. The gauge can be programmed to indicate low pressure.
Sweet. I got it all ordered. If I have any other issues I'll be sure to ask here!
Old 01-05-2016, 11:07 PM   #34
dustmann
Sorry for the confusion @FR-Shred I have corrected the part number. You need the 2269 1/8 bsp to npt adapter for the pressure sender
FR-Shred (01-06-2016)
Old 01-06-2016, 10:03 PM   #35
FR-Shred
FR-Shred's Avatar
Thanks again!
Anyone in the same situation but auto meter #2269 NOT 2280 haha.
Old 05-13-2016, 01:50 AM   #36
Arcade_West
Drives: Subaru BRZ
does anyone have a diagram of wiring the gauge in? not sure which wires to tap into for power supply and dimming.
Arcade_West is offline   Reply With Quote
Old 05-13-2016, 10:10 AM   #37
ChrisD
ChrisD's Avatar
Drives: GT86
I'm looking for the exact same thing. Got the oil pressure sensor installed fine but have no idea how to actually wire the gauge up for power on my Blitz gauge. The instructions with it just say this:
Red (+B): To battery(+); Constant 12V power
Orange(IGN): To power line with IGN ON
Yellow (ILM): To illumination power line
Black (GND): To battery (-); GND
But I don't know where to find a "power line with ignition on" and an "illumination power line" as I've never done anything with car electronics before.
My GT86 build so far:
AVO Stage 4 Turbo, Carrillo forged con rods, 10:1 CR Carrillo pistons, AVO 3 inch turbo back exhaust, Helix clutch, TheDriveShaftShop drive shafts, lightweight flywheel, NamelessPerformance hydraulic hand brake, KW V3 coilovers... and lots of other little bits
ChrisD is offline   Reply With Quote
Old 05-13-2016, 10:26 AM   #38
dustmann
I'm pretty sure I used a fuse tap on the seat heater for power and fog lights for illumination on my car. The fuse box lid will have a diagram for where these are located. There is also a convenient ground near the fuse box.
Old 05-13-2016, 10:31 AM   #39
dustmann
Also I believe the STOP fuse is a hot fuse (I.e 12v constant).
See here: http://www.ft86club.com/forums/showthread.php?t=86658
Old 05-13-2016, 11:00 AM   #40
nunonuna
nunonuna's Avatar
• 12v constant: There is one blank fuse slot which is constant 12v. You can use fuse tap there. Refer here http://www.ft86club.com/forums/showthread.php?p=1005795
• 12v ignition: siga jack in the glove box or stereo fuse slot.
• Ground: choose whatever you can pick from bunch of ground points.
• Dimmer: tap the purple wire from harness of factory dimmer switch
nunonuna is offline   Reply With Quote
The Following User Says Thank You to nunonuna For This Useful Post:
Initial_RD (06-08-2016)
Old 05-13-2016, 03:08 PM   #41
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
why don't you just get an m18x1.5 to 1/8 adapter and tap into the oil galley plug like you should?
For pressure only, you could also buy a T adapter disconnect factory sensor(green wire) and replace with the T adapter and both sensors plugged (can't also do temp here as it is not in the flow).
fumanchu1 is offline   Reply With Quote
Old 05-13-2016, 03:12 PM   #42
fumanchu1
For temp I have:
And
1/8 npt t shaped adapter is all you'll need if you already have the oil galley plug converter (temp in oil galley, pressure in stock location with the T) or as others have ssaid you can apparently just leave the stock sensor unplugged and it doesn't cause any adverse issues (no cel, no light, no problem)
Oil Pressure and Temp Gauge Install BokChoiTV Cosmetic Modification (Interior/Exterior/Lighting) 14 12-29-2015 06:19 PM
Defi Oil Pressure Gauge and Cravenspeed Flexpod Gauge Mount Install and Review Tye300 Cosmetic Modification (Interior/Exterior/Lighting) 10 05-22-2015 12:48 PM
DIY request: Gauge install and wire routing mikepaul21 DIY (Do-It-Yourself) Guides 3 07-05-2014 12:43 PM
Plot your oil pressure vs temperature Gords_zenith Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-22-2014 06:09 PM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 04:29 PM
