Old 05-07-2016, 11:49 AM   #911
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by super josh View Post
Thanks for the details Sojhinn Just to follow on from Algreen's post, presumably this aux charger runs in parallel to the existing charger to take some of the strain off it and, as you say, stop it going into one of its heat protection modes?
You mention that you are successfully running an aux charger, is it this model or something else?
Thanks again for more insight,
Josh
Yes, you run this in parallel with the controller. Both will charge the system.
The controller still has a possibility of entering the thermal protection modes but it significantly increases the time it takes to enter those modes.
As for my aux charger? No, I don't have this one. Rob used to make them and about 8-10 of us are running them. They even tied into the controller.
I think due to cost and time he saw that these do the same for a lot less.
Installed Mods:
Old 05-07-2016, 10:33 PM   #912
stevo585
Drives: White 2014 BRZ
I'm going to track my car soon at PBIR and I wonder if the ESC will hold up. Gonna suck if I have to run NA. Might look into the aux but does anyone have experience with it on track sessions?
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
Old 05-08-2016, 11:08 PM   #913
stevo585
1/4 mile pass this friday May 6th.
[ame="https://www.youtube.com/watch?v=Wtz3GNckOAg"]track run 1 - YouTube[/ame]
The Following User Says Thank You to stevo585 For This Useful Post:
DAEMANO (05-09-2016)
Old 05-09-2016, 11:12 AM   #914
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
damm 1st gear shake.. i hate it.
anyway nice run.
time??
Old 05-09-2016, 10:50 PM   #915
stevo585
anyway nice run.
time??
It was probably wheel hop as I did a dry burnout. Then bogged even after a 4k launch.
14.2 @ 99.5. Too warm kills performance I have done much better in cool weather. I also was only 2.3 on the 60 ft.
The Following 2 Users Say Thank You to stevo585 For This Useful Post:
DAEMANO (05-10-2016), zc06_kisstherain (05-10-2016)
Old 05-10-2016, 04:26 PM   #916
zc06_kisstherain
Drives: SWP BRZ
@Sojhinn
still no update on new map?
i also noticed that there is no download link for ESC from website
Old 05-10-2016, 04:27 PM   #917
Sojhinn
Sojhinn's Avatar
@Sojhinn
No luck with a new map for the oft. It's aggressive already per shiv. Ask shiv for a download of the esc tune.
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
Old 05-12-2016, 06:18 PM   #918
S84kam
S84kam's Avatar
Drives: FBRZS
whats the 0-60 with the phantom supercharger?
S84kam is offline   Reply With Quote
Old 05-12-2016, 07:06 PM   #919
DAEMANO
Time Traveller
I only know Phantom ESC+E85 which is right about 5 seconds with a hard launch on decent tires.
Old 05-12-2016, 07:37 PM   #920
Sojhinn
Sojhinn's Avatar
That's about what I got with crappy tires
Installed Mods:
Old 05-12-2016, 07:53 PM   #921
DAEMANO
Time Traveller
Range should be 4.8 to 5.2. When I did my runs I wasn't using precision equipment, but I'm guess it was on the low end of that scale.
Old 05-12-2016, 11:05 PM   #922
stevo585
Be interested to see the afr and ignition advance on the OFT compared to my Ecutek tune.
On 93 pump gas I'm at 11.8 afr and 22 degrees. E85 is 12.x afr and timing high 20's not sure exactly.
I assume the OFT is probably made to work with 91 pump.
Old 05-13-2016, 01:18 PM   #923
S84kam
S84kam's Avatar
Drives: FBRZS
thats 0-60 with premium fuel?
Old 05-13-2016, 02:12 PM   #924
DAEMANO
Time Traveller
e85.
My guess is that pump gas will put you in the ~5.2 - 5.5 ish range with a hard launch and decent tires. Primacy's will probably cost you a couple of tenths above that.
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6049 06-25-2026 10:40 PM
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
phantom supercharger restrictions? Shinigunz Forced Induction 12 05-13-2014 03:28 AM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 09:51 AM
