Old 05-11-2016, 03:17 AM   #43
Kostamojen
Originally Posted by PandaSPUR View Post
But yea, no way to adjust camber in the rear without aftermarket control arms.
The Subframe spacers from a Crosstrek would do the trick. That plus larger tires and a mild lift. Wouldn't be too much positive camber with that combination.
Old 05-11-2016, 03:30 AM   #44
churchx
churchx's Avatar
Drives: 2014 GT86
PandaSPUR: issue is relatively low ground clearance even for stock for rally-ish driving on gravel roads with potential roadholes/jumps or in deeper snow. Those plastic panels (mostly meant not for protection, but to decrease air drag)/mud flaps (to save somewhat bumper paint from chips) won't do much protecting from scraping engine/bottom. While rally sump underguard panels may help with protection when you do scrape/hit, better would be prevent scraping/hits by avoiding them completely with more ground clearance.
Old 05-11-2016, 10:51 AM   #45
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Yea I understand that, I wasn't pointing to those underpanels as protection in a rally style race or for offroading. I assumed "farm roads" meant still relatively normal/level roads, but just with dirt and gravel.
Old 05-11-2016, 12:36 PM   #46
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by Hot Wheels View Post
I saw that Subtle Solutions has a premade 1" kit like this one. I know fooling with suspension requires an alignment after, but would raising it the 1" put too much positive camber on the rear? I've tried looking into being able to adjust rear camber for cheap, but all I've found was expensive control arms. Sorry, but you'll need to keep it simple with me, as I am just learning about our cars. I live in Kansas around a lot of dirt/gravel farm roads, and the extra ground clearance would give me more peace of mind.
Ran for a winter with the Lift kit and didn't seen any adverse tire wear. You can get a set of SPC LCAs for like $230. Which in the grand scheme of things isn't too bad.
The Following User Says Thank You to DustinS For This Useful Post:
BigFatFlip (05-11-2016)
Old 05-11-2016, 12:42 PM   #47
IPGJames
Drives: ...Cars...
Originally Posted by DustinS View Post
That looks badass
IPGJames is offline   Reply With Quote
Old 05-11-2016, 01:12 PM   #48
Freeman
Freeman's Avatar
Sounds like a rally build would be right up your alley. Nameless Performance Rally BRZ on the bottom. liftedbrz from Instagram on the top.
Freeman is offline   Reply With Quote
Old 05-11-2016, 01:55 PM   #49
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
How much ground clearance are you trying to get? You might be able to get away with a combination of 1/4" or 3/8" spacers and a "taller" tire. I've looked into it myself and took some measurements on the trailing arm. Seemed to only result in minimal (+) camber. I was able to do my TSD (on gravel/dirt fire roads) by just cranking up the ride height on my ohlins and using an old set of 225/60 I had laying around. Handled like crap, but did the job
^this (looks badass btw!). Its been a while since I've looked at the subtle solutions website, but it looks like they now sell SPC LCAs and "alignment correction" kits. I've never liked the lack of detail on their website, but I've found them to be very responsive with e-mail.
The Following User Says Thank You to BigFatFlip For This Useful Post:
DustinS (05-11-2016)
Old 05-11-2016, 02:02 PM   #50
DustinS
DustinS's Avatar
You can also look into Anderson Design and Fabrication. He takes into account camber setting and adjusts his kits accordingly. So Camber stays within Factory specs. He has a lot of great products and good customer service as well. Can't really go wrong with either company.
Old 05-11-2016, 03:17 PM   #51
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I wonder if the stock LCAs can't be reinforced and then re-drilled. A bit low-rent, I'm sure, but then so is a threaded rod end in bending, which is what every single adjustable solution uses for our platform.
There's also the whiteline camber bushings.
Old 05-11-2016, 03:26 PM   #52
DustinS
DustinS's Avatar
Both SPC and the Whiteline LCAs are almost exactly like stock arms with a slotted adjustment. Plus it is adjustable.
Old 05-11-2016, 03:47 PM   #53
EAGLE5
Dismember
EAGLE5's Avatar
I believe the SPC control arms have reports of snapping bolts in that slot. Hence me not suggesting slots.
Old 05-15-2016, 04:33 PM   #54
Hot Wheels
Drives: 2014 WRB BRZ Limited
What size wheels and tires are those? I think I have decided that 16 inch wheels with meatier tires on stock suspension could be my solution for now, considering that for every 10 miles on farm roads I do 100 highway. I need a middle ground approach.
Hot Wheels is offline   Reply With Quote
Old 05-16-2016, 10:01 AM   #55
DustinS
DustinS's Avatar
16x6.5? WRX Wheels with 215/65/16 You would not be able to fit these with stock suspension. This requires a 1" lift
Where to Lift with Two Post Lift? Don Ivey Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 08-18-2022 08:51 AM
Lift rental Calidrifter Southern California 15 06-04-2013 10:23 PM
EZ Car lift RRnold Other Vehicles & General Automotive Discussions 13 11-09-2012 04:20 PM
How to lift? Mo707 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 08-28-2012 12:57 PM
don't lift pr086 Scion FR-S / Toyota 86 GT86 General Forum 27 08-17-2012 11:51 AM
