Old 05-03-2016, 01:37 AM   #43
Originally Posted by 86kahl View Post
By loosening my spark plugs a couple of turns, how many do u guys usually go? I did two last night and my car sounded mean, like a chopper😁
If you want to lower the compression on your engine, simply remove the piston rings.
JD001 (05-03-2016)
Old 05-03-2016, 02:56 AM   #44
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
F this, I'm raising my compression. I'ma gonna smear some JB weld through the plug holes onto the piston tops and spin the engine by hand before the stuff dries to form domes. Science, bitch!
Old 05-03-2016, 03:11 AM   #45
JD001
JD001's Avatar
Drives: Subaru BRZ
Spinning the engine by hand is a great idea as the newly shaped piston heads will softly kiss the valves to get them to match the curvature.
Old 05-03-2016, 05:45 AM   #46
Just inject some water. Since water will not compress then it reduces the air space and increases the air compression without creating a hard surface that could get hit.
#bettersciencebitch!
Tectoniic (05-03-2016)
Old 05-03-2016, 06:03 AM   #47
themadscientist
Hotlink Terrorist
Actually, all kidding aside, I'm looking at water/meth injection for the R to stave off detonation.
The Following User Says Thank You to themadscientist For This Useful Post:
86kahl (05-03-2016)
Old 05-03-2016, 06:08 AM   #48
Yep. War Emergency Power has been around a long time.
Old 05-03-2016, 06:10 AM   #49
themadscientist
Hotlink Terrorist
If I recall, that's where they first started injecting nitrousoxide too.
Old 05-03-2016, 08:29 AM   #50
Yes. That was the way the Germans got emergency power in their aircraft. Not sure if the US used it then though.
Old 05-03-2016, 08:55 AM   #51
HunterGreene
Hail Magnet
HunterGreene's Avatar
Ok, possibly dumb question, but what is the purpose of the scoop on the bottom of that plane? First answer is engine cooling, but placing it that far back seems unnecessarily complex.
It has priests in it?
Old 05-03-2016, 08:55 AM   #52
xmadror
Drives: BRZ Sport Tech 13
at least with the frs you'll only replace tires and not the hood !
xmadror is offline   Reply With Quote
The Following 2 Users Say Thank You to xmadror For This Useful Post:
86kahl (05-03-2016), ScoobsMcGee (05-03-2016)
Old 05-03-2016, 09:13 AM   #53
It is cooling. It is back there for aerodynamic reasons. Simple case of the less on the front of the plane the better.
86kahl (05-03-2016), Dadhawk (05-03-2016), HunterGreene (05-03-2016)
Old 05-03-2016, 11:26 AM   #54
JD001
JD001's Avatar
Drives: Subaru BRZ
And I was thinking that you were going to say that the scoop lowered compression.
The Following User Says Thank You to JD001 For This Useful Post:
Old 05-03-2016, 12:36 PM   #55
Well technically that is exactly what it does. Just on the outside of the plane instead of in the engine.
HunterGreene (05-03-2016), JD001 (05-03-2016)
Old 05-03-2016, 12:51 PM   #56
Yep, the P51 was water-cooled, so the radiator had to be somewhere besides "in front" (most WWII era prop driven airplanes were air-cooled hence the big front ends on them)
Here's the airflow. This actually contributed to the P51s superior speed, and really wasn't that complex, it was just a good place to pick up air without adding drag.
HunterGreene (05-03-2016), Tcoat (05-03-2016)
HKS Stroker Kit or Lower Compression Setup? Efferalgan Engine, Exhaust, Transmission 4 05-02-2016 03:58 AM
Low compression? Venator Engine, Exhaust, Transmission 4 06-17-2014 10:37 AM
Lower Compression with Headgasket Team STILLEN Engine, Exhaust, Transmission 28 12-15-2013 05:26 PM
Low Compression - 10:1 // 9:1 1086 Engine, Exhaust, Transmission 12 12-13-2013 05:46 PM
High compression engine fuel requirements Ben_G Engine, Exhaust, Transmission 3 01-16-2013 11:44 AM
