Old 05-01-2016, 03:40 AM   #1
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
HKS Stroker Kit or Lower Compression Setup?
Since my engine seems to be dying (http://www.ft86club.com/forums/showthread.php?t=104222) I decided to upgrade internals rather that rehauling the stock block.
Unfortunately I am still on HKS v2 SC (my 2nd as the first one died after 5000 miles) and will keep it till its inevitable death a bit down the road. Currently it is with the 43 mm restrictor which allows it to blow 0.75 bar = 11 psi. Unrestricted this thing could blow up to 1 bar =14.5 psi which I'm planning to do upon upgrading internals. Delicious Tuning T&G tune currently, will either ask Bill for remote tuning after upgrade of internals or will have to dyno tune it with one of local guys who apparently gained some expreince with FA20 by now.
The question I have now is whether to lower the compression to 10 and go with some Carillo/CP rods/pistons set or go full HKS and put a stroker kit + maybe camshafts too:
http://www.hks-power.co.jp/en/produc...city/fa20.html
With 1 mm HKS gasket it should be about 12 compression ratio.
I've seen recently a number of posts on this forum against lowering compression for not super powerfull 450-500+ hp builds which is my case (320-340 at 14.5 psi is the expected outcome of the exercise). Curious to hear other opinions!
Efferalgan is offline   Reply With Quote
Old 05-01-2016, 06:37 AM   #2
R2RO
R2RO's Avatar
Drives: 2013 FR-S, 2013 FR-S(2JZ Build)
Keep the stock compression if you plan on staying sub 500 hp, my 2 cents.
R2RO is offline   Reply With Quote
The Following User Says Thank You to R2RO For This Useful Post:
Efferalgan (05-01-2016)
Old 05-01-2016, 07:58 AM   #3
Teseo
Drives: frs
HKS for staying N/A and low comoresion if force induction is on the table?
Old 05-01-2016, 07:16 PM   #4
Efferalgan
Nope. FI (HKS v2 Supercharger) in both cases. NA is off the table.
Old 05-02-2016, 03:58 AM   #5
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Dont lower compression via headgasket. Use aftermarket pistons.
Toda 2.3 stroker kit brn12345 Engine, Exhaust, Transmission 116 09-29-2016 08:47 PM
JRP-New Greddy Stroker kit now available Stav Canada Classifieds 4 12-25-2014 04:12 AM
FRS stroker kit? chiefshayan Engine, Exhaust, Transmission 78 01-21-2014 08:58 AM
Lower Compression with Headgasket Team STILLEN Engine, Exhaust, Transmission 28 12-15-2013 05:26 PM
Stroker Kit for the love of god!!! FAER Engine, Exhaust, Transmission 24 08-03-2013 05:54 PM
