Old 05-02-2016, 09:22 PM   #141
alxtheoreo
alxtheoreo's Avatar
Originally Posted by Vracer111 View Post
Still stock suspension 4 years on. A new set of tires just put on last week, finally trying out the Continental ExtremeContact DW - in 205/45-17 (my preferred tire size for this car) on the 17x7.5 +40mm offset Enkei Fujins (which I love, perfect match for the car):
How is it with the 205 width, versus 215?
Sent from my SCH-I545 using Tapatalk
Invidia catless FP & Q300. Enkei TS-10s. Conti ExtremeContact Sport tires. Hawk HPS pads. Centric Rotors.
alxtheoreo is offline   Reply With Quote
Old 05-02-2016, 09:59 PM   #142
Mr Nerd
Mr Nerd's Avatar
Originally Posted by turbocat View Post
Apex Racing ARC-8, 17x9 42, race silver, 225/45/17 Hankook RS3
Stock suspension
Front Camber -1.4
The exact set up I've been researching lately.
Do your tires rub at all during tight turns?
Mr Nerd is offline   Reply With Quote
The Following User Says Thank You to Mr Nerd For This Useful Post:
turbocat (05-03-2016)
Old 05-02-2016, 10:00 PM   #143
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Not a negative change in tread width over stock... most 205/45-17 tires are as wide or wider than stock 215 Primacy's, even the 205 Primacy is the same width. So you have the same or slight larger than stock contact patch.
For comparison here are the stock Primacy's and 205/45-17 Kumho Sport LE:
215/45-17 Michelin Primacy HP
205/45-17 Kumho Ecsta Sport LE
205/45-17 get you a lower CG, lowest weight in 17" performance tires, a better match to a 7.5" width wheel for immediate and precise handling, and quicker response to throttle due to slight better gearing advantage with the reduced diameter and lighter weight. Basically it quickens and sharpens the cars reflexes with an extremely slightly better ride quality while still being more stable than stock with much more grip (because tire compound not tire width is what counts for grip). Car is an absolute riot... especially in the wet on these Continental DW tires!
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
The Following 4 Users Say Thank You to Vracer111 For This Useful Post:
alxtheoreo (05-02-2016), freerunner (05-08-2016), Mr.Impreza (05-24-2016), Varelco (07-18-2016)
Old 05-02-2016, 10:10 PM   #144
alxtheoreo
alxtheoreo's Avatar
That's great to hear! I'm actually gonna buy this setup later this month, yet with 215 width.
Old 05-02-2016, 10:25 PM   #145
Vracer111
Vracer111's Avatar
Why not try 205/45-17 size? They cost less and are lighter for being almost the exact same width...
Old 05-02-2016, 10:50 PM   #146
alxtheoreo
alxtheoreo's Avatar
How's the sidewall stretch?
I've seen a few 7.5 on a 215/45, yet never a 7.5 on a 205/45.
Old 05-03-2016, 01:45 AM   #147
Vracer111
Vracer111's Avatar
About the same stretch as the stock tires on 7.5" wheels. If you noticed in the pictures from my previous post, the stock 215/45-17 are actually more stretched than the 205/45-17 Kumho's, because the Kumho's have a wider tread. 205/45-17 tires are designed for fitment range of 6.5"-7.5" wide wheels... and 7.5" is perfect width since that is the tread width as well...if you are looking for the best responsiveness from it, especially with softer sidewall tires.
The Following User Says Thank You to Vracer111 For This Useful Post:
alxtheoreo (05-03-2016)
Old 05-03-2016, 07:11 AM   #148
alxtheoreo
alxtheoreo's Avatar
Thank you for the information. I'll need to reconsider my tire selection. Lol
Old 05-03-2016, 03:28 PM   #149
turbocat
turbocat's Avatar
Drives: 13 BRZ SSM
No Rub. Just ran an Auto-x, once the tires were warm the car was very grippy with the RS3s in 225 width tires. I'm still stock power.
If I increase tire width(235 or 245) with the next set of tires i'm a little worried about the side wall touching the stock lower spring perches in the front. I'll have to see when its time for new tires in the future.
I know my stock ride height is not cool looking, but I really enjoy the stock suspension. It is leaps and bounds better than stock WRXs I've owned. I'm really on the fence about getting any suspension mods (spring/struts, or coilovers). I've owned both before on other cars.
turbocat is offline   Reply With Quote
The Following User Says Thank You to turbocat For This Useful Post:
Mr Nerd (05-03-2016)
Old 05-03-2016, 05:23 PM   #150
lupindub
Drives: Scion FR-S
I would say a 235 width tire because it's the minimum measured width for a 8" wheel. Or if you want to keep the same width, go up in profile.
What?! I'm pretty positive 215's are the minimum width for 8 inch wheel's albeit a slight stretch.
lupindub is offline   Reply With Quote
Old 05-03-2016, 05:28 PM   #151
alxtheoreo
alxtheoreo's Avatar
8" is the MAX width for most 215s. The MINIMUM will be 7"
The Following User Says Thank You to alxtheoreo For This Useful Post:
lupindub (05-03-2016)
Old 05-03-2016, 11:49 PM   #152
lupindub
Drives: Scion FR-S
Originally Posted by JonAvalon View Post
5zigen fno1rc 17x8 +35 offset
Hankook Ventus V12 Evo2: 215/45-17
Even though the tire setup is temporary, I'm digging it for stock height.
Is it just me or do these tires hardly look stretched? I was told that 215's on 17x8 will make the tire look stretched but these look normal...
Old 05-04-2016, 12:26 AM   #153
JonAvalon
SCBYD0
JonAvalon's Avatar
Drives: 18 BRZ (WRB)
Yea it can depend on the tire. If you were to do it on the stock primacy the stretch would be way more noticeable. I was surprised it wasn't that stretched on the Hankooks but in person you might be able to see it.
JonAvalon is offline   Reply With Quote
Old 05-24-2016, 04:31 PM   #154
lupindub
Drives: Scion FR-S
Enkei RP03 on stock tires. 17x9 +25 on the front and 17x9 +20 in the rear.
The Following 3 Users Say Thank You to lupindub For This Useful Post:
Mr.Impreza (05-24-2016), SStratos (09-28-2017), Tcoat (05-24-2016)
Aftermarket lug nuts on stock wheels: confirm? empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 09-19-2018 07:38 PM
Aftermarket wheels with stock suspension Thongpocket Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 01-24-2013 05:08 PM
Stock TPMS's with aftermarket valves/wheels? Phaedrus29 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-17-2012 01:18 PM
Need help with Stock height measurement D1cker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-03-2012 03:30 AM
Aftermarket wheels on stock BRZ/86s yajin BRZ Photos, Videos, Wallpapers, Gallery Forum 2 05-01-2012 02:52 AM
