#15 | |
Are you sure you're doing it correctly?: http://www.ft86club.com/forums/showthread.php?t=7975 I'm lucky the TRD intake is much bigger but somehow less cumbersome to mess with
#16 |
Drives: 2015 Scion FRS
#17 |
Drives: '13 FRS - STX
Boxes confuse me sometimes, so it took me 15 minutes to get my K&N in, coming up on being due for a cleaning.
Interesting to note that the TRD is also oiled, so much for that 'oiled filters are crap and will screw up your sensors that's why OE is dry' theory... |
| The Following 6 Users Say Thank You to strat61caster For This Useful Post: | Cole (05-02-2016), FRSBRZGT86FAN (05-02-2016), Muaddib (05-03-2016), roddy (05-02-2016), soulreapersteve (05-02-2016), Tcoat (05-02-2016) |
#18 | |
#19 | |
http://forum.fdmc.org.uk/phpBB3/viewtopic.php?t=1272 |
#20 | |
Usually all the issues I've ever seen with "oiled" filters are involved with over oiling
#21 |
Space for Rent
Drives: 2014 6MT ToyoBaru86ScionMonogram?
the trd air filters are just rebadge K&n filters, almost everything is outsourced for TRD USA
#22 |
Strange, mine slid in nice and snug, clips buckled on perfectly. I dont think it would go in the wrong way so it must be right. weird.
#23 |
Talking filters here not your last date!
#24 |
| The Following 3 Users Say Thank You to humfrz For This Useful Post: |
#25 |
#26 |
Drives: 2014 Subaru BRZ Limited WRB AT
I had trouble with mine too, and after several attempts I found that the "trick" is to place the new filter on the bumper (fixed) side of the housing and then clip the box (moving) side around it. This was MUCH easier than what I was doing (which was to place the new filter in the box side and clip it with filter on to the other side).
To repeat - try placing the filter on the fixed frame and then clipping the box around it. Hope this helps.
Cosworth Drop-In Air Filter, Diode Dynamics DRL module, Perrin Tips |
| The Following User Says Thank You to Elkton86er For This Useful Post: | GoobyFRS (05-03-2016) |
#27 |
#28 |
Drives: FRS
i have an HKS drop in filter. fit perfectly and the whole thing took under 5 min. i spent more time unscrewing the bolts than swapping the actual filter.
| SOLD: LED lights, Stivo duckbill, clear corners, engraved plate fram | CaptainSlow | Exterior Parts (Aero, Lighting, Etc.) | 16 | 12-18-2015 01:59 PM |
| Cusco Oil Filter or Blitz Oil Filter | Mr.Impreza | CANADA | 6 | 10-11-2014 07:08 AM |
| OEM Subaru engine air filter + cabin air filter | autobrz | Mechanical Maintenance and Tools | 6 | 03-09-2014 09:28 PM |
| FRAM CA9482 Airfilter louder? | Pake1 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 8 | 01-19-2013 07:55 PM |
| Drop In filter test! Stock, Apexi, No filter | RallySport Direct | Engine, Exhaust, Transmission | 14 | 06-25-2012 02:40 PM |
