Old 05-02-2016, 11:38 AM   #29
JD001
JD001's Avatar
Drives: Subaru BRZ
Actually I have a question, why do you want to reduce engine compression?
Another good reliable method to help reduce engine compression:
1. Take out say 2 spark plugs
2. Poke thin screw driver into the engine
3. Carefully locate piston crown and then hit screw driver with hammer to hole the piston crown
4. Re insert spark plug
5. You may need to change the oil so that piston head bits don't wreck the engine
The Following 5 Users Say Thank You to JD001 For This Useful Post:
86kahl (05-02-2016), HunterGreene (05-02-2016), mdm (05-02-2016), Tcoat (05-02-2016), themadscientist (05-03-2016)
Old 05-02-2016, 11:44 AM   #30
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
At first I was worried that someone would read this and take it seriously. Now I'm to the point where if they do, they deserve whatever they get. Including salmonella poisoning.
The Following 8 Users Say Thank You to ScoobsMcGee For This Useful Post:
86kahl (05-02-2016), cdrazic93 (05-02-2016), clayrush (05-06-2016), HunterGreene (05-02-2016), JD001 (05-02-2016), NWFRS (05-02-2016), Tcoat (05-02-2016), Tectoniic (05-02-2016)
Old 05-02-2016, 11:45 AM   #31
86kahl
86kahl's Avatar
Drives: whiteout, dark tint
Actually I have a question, why do you want to reduce the engine compression?
Cuz I don't have money for a 2jz swap but low compression is life.
Bro stop trolling, everyone knows a screwdriver won't fit cuz boxer.
86kahl is offline   Reply With Quote
The Following 4 Users Say Thank You to 86kahl For This Useful Post:
clayrush (05-06-2016), JD001 (05-02-2016), MisterSheep (05-02-2016), Tectoniic (05-02-2016)
Old 05-02-2016, 11:46 AM   #32
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Ever tried one of those bent screw drivers?
Instagram: trevor.parque
The Following 2 Users Say Thank You to MisterSheep For This Useful Post:
86kahl (05-02-2016), JD001 (05-02-2016)
Old 05-02-2016, 12:03 PM   #33
HunterGreene
Hail Magnet
HunterGreene's Avatar
left handed or right handed?
It has priests in it?
The Following User Says Thank You to HunterGreene For This Useful Post:
JD001 (05-02-2016)
Old 05-02-2016, 02:48 PM   #34
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
Have you tried putting 87 octane in your car? I put 86 octane and the engine lets me know it lowered its compression.
Since then, I've always run 86 octane, but 87 should work just as well.
Old 05-02-2016, 03:14 PM   #35
kevman_101
Drives: 2013 Scion FRS
Your going about all wrong. Loosening the plugs is very inconsistent. Here's the secret to do it like the pros. Get a drill bit set and drill a hole through the head. Now be careful not to use a big bit at first or you might go too low compression like a scrub. Start small and go bigger to get that perfect compression. Also don't worry if ya hit a valve, they are actually just to add weight to the engine.
kevman_101 is offline   Reply With Quote
The Following 2 Users Say Thank You to kevman_101 For This Useful Post:
JD001 (05-03-2016), Tcoat (05-02-2016)
Old 05-02-2016, 03:28 PM   #36
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
I will never forget the time I was playing baseball with some friends and the one kid picks up a bat and was completely serious when he asked if it was a left handed or right handed bat
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
The Following User Says Thank You to Tectoniic For This Useful Post:
Old 05-02-2016, 03:28 PM   #37
I have looked everywhere for octane reducer but can't seem to find any. Do you have it local there?
clayrush (05-06-2016), KR-S (05-02-2016)
Old 05-02-2016, 03:58 PM   #38
KR-S
Sporadic Member
KR-S's Avatar
Never bothered to look as 86 octane was already readily available to me, but we should have some here.
The Following User Says Thank You to KR-S For This Useful Post:
Tcoat (05-02-2016)
Old 05-02-2016, 04:28 PM   #39
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
Pro tip, just add sugar and flour to the gas tank, it'll reduce octane plus it smells like cake
fumanchu1 is offline   Reply With Quote
The Following 5 Users Say Thank You to fumanchu1 For This Useful Post:
HunterGreene (05-02-2016), JD001 (05-03-2016), KR-S (05-03-2016), Tcoat (05-02-2016), Zed (05-05-2016)
Old 05-02-2016, 06:00 PM   #40
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
OP forgot the ultimate compression lowering trick. I removed my engine to bring the car down to a zero compression rating. I can now safely run infinite boost.
Checkmate high compression lovers
The Following 5 Users Say Thank You to Tectoniic For This Useful Post:
86kahl (05-02-2016), clayrush (05-06-2016), HunterGreene (05-03-2016), JD001 (05-03-2016), Tcoat (05-02-2016)
Old 05-02-2016, 06:14 PM   #41
86kahl
86kahl's Avatar
This. Thanks for your suggestions (some of you) but I've decided to ultimately swap in an SR20det. It's half the cost of a 2jz or LSx, 20 years old and pull a premium a week before race wars.
The Following 2 Users Say Thank You to 86kahl For This Useful Post:
Itsjusdame (05-03-2016), Tectoniic (05-03-2016)
Old 05-02-2016, 06:32 PM   #42
Zero compression!
HKS Stroker Kit or Lower Compression Setup? Efferalgan Engine, Exhaust, Transmission 4 05-02-2016 03:58 AM
Low compression? Venator Engine, Exhaust, Transmission 4 06-17-2014 10:37 AM
Lower Compression with Headgasket Team STILLEN Engine, Exhaust, Transmission 28 12-15-2013 05:26 PM
Low Compression - 10:1 // 9:1 1086 Engine, Exhaust, Transmission 12 12-13-2013 05:46 PM
High compression engine fuel requirements Ben_G Engine, Exhaust, Transmission 3 01-16-2013 11:44 AM
