#15 |
I think I found the reason for the confusion. Seems like Greddy USA is stating 15-20psi, but Trust Japan has that wastegate listed correct at 12psi.
#16 | ||
Drives: JDL Turbo FRS, 335SC BRZ (ret)
I would have no qualms going t620z on the stock motor, unless running 91 exclusively and doing track time. |
#17 | |
Drives: 13 10 series FRS
My high boost set up is 16.3psi. I'm also on e85 (and only using high boost while on e85) |
#18 | |
Drives: FR-S TRD RS1#1488
#19 | |
Drives: none
-Matt |
| The Following User Says Thank You to armstrom For This Useful Post: | Crazypinoy9 (05-02-2016) |
#20 | |
Road-hole
Drives: 2013 Whiteout FR-S
that seems weird...
Jaden |
#21 | |
#22 | |
Drives: none
The reasons may not be quite so obvious, and there are several factors that could cause a "12 PSI wastegate actuator" to actually only deliver 10PSI. First, you have to picture the forces going on here. If you have a simple internal wastegate actuator with a single port You basically have a diaphragm that the boost pressure can act against, on the other side of the diaphragm is a spring that gets compressed as the boost pushes the diaphragm down and a rod that moves with the diaphragm and opens the wastegate itself. So Boost Pressure->Pushes on Diaphragm->Compresses spring->Opens wastegate. With a boost controller in there you're basically intercepting the boost pressure input to the actuator and either blocking it entirely or bleeding some of it off (different boost controllers work slightly differently). This allows you to make, say, 20PSI on a 10PSI wastegate. The EBC simply blocks/bleeds the boost reference until it approaches 20PSI, then it lets it all through. Since 20PSI is more than enough to compress the spring in your 10PSI actuator, it opens reducing turbine speed and therefore holding boost at 20PSI. However, boost pressure isn't the only pressure acting on the spring. It also has to hold the wastegate closed against the exhaust backpressure in the manifold. This backpressure is always trying to force the wastegate open and only the spring is able to keep it shut. This is why some cars that are able to hold a steady 10PSI (or whatever) of boost suddenly see boost creeping up to 12-13PSI when they install a free flowing exhaust manifold, exhaust system, big cams, whatever. There's now less exhaust backpressure trying to open the wastegate so it takes more boost to do it. This is also why simple 1-port wastegate actuators don't work well when trying to run really high boost on a light spring. If your wastegate actuator spring is meant to run 10PSI and you install a boost controller and try to make 30 PSI (don't do this, BTW ) then it will likely fail to hit that boost since the exhaust backpressure alone is enough to open the gate. This is why dual-port wastegates/actuators exist.. but that's an entirely different discussion.Another reason a turbo might only make 10PSI on a 12PSI actuator is that the engine might be out-flowing the turbo. This is not what is happening to you as it normally only happens when using too small of a turbo for the power goals. You can go down a huge rabbit hole of discussing compressor and turbine flow maps, surge lines, etc... but suffice it to say, your actuator is probably just going to make 10PSI on your car and everything is just fine. Upgrade your exhaust -Matt |
#23 | |
I had my tuner set me up for a 10psi map as my primary for now to play it safe because Socal 91 oct sucks balls. I originally started out with a 7psi wastegate when i got the turbo kit. i ditched it about 3 months ago when the rod snapped
#24 | |
I want to run it at 10psi max with stock engine/fuel (stock wastegate is listed at 12psi) until at least next year, then might build the engine. |
#25 |
Senior Addict
Drives: 86 GT
This place sells just the actuator head which allows you to pop in whatever psi spring you select, then re-use your existing actuator rod and bracket. They've got a 7psi one so that could be your lowest boost setting, then you can run it at a higher boost using either an mbc or ebc
http://shopping.kinugawaturbo.com/ki...uatorhead.aspx |
#26 | |
Drives: '13 FR-S Turbo (Greddy T620z)
Did you use this on your own build? It works with the Greddy kit? |
#27 |
Senior Addict
Drives: 86 GT
| New Greddy T620Z?? | Celigts | Forced Induction | 30 | 09-12-2016 01:49 AM |
| GReddy T518z+Greddy CS GTS Ver 2. Video + pics (not tuned) | NOTORIOUS.BRZ | Engine, Exhaust, Transmission | 21 | 09-24-2013 06:09 PM |
