Old 04-29-2016, 02:35 PM   #1
Noobthen
Drives: Scion FR-S 10 series
Blew my motor
Hey guys I recently installed a stage 2 MAP turbo kit with a precision Ball bearing 5858. I was running a safe tune and decided to race an M3 and won. Unfortunately towards the end of the race I discovered a weird ticking noise. Eventfully once my motor was cracked opened, we discovered it was a broken Piston. What is a good affordable piston and Rod that you guys recommend to handle around 450 HP (max) On E85 Gas.
Noobthen is offline   Reply With Quote
The Following 5 Users Say Thank You to Noobthen For This Useful Post:
MisterSheep (04-29-2016), NyC Zn6 (04-29-2016), raven1231 (04-30-2016), SoCal80six (04-30-2016), yip (05-02-2016)
Old 04-29-2016, 02:51 PM   #2
CSG Mike
CSG Mike's Avatar
What kind of compression do you wanT?
Old 04-29-2016, 02:53 PM   #3
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Might have won the battle but M3 won the war....On a serious note good luck with the build bro
The Following 7 Users Say Thank You to NyC Zn6 For This Useful Post:
Cole (04-29-2016), Dream20b (04-29-2016), hmong337 (05-03-2016), KR-S (04-30-2016), MisterSheep (04-29-2016), raven1231 (04-29-2016), soulreapersteve (04-30-2016)
Old 04-29-2016, 03:48 PM   #4
mixtape
Posts in the nude
mixtape's Avatar
Drives: 2016 WRB BRZ
Did it at least buy you dinner first?
2016 Subaru BRZ - World Rally Blue [Build Thread]
Instagram: @mixtography | My Automotive Photography
"Lesbian trees have no wood." - Scoobs McGee
mixtape is offline   Reply With Quote
The Following 4 Users Say Thank You to mixtape For This Useful Post:
Cole (04-29-2016), MisterSheep (04-29-2016), NyC Zn6 (04-29-2016), soulreapersteve (04-30-2016)
Old 04-29-2016, 03:51 PM   #5
STV3
Señor Member
STV3's Avatar
Your tune was obviously not as safe as you thought.
STV3 is offline   Reply With Quote
The Following 10 Users Say Thank You to STV3 For This Useful Post:
Cole (04-29-2016), drewbot (04-29-2016), D_Thissen (04-29-2016), Leonardo (04-29-2016), MisterSheep (04-29-2016), mixtape (04-29-2016), Pat (04-29-2016), R2RO (04-30-2016), Sideways? (04-30-2016), soulreapersteve (04-30-2016)
Old 04-29-2016, 04:46 PM   #6
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
CounterSpace Garage is offline   Reply With Quote
The Following 24 Users Say Thank You to CounterSpace Garage For This Useful Post:
Cartman (04-30-2016), cdq85 (04-30-2016), cdrazic93 (04-30-2016), Cole (04-29-2016), drewbot (04-29-2016), D_Thissen (04-29-2016), finch1750 (04-30-2016), FLESH KILLA (04-30-2016), Guff (04-30-2016), Initial_RD (06-10-2016), KR-S (04-30-2016), Lorico (05-08-2016), mmmcambelsoup (05-03-2016), NyC Zn6 (04-29-2016), raven1231 (04-30-2016), Sargy (05-02-2016), shu5892001 (04-29-2016), SoCal80six (04-30-2016), soulreapersteve (04-30-2016), steeloyangster (04-30-2016), tumbla.jr (04-30-2016), Votlon (05-05-2016), weederr33 (04-30-2016), xkalelx (05-02-2016)
Old 04-29-2016, 05:59 PM   #7
Noobthen
Im thinking of 10:1
Old 04-29-2016, 06:00 PM   #8
Noobthen
Lol of course :p
The Following User Says Thank You to Noobthen For This Useful Post:
mixtape (05-01-2016)
Old 04-29-2016, 06:07 PM   #9
Noobthen
I was told not to run it hard. But I guess I am stubborn and never listen to directions. This just gives me a chance to build the motor while its open.
Old 04-29-2016, 07:16 PM   #10
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
1) What tune is the safe tune? MAP base map?
2) What psi? No more than 7-8psi I hope.
3) Factory rev limiter? Factory valve springs suck ass
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 04-30-2016, 07:17 AM   #11
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Did the same thing ahah same turbo and kit to!!! Have you had the chance to strip down the block and see all the damage you did??
SoCal80six is offline   Reply With Quote
The Following User Says Thank You to SoCal80six For This Useful Post:
MarcFr-s (05-05-2016)
Old 04-30-2016, 07:59 AM   #12
FRS Justin
Drives: 2013 Asphalt FRS
Im thinking of 10:1
if you want a decent idle go back with 12.5, lower compression isn't needed with the D4S system. The port injectors can spray fuel right on top of the piston to keep things cool.
The difference in power between 10.5 and 12.5 is 20hp n/a approx.. That is about 3.2 psi of boost for the same level of power on the top side. Plus Low compression boosted apps suck compared with the High compression boosted engines. Lowering compression is old school thinking for old school motors (V8s) Maximize your new school engine. Think of it this way you were 12.5 before the motor blew so why drop now? Why put strong components in your motor if your going to detune it with lower compression. DO you run your motor at mid boost and up 90% of the time?? No you daily the car so their is no need to lower the compression and sacrifice drivability on the street.
If your hell bent on 10.5 I have a set of JE 10.5 pistons with 250 miles on them I will sell cheap. I also have a set of L19 head studs to....I'm back to 12.5 and I will never lower my compression again on a FA20 the difference is night and day.....
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following 2 Users Say Thank You to FRS Justin For This Useful Post:
#maverick# (04-30-2016), lamawithonel (05-02-2016)
Old 04-30-2016, 08:17 AM   #13
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Heard you were going back to stock cr your having outfront do your build correct?
Old 04-30-2016, 09:56 AM   #14
GsxrMe
GsxrMe's Avatar
I kinda agree with frs Justin, in the fact. When I lowered my CR on my hayabusa to 9:1, I felt the bike was a gsxr 600 before boost. When I hit boost, snap.... it was nasty, nasty, nasty.
I think the tuner can advance timing with the much lower CR to help before boost and start to pull timing as needed as the turbo starts to spool. The plus side to lower CR is just less room for error and with valve and piston clearance. Also with lower CR we can run 93octane at much high hp.
For the people running a gtx28 the factory CR with stronger rods and valves might be idle but for the members running much larger turbos such as the gtx30 I or gtx35s with hp goals over 400, I'd say lower CR is required.
Find your hp goal and talk to a real tuner that has great reviews not just a ecutek stamp on the ecutek website.
I'm still intrested in what psi this motor was blow at.
2014 Subaru BRZ
The Following User Says Thank You to GsxrMe For This Useful Post:
FRS Justin (04-30-2016)
Motor Blew Last Night John Rambo Forced Induction 142 10-16-2017 12:11 PM
Blew a ballast? coloradobrz BRZ First-Gen (2012+) — General Topics 13 12-31-2015 07:23 PM
so my motor blew up on dyno today jdl kit gtx3071 kingkai23 Forced Induction 62 07-24-2014 09:09 PM
So my engine blew up.... alliedcam1 Engine, Exhaust, Transmission 57 12-28-2013 02:50 PM
What would You do if your motor blew? TyperRspec789 Forced Induction 58 07-02-2013 10:54 PM
