Drives: 13 swp limited
so my motor blew up on dyno today jdl kit gtx3071
What are chances the heads ok and or chances i can get it replaced under warranty if i returned back to stock..supposingly the tial wg port plug came out and overboosted and rod went 3k miles on motor and bye bye
Thanks
no chance
bottle of brown liquor, press to lips, consume contents.
Drives: 93.5 supra t & prius
good luck....hope you got extra money saved up
Go-Kart Enthusiast
Drives: Toyota Scion FRS
I dunno man. I feel like they are going to find out regardless of how hard you try to hide the fact you went FI. Too many pieces of been unscrewed, screwed and drilled. Not to mention the nature of your accident is suspicious. Having said that all that you are still going to take all the shit off as you need a new engine so it may be worth the effort. But I think you need to ask yourself what happens if you do and they investigate and find you lied? We are talking a big ticket item here and I suspect they will really dig before forking over a new engine.
I feel for you man it sounds like you had a sweet setup. On the bright side I have seen plenty of folks offering to sell their engines for around 3 to 4k. Its no easy feat buying, shipping and installing but it appears to be your only route. Stories like this steer me towards SC vs turbo. Good luck
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels |
Drives: 2013 Subie BRZ Limited, black, 6MT
$3-4k for a motor? I'd sell mine for that just to justify a built motor install! Lots of other hidden expenses, but still tempting.
On another note, hiding what you did to the motor, knowingly abusing it, would be fraud. Not something I'd pursue. Perhaps return it to stock, take it in, mention you had it turbo'd or FI'd and BAM. See if they're willing to help. Otherwise you're back to needing a new motor to install all the kit back onto. Good luck. |
Drives: 2013 Asphalt 6spd
that really sucks.
I am not heavy into the turbo discussions, but I am surprised I haven't heard anything about overboost protection at all. In my 240 there was a simple $50 box with an adjustible pressure sensor that cut spark if you went above your set limit. Seems like a cheap form of insurance if going FI. |
#8 | |
Drives: 2005 Toyota Camry
What you are doing is not only fraud, but it also cheats other honest owners out of warranty work in the long run. The more these things show up with the manufacturer, the less inclined they are to help out modded car owners. Don't ruin it for the rest of us, please. -alex |
Add lightness!
Drives: 17' WRX
Pay to play buddy. If you can't afford to lose the motor you shouldn't have been bolting a turbo kit on.
#10 |
I was only inquiring because somebody mentioned it..ill most likely buy a used motor and get rid of it..would like to get away with just replacing shortblock but my luck i doubt it
#11 |
Drives: 2JZ FRS
Should have tuned in the boost cut if it was on ecutek. It works great. @Pure Automotive might have a stock spare for sale
#12 |
Grip>Slip
#13 | |
Go-Kart Enthusiast
Your point is to think about the other people doing the right thing and I applaud you. Why should they be punished? Its people with minds like you that stir communities to come together for some righteous cause. I'm no there and I put myslef first. Here is what is racing through my mind and the reason why I lack sympathy. An old couple walks into a dealership looking for a new ride.... The End
FRS
#14 |
Yes had boostcut thru ecutek..i got all supporting mods new clutch even ran e85 to be safe but yet i cant even make it off a dyno
| So my engine blew up.... | alliedcam1 | Engine, Exhaust, Transmission | 57 | 12-28-2013 02:50 PM |
| dyno tuned today | WhiteFR-S | Engine, Exhaust, Transmission | 2 | 10-18-2013 02:40 PM |
| What would You do if your motor blew? | TyperRspec789 | Forced Induction | 58 | 07-02-2013 10:54 PM |
| Went to the DYNO Today, Stock* results are in! | Z3D | Engine, Exhaust, Transmission | 30 | 03-06-2013 09:49 PM |
| Baseline dyno test today on my new BRZ | Those Meddling Kids | Engine, Exhaust, Transmission | 2 | 08-25-2012 10:52 PM |
