Old 04-26-2016, 08:26 AM   #3837
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
As owners we agree
Freeman is offline   Reply With Quote
Old 04-28-2016, 08:23 AM   #3838
vgi
Drives: frs
Originally Posted by GsxrMe View Post
The kit needs an auto pulley tensioner. The belt heats up and the belt is no longer tight enough. To cold and it's tomuch tension. For this very reason is why cars main serpentine belt as a auto pulley tensioner.
it's the other way around on this kit
vgi is offline   Reply With Quote
Old 04-28-2016, 12:52 PM   #3839
vgi
Drives: frs
Originally Posted by FRSTRM View Post
Anyone have problems with the 1200 belt not fitting and the 1280 too large to be tensioned properly? I have updated charger and crank pulleys - were other pulleys updated as well?
The smaller belt fit fine with the tensioner almost fully engaged with the smaller crank and charger pulleys.
i did not have any issues with the belt and pulleys (just 2, crank and ss) that came from KW. I do not know though if the belt is indeed TP1280-8MGT-20 - that info was first posted by @Apoc i think
Old 04-28-2016, 02:14 PM   #3840
FRSTRM
Baby LFA
FRSTRM's Avatar
Drives: Baby LFA
Clarified with KW the belt is supposed to be 1280.
There may be an issue with my tensioner.
FRSTRM is offline   Reply With Quote
Old 04-29-2016, 08:25 PM   #3841
Freeman
Freeman's Avatar
Kraftwerks Supercharger Owners Thread
Email KW directly. It's the easiest way.
Being a vendor on these forums is expensive so most do it sporadically
Old 04-29-2016, 08:37 PM   #3842
Rulin
WRX -> BRZ. (TX)
Rulin's Avatar
Drives: 2015 Series.Blue WRB
Originally Posted by Sgtfluffy16 View Post
I think this is the last question I have before I do the install next week. Should I do spark plugs? If so which one should I do? The car only has 3500 miles on it
Havent/didn't change mine. Installed at 8500 miles, and I'm now at 38k miles over a year later, for what it's worth.
Sent from my Nexus 6 using Tapatalk
KraftWerks c3094 SC Kit
ARK GRiP w/ test pipe
KW V3
OEM Audio + Reference 400CF
Rulin is offline   Reply With Quote
The Following User Says Thank You to Rulin For This Useful Post:
Sgtfluffy16 (04-29-2016)
Old 04-29-2016, 09:39 PM   #3843
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I did yesterday, no response yet.
Just trying to get input from other kraftwerks supercharger owners.
nothing yet??? @KraftWerks
Last Activity: 04-13-2016 12:31 PM
They must be ignoring everyone i guess
Old 05-02-2016, 03:28 PM   #3844
D-VO
Drives: Whiteout FR-S, Evo 8 RS
Am I the only person this happens to? This is the second time the resevoir brackets broke since I moved it to the front.
D-VO is offline   Reply With Quote
Old 05-02-2016, 03:31 PM   #3845
Freeman
Freeman's Avatar
I hammered mine flat and haven't had an issue with them. Maybe have some custom ones made with thicker steel?
Old 05-04-2016, 02:12 PM   #3846
Rulin
WRX -> BRZ. (TX)
Rulin's Avatar
Originally Posted by D-VO View Post
I'm still using the factory header overpipe and frontpipe. Recently I caught some muffler packing coming out of the exhaust. I took everything apart and found the cat converter was empty.
LOL! POWWAAAAAA!!!!!!!
I believe i just blew out my cat this morning while driving to work. Going to check the header this weekend for sure though.
KW V3
Old 05-10-2016, 10:30 AM   #3847
vgi
Drives: frs
mmm...
i'm not sure I understood "the exact reason why".
are you saying you used wrench with long lever, pulled as hard as you could to tighten the bolts and then once you pulled the threads you went out to lookup the torque specs?
The Following User Says Thank You to vgi For This Useful Post:
Freeman (05-10-2016)
Old 05-10-2016, 10:35 AM   #3848
Freeman
Freeman's Avatar
mmm...
That's what I got out of it.
Old 05-10-2016, 01:15 PM   #3849
vgi
Drives: frs
oh boy, i think i'm smelling another pissed off KW customer with snapped belts.
the JRSC crowd will be exulted
clayrush (05-11-2016)
Old 05-10-2016, 04:25 PM   #3850
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
I don't really know why, everyone I've seen with a KW kit with PROPERLY Tensioned belt hasn't snapped one since so really I believe the issue is mostly due to user error and people being unable to tighten shit enough or too much (that includes fully capable mechanics, the number of times shit has come loose because of improper torqueing even by trained specialist is quite jarring).
People really need to stop the pissing contest between KW and JR. Both kits have their downfalls and both are great when properly installed and tuned.
fumanchu1 is offline   Reply With Quote
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
