Old 06-18-2012, 12:04 AM   #295
Deslock
Deslock's Avatar
Drives: 2013 DZE/01 (sold for MX5 ND1)
Originally Posted by Roadstercycle View Post
I believe the Prius tires that they put on us could be a little at fault but I don't know for sure.
The tires are not at fault.
Deslock is offline
Old 06-18-2012, 12:15 AM   #296
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
The fact is they don't give much grip, but that is what makes the car so fun.
Anybody can crash a car....
[ame="http://www.youtube.com/watch?v=1pgm8I0B8bY&hd=1"]Lamborghini Crashes in Chicago Suburbs - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=A4DIUZ_g6pk"]Dodge Viper Crashing a Van!!! CRASH!!! NEW VIPER CRASHED - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=_HqsqhdVXpY"]Brand New Ferrari California Crash! - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=IdLHAqL8KJw"]Super car driver idiots [NO pics, only videos] - YouTube[/ame]
tripjammer is offline
Old 06-18-2012, 01:01 AM   #297
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Originally Posted by AeroWRX View Post
Question: How did people drive RWD cars back in the day when there was no such thing as a traction control??? I don't understand why turning off stability control automatically warrants a crash...
personally, its because people expect x, and dont always get x but get y
x being, traction control off, drift like the reviews because the car is so great
one of the first things i did when it rained was went to a very large empty parking lot, turned everything off and practiced, because the first time i tried to drift the car it spun around on me, y( the thing that happens to most people)
i took the time to figure out how hard it was to get the back end to rotate at 20, 30, 40, and 50 mph
i actually had the hardest time learning control at 20 and 30 mph, in first gear your in the hp and tq range and you dont have momentum to help you stay straight, 20 - 30 mph drifts were better controlled and initiated in 2nd gear
40 and 50 mph is where the magic is and about where you would be on a medium sized corner at a track, 2nd gear about a 3k rpm range to play with, the torsen does a great job there ,and because the torsen works so well, lower speed slides are more unpredictable, both tires break loose and your limits are much easily crossed
the same day i was with a friend he had a rwd car but no limited slip, slower speed drifts were much easier for him because only 1 tire would break loose and the other would drag around at a slower speed(kind how stability control works in dragging the inside tire to correct you) but at higher speeds he just couldnt hold a drift, tires wouldnt stay broken loose or he would spin out( and this inst because of tq, hes got 240 tq to the ground vs my 130 to the ground)
in conclusion what im trying to say, is the rear will snap at you where you want it NOT to happen, at low speeds, through things like traffic lights, round abouts, street corners, and any kind of low speed turn on black top or grooved pavement really, most of these areas put you close to other cars, people, houses, and light poles
Juanito08 already had this happen to him, unless you've had about 50 hours of track time or have owned it longer than 2 years driving spiritedly everyday but aware of the limits, you are NOT going to know what will happen in every situation... just because you drifted one corner around your neighborhood doesnt mean you will at a different but similar corner
PS sorry juan if i put you on blast! ahahah
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline
Old 06-18-2012, 01:21 AM   #298
tripjammer
tripjammer's Avatar
Originally Posted by SWAMechFRS View Post
Note to self:
Do not post pics and/or tell the story if you wad up the car.
What a bunch of jackasses. He's just a kid. You got to live and learn. Cut him some slack.
Damn when was 24 years old a KID?
Old 06-18-2012, 01:41 AM   #299
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
This is very accurate. I've almost spun once on wet, disjointed, low grip pavement. There was nobody around, gave it some gas in 2nd at low speed in a 90 degree turn and the car just snapped... happened very very fast. I probably would have spun if I had everything turned off. I was in VSC sport at the time.
Keep in mind this is probably the worst place I know of in town for grip in the rain.
blu_ is offline
Old 06-18-2012, 01:41 AM   #300
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
When you hit thirty
blu_ is offline
Old 06-18-2012, 01:48 AM   #301
carbonBLUE
Reverse Burnouts
ahah just wait til your tires start to bald, youll leave intersections on low grip pavement at an angle but still moving straight forward, rwd cars with LSD is very weird in certain situations, or youll get weird sounds
try backing up straight then turn the wheel and move forward, youll hear/feel the lsd changing direction/locking as you turn
(wont forget you)
2011 Infiniti G37x
Old 06-18-2012, 01:51 AM   #302
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Not really the point. There's no reason to turn it off if equipped but the lack of them doesn't mean death and destruction. There's just no real value in turning them off on the street.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Dave-ROR is offline
Old 06-18-2012, 01:58 AM   #303
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
Yeah the noises I'm used to from my STI. The first part sounds interesting though.
Also like you said, its just not possible to react fast enough to a car which you have no experience with that exact situation in. The first time I drifted the car intentionally, just on instinct coming from AWD, I gave the car too much gas after the back end starting coming out.
If my steering input hadn't have been good and my "OH F@$@" reaction was to clutch or slam on the breaks, I definitely could have been the first wrecked brz.
That's enough confessions for the the day though. I don't recommend this throw yourself in the fire type of learning, but we all do stupid things.
blu_ is offline
Old 06-18-2012, 02:22 AM   #304
carbonBLUE
Reverse Burnouts
i threw myself into the fire, but it was in an empty parking lot and nothing to hit... im still not comfortable with turning everything off, still leaving it in vsc sport for a while there is a corner though on the way to my gf's house that well, its banked concrete 2 lanes wide, isnt a blind corner and nobody takes the street, drift it evey time!
entrance speed 32-35 mph, 2nd gear, 40% throttle, turn in, then counter 2-5 ft from the apex, 80% throttle, tires break loose on the yellow lines, power through when the car starts to correct, begin a stupid grin for the next 2-3 miles
ive got tire marks going both directions lol...
nothing but flat grass around the corner, so nothing to hit have yet to slide off or turn myself around
(wont forget you)
2011 Infiniti G37x
Old 06-18-2012, 02:44 AM   #305
CSOCSO
Drives: Scion Tc
yepp.... as soon as they announced an rwd scion back then I knew this is going to happen to young owners like every other week.
I'm glad you ok!
Originally Posted by Enzie View Post
CSOCSO for president of ft86club hater bashing committee!
CSOCSO is offline
Old 06-18-2012, 03:27 AM   #306
Z.Tune
Drives: E46 M3/Z34
well, I almost never have my traction control on, unless its a very bad raining day.
BUT, I NEVER HAD AN ACCIDENT.
So, IMO, its not about the car, its about the driver.
Z.Tune is offline
Old 06-18-2012, 03:27 AM   #307
nix
nix's Avatar
Drives: AVO BRZ
Originally Posted by R8 View Post
And even if someone IS experienced... why turn it off on the street? It only intervenes when the wheels break loose, right? So it's not something anyone should be TRYING to do in public anyway.
And besides, there are unexpected events where it might save someone, regardless of skill, such as an emergency lane change. No one, no matter how skilled, can brake one side of the car to straighten it out (as stability control will).
Depends on the car. The built in TC is so poor on my Supra it's dangerous to leave it on. I have to yank the fuse, because even disabled it will override and go into snow mode sometimes. Not exactly safe when you've gone for a gap in traffic, and suddenly the car drops from full revs and boost to more like low gear in a tractor.
IMO Relying on electronics to do your job for you, in anything in life, is not a good plan. At the least you should practice without it to get an idea of what will happen if your nannies fail.
nix is offline
Old 06-18-2012, 04:03 AM   #308
Minovsky
Minovsky's Avatar
Drives: Fr-s 2013 white out
Originally Posted by #87 View Post
O lawd, looks fixable tho
Talk about break in period
i herd the air bags popped tho O.o
Minovsky is offline
DOT Crash Test (non) Data for FR-S/BRZ Dadhawk Scion FR-S / Toyota 86 GT86 General Forum 15 03-24-2012 04:21 AM
Jay-Z and Kanye West's wrecked Maybach Auctioned for $60,000 M-17 Other Vehicles & General Automotive Discussions 10 03-16-2012 01:06 PM
First Toyota 86/GT86/FRS crash?? cb7 Scion FR-S / Toyota 86 GT86 General Forum 4 03-15-2012 03:54 PM
first 86 crash just86 Scion FR-S / Toyota 86 GT86 General Forum 31 03-12-2012 01:23 PM
Plane Crash in AZ Neutral_Eyes Off-Topic Lounge [WARNING: NO POLITICS] 4 12-02-2011 01:27 PM
