Old 04-29-2016, 11:48 AM   #43
ZionsWrath
Thanks
ZionsWrath's Avatar
You like Justin Beiber - Boyfriend?
Sorry I can't talk to you
Old 04-29-2016, 11:49 AM   #44
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
ajcarson11 is offline   Reply With Quote
Old 04-29-2016, 12:17 PM   #45
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
A Cat is not a resonator
Originally Posted by ajcarson11 View Post
It is my understanding that there are TWO resonators in the stock setup. One in the front pipe, and one in the midpipe. If you add a resonator to the front pipe, you will have THREE resonators.
Just to clarify on that.
Catalytic Converters, (one in the header, and one in the front pipe) may resonate, but because they aren't empty spaces, they can't be called resonators. Resonators are simply carefully designed empty spaces which help cancel out certain resonant tones. There is only one resonator in the stock setup, in the front pipe, after the Cat.
If I say yes, will that make you think I understand?
KoolBRZ is offline   Reply With Quote
Old 04-29-2016, 12:39 PM   #46
ZionsWrath
Thanks
ZionsWrath's Avatar
I clicked his youtube and it says one of his favorite vids is Justin Beiber Boyfriend......................................... .....................................
Old 04-29-2016, 12:51 PM   #47
ajcarson11
Never seen the video, nor do I care for justin bieber in any sense. Not sure why it shows anything regarding my 'favorite vids'. Hardly use (or post) to youtube as it is.
Wonder if I left my youtube account logged in at someone's house or something...
Old 04-29-2016, 02:25 PM   #48
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Exactly that, it will end up with 3 resonators in close proximity no matter what you do with the stock front pipe and mid pipe, so it should be welded in before the OEM front pipe resonator.
Old 04-29-2016, 04:13 PM   #49
ajcarson11
So you're suggesting putting a resonator in the front pipe then, and not midpipe. Due to space constraint in the midpipe? Do we have ample room in the front pipe for a resonator currently?
Old 04-29-2016, 04:26 PM   #50
FRSBRZGT86FAN
It would have to be placed between the cat and the exhaust hanger
OR before the midpipe goes over the rear axle
But look there isn't much space between the OEM "tube" type resonator running the length of the mid pipe
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
ajcarson11 (04-29-2016)
Old 04-29-2016, 06:11 PM   #51
Teseo
Drives: frs
Best place to add a resonator is on the front pipe imo, after the cat
The Following User Says Thank You to Teseo For This Useful Post:
ajcarson11 (05-02-2016)
Old 05-02-2016, 09:28 AM   #52
ajcarson11
All,
After some review, I think i'm OK on the rasp. There is very little overall -- I think i'm going to attempt to throw in a small muffler into midpipe to bring down the volume. There isn't any 'drone' persay... but the exhaust is simply noisy on the highway above 3k RPM.
Will research to find a decent tube-style muffler that can be welded in.
EDIT: you may be thinking 'why modify the mid-pipe?' -- I am not going to modify my own. I can pick up one for $40.... The stock front-pipe is much more expensive than $40.
Old 06-01-2016, 08:10 PM   #53
ajcarson11
Update: Attempted to have ultra quiet resonator (1141) installed in stock piping. The shop couldn't find a place to put it in without it hitting on the car. They eventually found a place to put it, but would have to hack up the front pipe and midpipe, costing $200 in total. With the cost of the ultra quiet, that would put this at $300 -- I could pretty much afford a new catback at that point.
The shop then found a bottle style muffler to install. They welded it in within 2 feet of the end of the midpipe (where the midpipe connects to the axleback). The total cost was $95, or roughly the cost of the ultra quiet resonator (which I was planning to return) so I figured I could get out of there for free.
Unfortunately, after review, the bottle style muffler sucked the life out of the exhaust. The exhaust now sounds like the stock catback, but with less tone and more drone/bass. For its tiny size I expected the muffler to have less of an effect, but this is not the case.
I'm now on a mission to determine how to proceed... Not sure if a bottle style resonator would have enough effect on the slight rasp/volume to pursue purchasing and replacing the bottle muffler.
Perhaps my needs are too ambitious?
The Following User Says Thank You to ajcarson11 For This Useful Post:
DarkSunrise (06-02-2016)
Old 06-02-2016, 08:03 AM   #54
CloudsSoul
CloudsSoul's Avatar
Exhaust note nearly perfect... But can you help me bring down the volume?
What brand is the bottle muffler?
CloudsSoul is offline   Reply With Quote
Old 06-02-2016, 08:13 AM   #55
ajcarson11
I had asked that prior to install and it was just a generic from one of their 'suppliers'.
Either way... My persistence has ordered a vibrant bottle resonator and sent back the ultra quiet resonator. I'll have them weld it in, in place of the bottle muffler.
Old 06-02-2016, 02:05 PM   #56
CodyJ28
Drives: Blue BRZ limited
Been reading through this thread. Keep us updated
I have ofh with Perrin 3" non res catback exhaust
I think it's a little too raspy
Hoping to get ideas from your experiments lol
CodyJ28 is offline   Reply With Quote
Bring the Noise with FRSPORT's 2014 Exhaust Blowout! FRSport.com Engine, Exhaust, Bolt-Ons 0 09-05-2014 12:40 PM
Front pipe variations and exhaust volume Vmax911 Engine, Exhaust, Transmission 9 03-05-2014 04:04 PM
Exhaust volume twag4 Engine, Exhaust, Transmission 17 09-24-2013 04:12 PM
Cold Start Exhaust Volume SilentMike Engine, Exhaust, Transmission 15 04-04-2013 10:49 AM
Bring your intake and/or exhaust! bdanisi Engine, Exhaust, Transmission 8 01-09-2013 01:07 PM
