Old 04-27-2016, 05:06 PM   #463
Noxcyn
Noxcyn's Avatar
Drives: '15 Scion FR-S - Ashphalt (MT)
New Stage 2 UEL (91-93 and E85) OTS tune files
Originally Posted by StayPuft209 View Post
Yeah I think so, but it's more a rattle sound like something is shaking inside.
Wheni put my o2 sensors in my OFH the stupid metal skirt thingg was a bit loose and rattled. I could rattle it with my fingers. Sounded kinda like dropping a coin in a metal sink sorta. (You can hear it in my exhaust video - you can hear it just after reving - [ame]http://youtu.be/BKa9my8sgN4[/ame]) I ended up buying a washer and putting the sensor through it and that stopped the rattle. (If thats the type of rattle you have, it eventually had me going insane)
Noxcyn is offline   Reply With Quote
The Following User Says Thank You to Noxcyn For This Useful Post:
StayPuft209 (04-27-2016)
Old 04-27-2016, 05:37 PM   #464
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by Killadelphia View Post
I don't even have my OFT yet but I have read enough to know that those logs don't look good. You want your IAM (adv multiplier) to stay at one. It doesn't even get to 1 in either of those logs, and I see knock corrections of over -2 which is also not good. So yeah you should probably stick with the old tune, or do some tweaking (do it yourself, or Vishnu remote tune would probably be best).
Incorrect, there is an OFT glitch that shows IAM at 0, but it does show that he did have an exhaust leak
Old 04-27-2016, 06:01 PM   #465
Killadelphia
He posted logs from after he switched to a Gruppe-S header.
Sent from my Nexus 6P using Tapatalk
Killadelphia is offline   Reply With Quote
The Following User Says Thank You to Killadelphia For This Useful Post:
FRSBRZGT86FAN (04-27-2016)
Old 04-27-2016, 07:03 PM   #466
FRSBRZGT86FAN
The IAM at 0 is still a glitch with his OFT
Old 04-27-2016, 07:17 PM   #467
StayPuft209
StayPuft209's Avatar
Drives: Firestorm FR-S
Originally Posted by Dru670 View Post
I also have their 60mm OP. Did you get theirs or you got diff brand OP or still stock? Might have something to do with using stock or other brand OP with their heading I guess when it comes to fitment somehow.
Yeah I picked up their 54mm op for use with stock front pipe.
StayPuft209 is offline   Reply With Quote
Old 04-27-2016, 07:40 PM   #468
Killadelphia
It's not stuck at 0 on the new logs. Take a look.
Old 04-27-2016, 07:54 PM   #469
FRSBRZGT86FAN
Oops sorry, datazap was taking me to his old ones
Old 04-27-2016, 10:37 PM   #470
Elliott S
Elliott S's Avatar
Drives: 2015 Subaru BRZ
Heres my newest set of 30-60 pulls. Only saw one minor area in which KC was present as well as negative flkc. Yes... I know I need to rescale my MAF (even though its just the stock box w/ hi flow filter and mishimoto inlet tube).
http://www.datazap.me/u/elliott-s/st...e?log=0&data=1
Elliott S is offline   Reply With Quote
Old 04-27-2016, 11:47 PM   #471
OkieSnuffBox
Drives: '23 BRZ Limited
I'm not going to look at your logs, but for you and everyone else, for a better picture.
Try to find a spot where you can at least do 3rd gear 3000-7200 pulls so you get a bigger load on the engine.
Old 04-28-2016, 12:17 AM   #472
Dru670
Drives: 2016 Scion FR-S
I'm starting to wonder how many stock fr-s motors are taking shit if they are knocking left to right on stock tune if they were tuned on high quality gas by the manufacturer.
Dru670 is offline   Reply With Quote
Old 04-28-2016, 07:07 AM   #473
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
It wouldn't really matter much because the engine can compensate for a huge amount of knock. It just means there's a ton of twins out there running at 75% of peak performance.
headlikeahole is offline   Reply With Quote
Old 04-28-2016, 07:28 PM   #474
Roneezy
Roneezy's Avatar
Drives: Scion FRS Halo White 2015
Are my new logs okay or is the car not doing good?
http://datazap.me/u/roneezy360/stage...e?log=0&data=1
http://datazap.me/u/roneezy360/stage...log=0&data=1-5
Roneezy is offline   Reply With Quote
Old 04-28-2016, 11:52 PM   #475
Elliott S
Elliott S's Avatar
Originally Posted by Roneezy View Post
It might just be me. But you are seeing a LOT of engine knock happening. Seems to me that on your gruppe headers, it might be too aggressive.
The Following User Says Thank You to Elliott S For This Useful Post:
Roneezy (04-29-2016)
Old 04-29-2016, 12:59 AM   #476
Roneezy
Roneezy's Avatar
What should I do?... I don't want my engine to die or anything lol.
Just how noticeable is OFT+OFH and stage 2 tune? BBYZILA Software Tuning 58 03-20-2018 11:56 AM
OFT 2.0 Stage 1 93 Tune MurderRider Software Tuning 57 03-21-2016 12:30 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
FA20club.com Turnaround Times On Modified Tune Files FR-S Matt Software Tuning 103 11-13-2013 01:48 PM
So whate does stage 3 tune do? I already have 2 Frsexxxy Engine, Exhaust, Transmission 17 05-14-2013 06:30 AM
