#435 | |
Drives: Toyota 86 GTS
Stg1 typically doesn't need changes. |
#436 |
Drives: 2016 Scion FR-S
I'm looking at waynos roms and i see there's both a Stg 2 UEL 98 v101 AU "LEAN" and "RICH" version. I live in Vegas which would be more appropriate for me?
When I compare my rom to say Stg2 UEL 98 v101 AU Rich A01G.bin there are 242 equal tables, 73 changed tables and 94 missing tables. Do I just copy and paste the 73 changed tables from Waynos to my rom (F00C) and i'm done? |
#437 | |
Drives: 2015 HL FR-S
Depends on where you want to start. You need to dl the defs he uses, otherwise you will have tables missing that you can't see from his roms. I found this out, still new with this setup, thought i could just use the ofs defs. I believe some tables might still be missing though, fyi, but i have seen the important tables (i was wanting to look at anyway) are there for both. Personally i know it gets HOT here in az, 100-125f temps out on road, if not a tad higher. Its a dry heat though, so humidity is super low. A bit different there then vegas. You can change Timing Compensation (IAT) 86 do -0.70 and 104 do -1.41. (i have noticed a change, but i have changed over 10 tables so far in the tune) still a work in progress... haha. So far on our crap 91 here, my tune is running ok, think i fixed the issue with with it going lean for a short bit from CL to OL as well. Have you ran the reg stage 2 ofs tune yet to see where you sit? Scaled your MAF yet? Or ran through wayno and steve99 guides? I wouldn't copy the tables directly, different defs, might mess stuff up. (i haven't to be safe, might be ok, again im still new to this) I use a screen clip (using sniping tool) of the table or parts of it that I want and then manually entered the numbers. Doesn't take me long as I input numbers all day long, lol. After this you can load both and check to make sure you entered them correctly with the compare tables. If you want, you can use the Base timing A, Base Timing B, Knock Correction MAX A, Timing Compensation (IAT), Timing compensation IAT (Activation), front oxygen sensor scale change (make sure to change the axis as well), rad fan change. (or copy all the tables) Drive and log the tune lots, i usually have 4 or 5 logs a day, lol. This way you can see whats going on with different temps loads etc, but let the computer learn 1st (unless some major lean or rich or to much knock) otherwise if you make little changes it might be for the worse instead, lol. Just to start off. =D So far im really enjoying this great tool.
[||•]=(86)=[•||] 2015 Hot Lava FR-S (Sold) OFT → My non sensor flexfuel UEL tune Plus other mods Last edited by HLHachiRoku; 04-27-2016 at 12:52 AM. |
#438 | |
#439 | |
If you start on wayno, and steve99 links in their sigs, wayno basically gives you a tune to copy for the 91 gas, their gas 98ron. Might need tweaking, but its a good starting point on all those tables atleast. They give really detailed and straight forward info I think anyway. Oh the 91 gas its horrid so I have come to find out. Now if its not knocking over -1, and its not doing it all the time. If it is more then -1, that is something you need to look at right away, probably happening alot. For either, look at what instances it is, engine load/throttle position/commanded afr vs afr to see the cause of it. You can start from scratch with wayno's stuff and adjust things to how your car runs works etc. I think you will enjoy it alot as i have, its an amazing little tool so far I think.
[||•]=(86)=[•||] 2015 Hot Lava FR-S (Sold) OFT → My non sensor flexfuel UEL tune Plus other mods |
#440 |
Drives: DMG Subaru BRZ
@Wayno just noticed that in v101 A01I, that you don't have UEL_Tomei 98/E85 files anymore. Would the v101 UEL98/E85 be fine to use for reference for the Tomei header as well? Or should I still look at the v100 Tomei files?
#441 | |
#442 |
Drives: Scion FR-S
Maybe I don't get it quite right, but if i would like to use the mods from the v102, should I use the defs in the zip file -v101 2016-04-27 linked on the first page, or the original OFT defs i am running now (UEL stg2)? Btw. I am running 98/100 RON.
Also, what are those KN metric and standard DEFs? |
#443 |
The latest ones have the latest date in the name.
#444 |
Drives: Scion FR-S
So i should always use the lates defs (from the v101 file)? Just curious what are the differences.
#445 |
#FiftyShadesOfBlue
Drives: 2015 FR-S
I've read most of the thread and didn't see this so I apologize if my 2 questions have already been explained but I'm trying to solve some high LTFTs at idle/low speed that seems to be related to IAT so I think the below changes will help?
There are 4 tables referenced in the OP related to coolant temp for the fans. Do I need to change anything regarding turn off at 70 kph or do the fans already turn off at that speed anyway? Can ztans di/pi fix http://www.ft86club.com/forums/showp...6&postcount=21 be done without doing any of the other changes in this thread? I get a bit of stumble at low load while cruising and idle and it looks like this should help. (I'm 2015 AT that has already done the TSB for dip at idle/park if that matters)
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes ![]() |
#446 | |
Drives: FT86
yes you can alter the pi\di ratios as per ztans post without other changes |
#447 |
Updated
- D00G, E00I definitions now have Front O2 Scaling B and all 10 cranking tables. - "v104" has a smooth AVCS maps, "v100" is close to the original openflash maps. - Other minor changes.
#448 |
Updated
v104 - Fixed AT bogging after shift in 2000-2200 rpm range at high load. Can still happen rarely at medium load. - Other fuel and timing tweaks.
| Help uploading 2.06 tunes to OFT | Jimmy817 | Software Tuning | 3 | 12-28-2014 09:06 PM |
| Custom Az Tunes | Juggles | Arizona | 13 | 11-08-2014 10:15 AM |
| EcuTek Tunes | Rio | Engine, Exhaust, Transmission | 1 | 04-29-2014 12:10 AM |
| How long until *other tunes? | ScionFrsFan | Engine, Exhaust, Transmission | 61 | 12-07-2012 05:34 PM |
| Speedhunters - TRD TUNES THE 86 | quik1987 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 69 | 05-22-2012 04:26 PM |
