#71 |
Drives: frs
I want to see those spark plugs, and you demostrate these engine are reliable
The Following User Says Thank You to Teseo For This Useful Post: | 86kahl (04-23-2016) |
#72 |
Drives: 2013 Scion FRS
It's actually not hard at all.
Sent from my SM-N915T using Tapatalk
Vortech V3 Supercharger| 12 PSI|E85 MotoEast Flexfuel kit|Crawford AOS| Mishimoto Oil Cooler|3"Perrin Resonated CBE| 3" JDL Front/Over Pipe|OpenFlash Performance Headers|Exedy Stage 2 Ceramic Clutch |Yonaka Coilovers|17x9 O.Z. Wheels| 245/40r/17|TRD Brake Pads|Perrin Master Cylinder Brace |ChaseBay SSBrake Lines|CF Side Fins|OEM Shark Fin Athena|Yospeed Console Plaque|R/T Shift Knob|Fog Lights|Backup Camera|Navigation| |TRD Quickshifter|Motul Gear Oil|
The Following User Says Thank You to FRSToyota86 For This Useful Post: | 86kahl (04-23-2016) |
#73 | |
Drives: Series10 FRS 6MT
3/18/14: '14 Firestorm Monogram FR-S 6spd-Sold
2/6/16:'13 SILVER IGNITION Series10#322 FR-S 6Spd-sold 5/12/18: ‘17 Toyota 86 6-spd |
#74 |
Inactive
Drives: .
It's not that hard to do guys. A process is just a process just because it takes a little longer doesn't mean it's impossible.
The Following User Says Thank You to _gt86_user For This Useful Post: | FRSToyota86 (04-24-2016) |
#75 |
Did you change your plugs the same way?
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#77 | |
Drives: 2013 Toyota GT 86
![]() Quote:
![]() Did them in the driveway & aside from a good 20 minutes fishing a socket out that got dropped, it took roughly 2 hours. It really wasn’t that hard, just takes some screwing around. But yeah, remove the cover over the injector rail and move the ECU. Car runs & idles so much better! I'll post up some pics when I have a chance - they didn't look horrible. ![]() I hear people say they would love to own an FRS but can’t because it snows where they are. I commute 1,000 KM a week through the snow belt of Georgian Bay in central Ontario. I have oil changes in Alberta, Texas & all over – every dealer I visit tells me that I have the most mileage they have seen on an FRS. ![]() And my car was NOT babied for 270,000 KM ... it was beaten and redlined continuously since the day I drove it off the lot. |
#78 |
#79 |
hey you, yeah you <3
Drives: 2014 37J FR-S
Whats the dealer cost? I do this every 40-50k. I'm at 25k
#80 |
Drives: 94 civic hatch, Whiteout frs
How did u guys remove the coil pack on the right side back? I got the front one out, but the rear coil pack hits the frame when I try to take it out
The Following User Says Thank You to umpadupa For This Useful Post: | hmong337 (04-28-2016) |
#81 |
Drives: Whiteout FRS
what is the part number for the spark plug? I have been reading and cant find the part number unless at the dealer. And they are 25 bucks each. Any suggestions?
#82 | |
Drives: '13 Ultramarine
SU003-00416 Edit: in case this is what you meant, the manufacturer is Denso, and their part number is ZXE27HBR8. You could also try stopping by a Subaru dealer and pricing a set of plugs for a BRZ. Parts are often a little less money from Subaru VS Toyota.
#83 |
Drives: 2013 Raven FRS
It would be interesting to see more pics of the process. I am a very visual type of learner.
I took a peak at my engine yesterday to see how it can be done based on the OP. Looking at the ratchet and tools I am curious to know how you were able to snake the tools into the crevice which is only about an inch and half to two inches in space and then get the plugs out.... Also manoeuvering the coils and plugs at an angle would be a challenge too. The drivers side seems to be tighter and have more obstructions. Good to know some are able to do it without lifting the engine. Just want to see more pics if possible. |
The Following User Says Thank You to FrostedFlakes For This Useful Post: | zc06_kisstherain (05-11-2016) |
#84 |
Drives: 13 Subaru BRZ, 02 Audi TTQ
I honestly don't remember anymore but the usual way to deal with clearance issues is to put the socket in the spark plug hole and then put the extensions & ratchet onto the socket.
The Following User Says Thank You to Scenic Driver For This Useful Post: | 86kahl (05-12-2016) |
Spark plugs for turbo | whitefrs | Forced Induction | 88 | 05-05-2018 09:18 PM |
boosted spark plugs? | 350matt | Forced Induction | 9 | 08-09-2014 03:54 PM |
Spark plugs | Triumphrider | Engine, Exhaust, Transmission | 12 | 06-19-2014 10:47 AM |
spark plugs | subaruferrucci | Engine, Exhaust, Transmission | 22 | 04-10-2013 11:24 AM |
