Old 04-22-2016, 01:15 PM   #1
Devil 86
Devil 86's Avatar
Drives: Ultramarine FR-S
RUBBING with 17x9 +35
I'm running 17x9+35 TC105Ns with 245/40/17s and they're running pretty bad at -1.5 degrees of camber on my KONI struts. How much camber do you guys run with this wheel setup? I don't want to run wheel spacers at the track.
Devil 86 is offline   Reply With Quote
Old 04-22-2016, 01:26 PM   #2
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
How are you getting your camber? With bolts or with top plates?
Instagram: trevor.parque
Old 04-22-2016, 01:31 PM   #3
infinity21
infinity21's Avatar
Drives: 2014 BRZ Sport-tech
Try maxing out positive camber with a camber bolt and get your negative camber through a top hat.
infinity21 is offline   Reply With Quote
The Following User Says Thank You to infinity21 For This Useful Post:
MisterSheep (04-22-2016)
Old 04-22-2016, 01:38 PM   #4
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
you're either too low or your alignment is off besides camber. toe and caster?
Any pics of where you're rubbing? I would just mark your areas where you're thinking you're rubbing with blue tape and drive around and find out where your tire is touching the blue tape. thats where you can determine you're rubbing.
otherwise 17x9 +35 with 245s should not be rubbing. Its a pretty safe offset
DuMa is offline   Reply With Quote
The Following User Says Thank You to DuMa For This Useful Post:
Toyarzee (04-22-2016)
Old 04-22-2016, 01:40 PM   #5
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
That's crazy... I'm running 17x9 et35, albeit rpf1's, and 1.8 neg camber without any issue on stock struts. Are the Koni's much different?
Toyarzee is offline   Reply With Quote
Old 04-22-2016, 02:30 PM   #6
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
More importantly, WHAT are you rubbing? Tire + strut? Tire + wheel arch? Tire + fender liner?
Please be more vague.
sdemo is offline   Reply With Quote
The Following 3 Users Say Thank You to sdemo For This Useful Post:
MisterSheep (04-22-2016), mixtape (04-25-2016), wparsons (04-25-2016)
Old 04-22-2016, 02:38 PM   #7
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
How much are you lowered? I'm lowered 1 inch on springs with the stock struts, same wheel/tire, same camber (SPC bolt in lower hole) and I don't rub anywhere.
BigTuna is offline   Reply With Quote
The Following User Says Thank You to BigTuna For This Useful Post:
Old 04-23-2016, 01:29 PM   #8
Cole
Not a troll
Cole's Avatar
I have -2.5* of camber up front on 17x9 +35 on stock struts and S-Tech springs. Camber was achieved by adjustable top hats (SilverProject) and camber bolts. I don't rub, and have a healthy amount of space between wheel/tire and spring/strut.
If I recall correctly, -1* is probably the safest amount to run up front without adjustable top hats.
Cole is offline   Reply With Quote
The Following User Says Thank You to Cole For This Useful Post:
Old 04-23-2016, 02:12 PM   #9
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
this
The Following 2 Users Say Thank You to continuecrushing For This Useful Post:
sdemo (04-23-2016), wparsons (04-25-2016)
Old 04-23-2016, 02:59 PM   #10
toby714
Drives: whiteout
i ran 255 with that wheel. you might need to shave the rear tabs other than that you should be good the rear fenders are rolled from the factory
toby714 is offline   Reply With Quote
Old 04-24-2016, 03:35 PM   #11
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Probably rubbing on the spring/shock considering he said he doesn't want to run spacers.
Surprising since I run 17x9 +45 on coils and nowhere near close.
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
Old 04-24-2016, 06:38 PM   #12
lightdir
Drives: 2013 Raven FRS 6MT
i ran 17x9 +35 245/40/17 on stock suspension and no rubbing
lightdir is offline   Reply With Quote
Old 04-24-2016, 07:11 PM   #13
sdemo
sdemo's Avatar
Literally none of you are helping.
The Following User Says Thank You to sdemo For This Useful Post:
Old 04-25-2016, 10:14 AM   #14
gtslow
Drives: 2015 Halo FR-S
Kind of hard to help when the OP doesn't respond. Would be nice to know how he achieved camber and exactly where he is rubbing.
Sent from my SM-G920V using Tapatalk
gtslow is offline   Reply With Quote
Endlinks rubbing frs_94 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 04-16-2016 04:43 PM
Rubbing fender. dito Southern California 34 05-15-2015 01:12 AM
Any rubbing issues with 17x9.5 +40 wheels and 255/40/17 tires? Eazy-V Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 11-02-2014 09:42 PM
How much rubbing is too much rubbing? Pokeguyjai Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 12-10-2013 08:04 PM
Rubbing sound? Mo707 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-15-2013 11:06 AM
